    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 738.4k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Brad_OlwinB Offline
      Brad_Olwin Moderator @duffman19
      @duffman19 said in Suunto Vertical: Bug Collection:
      @Brad_Olwin Ah, yes, this somewhat solves it. But I still think this behavior is incorrect. The Map widget should operate independent of any Activity settings. Recording an activity in something other than Performance shouldn’t turn the map in the Map widget off.
      This is the same behavior that we have with Media Controls. Turning Media Controls off in the activity options completely disables the Media Controls widget. I know this has confused quite a few folks.
      Activity options simply shouldn’t impact widget functions. Any idea if this is being addressed?
      The map cannot operate independently as there is one map. Perhaps it should come back on but is easy to turn on. I am with you on media controls, I have asked for this to change but not sure it will.
      Vector/T6c/Vertical 2 Ti
      M 1 Reply Last reply Reply Quote 0
      • M Offline
        maszop Bronze Member @Brad_Olwin
        @Brad_Olwin But it’s still a bug
          Brad_Olwin Moderator @maszop
          @maszop what is a bug? The maps turning off works as intended.
          M 1 Reply Last reply Reply Quote -1
          • M Offline
            @Brad_Olwin I will repeat what was written earlier: Changing battery settings during activity turns off the map view also outside of activity. For me this is an obvious bug (fortunately not too serious).
            The map widget should check and change this on startup. This is not rocket science in 2024.
            For some people it is apparently very difficult to accept that something is not working properly and someone reports a problem.
            These are just watches — not religion.
            sartoricS Brad_OlwinB 2 Replies Last reply Reply Quote 1
            • sartoricS Offline
              sartoric Moderator @maszop
              @maszop said in Suunto Vertical: Bug Collection:
              Actually, there are people that try to clearly understand what is the problem reported so it can eventually be forwarded to Suunto via official bug reporting.
              SVTS - 2.50.28
              SSSWHR BARO Amber - 2.8.32
              Samsung A5 2016 - Android 7.0
              Suunto App Android 6.11.12 beta
                @maszop I’m not saying anything except it is not a bug AFAIK it is working as intended.
                • D Offline
                  duffman19 @duffman19
                  I’ve found a bug associated with the Map widget.
                  I think I’d like to redact my original phrasing calling this a bug. Perhaps it’d be better to call this “unexpected behavior”? Didn’t mean to cause a row! 😃
                  As I now understand it, the Map is actually functioning as part of the Navigation feature, which itself is operating as its own independent thing; like a separate app in the background. I think most users, when clicking through the Map widget, would expect to see the actual map. Instead, it’s acting like a shortcut to open the Navigation function, which has maintained the settings from the last time it was used in an activity.
                  Two possible solutions are:
                  • Rename the widget Navigation instead of Map. That’s what it really is, no? All of the navigation features are there. And sometimes the map isn’t. 😉
                  • Separate the Map widget settings from activity Navigation settings. Maybe that’s not possible (or easy to implement) given how I think things currently work, but I believe that’s what most users would expect.
                  Vertical Ti / S9PP Ti / S9P Ti
                  1 Reply Last reply Reply Quote 3
                  • M Offline
                    @Brad_Olwin According to this logic, if I turn off the heart rate monitor during some activity, sleep detection and many other functions that normally use this sensor will not work from the end of that activity.
                    This is absurd.
                    I won’t write in this thread any more because it’s obvious and I’m not interested in pointless arguments.
                    Brad_OlwinB L 2 Replies Last reply Reply Quote 1
                    • TieutieuT Offline
                      Tieutieu Platinum Member
                      I have this small « bug » sometimes : when exercicing with personnal sport mode with touchscreen activated, sometimes touchscreen doesn’t work. Happened yesterday. Can’t relate it to any particular action.
                      Suunto’s devices at home :
                      Vertical titanium solar
                      Suunto Race S
                      S9pp titanium sand
                      Suunto Wing & Spark
                      S9B titanium Ambassador edition, A3P, X6
                      L 1 Reply Last reply Reply Quote 0
                        This is absurd.
                        I am not passing judgement, just informing you this is not a bug. I have not stated what my opinion is but trying to help here so that you do not think this is a bug that might be fixed. You can certainly make a feature request for this. Don’t shoot the messenger.
                        • M Offline
                          Marko1478
                          Suunto Vertical step counter is still terrible. All I need to do is glance at my watch and I gain a few steps. Tried the SR also and it seemed to have a much better and realistic step counter. Hopefully the SV also gets that update some day.
                          • SvenSchroeterS Offline
                            SvenSchroeter
                            I made an exhausting little experiment this morning. I tried to determine my max heart rate in a vague attempt to see where the limit lies. From the attempt, you can see that the result seems to be capped at 210bpm (graph attached).
