    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 716.7k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • DrSilverthornD Offline
      DrSilverthorn
      I’m not sure if this has been reported already. But there are some remaining issues with the music player app. First problem - on android, if you have more than one music app loaded in memory, if you hit the forward button while the current music app is playing, the player will sometimes switch to the background app and start playing audio from it. The second problem can be seen in the photo below. If you use one of the audio controls on the watch (forward for example), then the current track time will fail to reset from that point forward, and will keep counting higher, even when another track is played (won’t reset there either). See photo below, I just hit forward to get to this track, and the total time is 8:58/8:00. Also note that the progress bar is now filled, even though the track has just started playing (probably tied to the failure to reset mentioned earlier.
      And finally - the other night, the watch went into DND mode, as per my settings. When it did that, the backlight came on and stayed on. I was unable to turn it off - since none of the settings showed it to be on. I had to reset the watch for it to go off.
      Suunto Race Ti, Vertical Ti, Vertical 2 Ti, Garmin Enduro 1/2, Polar VV2
      Brad_OlwinB ? 2 Replies Last reply Reply Quote 0
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @DrSilverthorn
        @DrSilverthorn Maybe an overall glitch fixed by reset. I am on iOS and have never seen these issues with the music player.
        Vector/T6c/Vertical 2 Ti
        SuperFlo75S 1 Reply Last reply Reply Quote 0
        • SuperFlo75S Offline
          SuperFlo75 Silver Members Bronze Member @Brad_Olwin
          @Brad_Olwin And why should I use the music control on the watch? I can direct my music by head-shaking with my wing 😂😉😂😉
          Suunto Vertical 2 Titanium Sage
          Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
          Suunto Wing
          Suunto 9 Peak Pro Titanium (owns my wife now)
          Suunto Spartan Ultra
          SA iOS 3.12.0 (22937)
          Instagram @superflo75
          1 Reply Last reply Reply Quote 3
          • ? Offline
            A Former User @DrSilverthorn
            @DrSilverthorn @Brad_Olwin I am on Android 14 and can confirm similar experience.
            If I was listening to a podcast (Podcast Republic) and switched over to music (Oto music), pause or take a call it may open either music or podcast or show “Nothing to Play”. No specific default.
            Restarting either will then show the controls on the watch and resume function.
            sartoricS 1 Reply Last reply Reply Quote 0
            • sartoricS Offline
              sartoric Moderator @Guest
              @Todd-Danielczyk
              I guess that is something related to Android.
              I have similar issues with my openrun headphones, skipping tracks skip also the player 😁
              SVTS - 2.50.28
              SSSWHR BARO Amber - 2.8.32
              Samsung A5 2016 - Android 7.0
              Suunto App Android 6.11.8 beta
              • M Offline
                Marko1478
                I had blood oxygen measurement on but then decided to switch it off. Still every morning the watch shows the last recorded blood oxygen reading and altitude in the morning report. Minor bug but annoying.
                renton82R 1 Reply Last reply Reply Quote 1
                • renton82R Offline
                  renton82 Platinum Member @Marko1478
                  @Marko1478 And i bet always 100%?
                  M 1 Reply Last reply Reply Quote 0
                  • L Offline
                    lilaceo @Tieutieu
                    @Tieutieu the same happens to me…
                    • L Offline
                      lilaceo @maszop
                      @maszop I’ve arrived a that conclusion times ago, I suppose there are many people in this forum thats works for Suunto. The same happens in the telegrams channels . many times the answer is “maybe you are not a suunto watch customer”… my god… I’ve arrived the conclusion that they knows the watch slacks and try to justiticate with that kind of answers. I’ve also decided that the vertical is going to be my last suunto watch…, that’s all.
                      • sartoricS Offline
                        sartoric Moderator @lilaceo
                        @lilaceo said in Suunto Vertical: Bug Collection:
                        Some (few) yes
                        Many,no
                        SVTS - 2.50.28
                        • M Offline
                          Marko1478 @renton82
                          @renton82 when blood oxygen was on, it wasn’t always 100% but the last known reading was 100% and now it does always say that 😄
                          I don’t care about blood oxygen, I’m just annoued that the morning report shows the last known reading from many weeks ago.
                          renton82R 1 Reply Last reply Reply Quote 0
                          • renton82R Offline
                            @Marko1478 Yes i mean last reading in Suunto app… it’s always at 100% what is the sense of this data? 😂
                            • G Offline
                              GKnoll
                              Apologies if this post is in the wrong thread.
                              It appears that the minimum number of data fields that can be displayed, for example for running, is three. My close-in eyesight is not great and it would help if there are 1-field and 2-field display options with the data displayed in large characters so I read the data easily without wearing glasses (that I otherwise do not need for running).
                              My Garmin (sorry…) Fenix 6 had this option and I found it worked well.
                              Thanks.
                              AudaxjoeA 1 Reply Last reply Reply Quote 3
                              • AudaxjoeA Offline
                                Audaxjoe @GKnoll
                                @GKnoll agreed. It would help me also.
                                Suunto Vertical
                                Suunto 9 BARO
                                Garmin Fenix 3, 5
                                Suunto Vector
                                • TieutieuT Offline
                                  Tieutieu Platinum Member @Brad_Olwin
                                  @Brad_Olwin said in Suunto Vertical: Bug Collection:
                                  @Tieutieu I rarely ski at resorts but thought uphill was not counted. A tester has reported this as a potential bug. We will see what Suunto says.
                                  As a reminder : still buggy on SV and S9pp
                                  Vertical week should give surprises so ! 😁
                                  Suunto’s devices at home :
                                  Vertical titanium solar
                                  Suunto Race S
                                  S9pp titanium sand
                                  Suunto Wing & Spark
                                  S9B titanium Ambassador edition, A3P, X6
                                  • Tami999T Offline
                                    Tami999 Silver Members
                                    Happened with 2.33.12 - Q1 2024 today’s update.
                                    Actually it seems like small bug. I noticed something weird on default Vertical watchface after update, it took me some seconds to figure what actually changed or missing, and that was altitude missing ,m" (meters) next to number.😁
                                    I’ve tried change watchface or soft reset but it still missing.
                                    L isaziI 2 Replies Last reply Reply Quote 6
                                    • L Offline
                                      Likarnik Gold Members @Tami999
                                      @Tami999 hahaha, same, what is new, something is weird, but it didn’t click 😄
                                      B 1 Reply Last reply Reply Quote 0
                                      • B Offline
                                        batavlasta @Likarnik
                                        Hi, could you please advice me? Is this normal graphic view or some kind of issue with screen. Looks kinda distorted, no sharpness. Thank you. 20240326_081338.jpg
                                        • isaziI Offline
                                          isazi Moderator @Tami999
                                          @Tami999 it is known and reported, I believe it is to save some space.
                                          Blog: isazi's home
                                          • I Offline
                                            Iggge
                                            This is how 8-9 hours of sleep looks like for me, everyday. Anyone else has this problem?
                                            TieutieuT jjpazJ 2 Replies Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