                            The 210bpm limit appears to be a flat line spanning accross a period of 5 or 6 minutes. It looks like a software limit, or a measurement limit has been reached. I am not sure if this is a scalling issue in the app, or a limit in the raw data recorded during the activity.
                            But the flat line visualisation makes me thing that it is a software or firmware limitation.
                            I realise that a wrist watch measuing this data on the pulse is not going to be the most accurate. and i am not looking for absolute values. rather interested in relative readings which i can make some judgement calls on. Not sure if anyone else has seen this llimit.!Screenshot_20240306_122259_Suunto.jpg
                            Suunto Vertical Ti Solar (Daily)
                            Suunto Race (Wife Daily)
                            Retired: Suunto Ambit3 / Ambit / Core
                            https://www.strava.com/athletes/142980701
                            TieutieuT 1 Reply Last reply Reply Quote 0
                            • TieutieuT Offline
                              Tieutieu Platinum Member @SvenSchroeter
                              @SvenSchroeter interesting !
                              You probably should try with an hr belt to compare behavior.
                              I can’t reproduce, my max hr is so low compare to you…(around 175).
                              Suunto Race S
                              S9pp titanium sand
                              Suunto Wing & Spark
                              SvenSchroeterS 1 Reply Last reply Reply Quote 0
                                SvenSchroeter @Tieutieu
                                @Tieutieu You are right about that! And i am already looking at options on amazon as i saw your reply! I assume the wrist gives higher estimates than a belt.
                                But since I am not interested as much in the absolute readings, rather relative. If i take the 210bpm and set it as my max heart rate everything should scale in the training zones accordingly. As long as you keep using the same device, and it is giving shall we say consistent errors (deviations from the absolute real reading) then I should be ok. Maybe my thinking is flawd…
                                I was just sprprised to see such a perfect flat line. Which looks like a limit of the graphing, or the readings themselves.
                                Just an interesting point. Was really surprised myself to see 210bmp… i am 37years old… I have seen peaks of 191 in one or 2 activity sessions, but nothing above 200bpm until i did this little test.
                                Mff73M ? 2 Replies Last reply Reply Quote 0
                                • Mff73M Offline
                                  Mff73 @SvenSchroeter
                                  @SvenSchroeter
                                  this flat part can be, software limit, of also bug of the HR sensor, maybe the whole values are even not correct, etc…
                                  210 is quite not common.
                                  You can use (for free 🙂 ) a two fingers sensor on your throat or wrist, to check if 210 is something “logic” for you at that time.
                                  And, theorically, optical HR should be less than with a belt
                                  SSU (retired), SV1, SV2
                                  Wife : S9PP
                                  SA: Always the latest beta :)
                                  Android + Galaxy S205G
                                  • ? Offline
                                    A Former User @SvenSchroeter
                                    @SvenSchroeter said in Suunto Vertical: Bug Collection:
                                    I remember years ago I had that value during a race because of an arrhythmia, the watch read 210 for 10 or more minutes, but the doctors told me I was at 220 or maybe more iirc (I was 56yo)–so I’m also thinking of a chest strap limitation as well (I was wearing a H10)
                                      SvenSchroeter @Guest
                                      @robis i think it is because commonly it is used the 220 - age calculation for the recommended max hr. And tytpically they assume no one under the age of ten will be using such a watch/tool, hence they cap it at 210 maybe. Also based on the studdies performed on the general population. which even suunto themselves have written can be grossly inaccurate (especially for the older generation).
                                      https://www.suunto.com/en-us/sports/News-Articles-container-page/know-your-resting-and-max-heart-rates/
                                      Was an interesting read. Normally I have a much much lower heart rate during activity. Rarely going over 160bpm or 170bpm. But i tried to push this morning and when i looked back at the data after a shower… i was ready to head to the emergency room 😉
                                      • sartoricS Offline
                                        sartoric Moderator
                                        Just a glitch in alarm menu I’ve noticed today
                                        SVTS - 2.50.28
                                        • T Offline
                                          TurtleCub
                                          For the vertical, is there a reason why autolaps are not recorded and downloaded if the lap button is used in a run? All suunto watches I used in the past recorded both.
                                          Can this be setup/changed?
                                          If no manual laps are used, the autolaps show up in the run
                                          DrSilverthornD 1 Reply Last reply Reply Quote 0
                                          • DrSilverthornD Offline
                                            DrSilverthorn @TurtleCub
                                            @TurtleCub if you use the manual interval S+ app, then the manual laps are recorded.
                                            Suunto Race Ti, Vertical Ti, Vertical 2 Ti, Garmin Enduro 1/2, Polar VV2
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
