    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 779.3k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User @Tieutieu
      @Tieutieu same problem with the s9pp, I had (sorry) @taziden reported that a while ago… and I confirmed that!
      • stromdiddilyS Offline
        stromdiddily Gold Members
        TSB on watch face switching values when display is activated vs not.
        The -23 is the correct value but you can see it toggling between that and -15 which was from the day before.
        https://photos.app.goo.gl/f9Vyxn6YapLuorJ46
        Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
        User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @stromdiddily
          @stromdiddily I am not seeing this on production firmware. Mine is stable. However, in the morning it takes time for the new value to be reflected and does not always occur on the first sync. My TSB value is - 22 in SA, in the main widget and on the watch face mini widget.
          Vector/T6c/Vertical 2 Ti
          stromdiddilyS 1 Reply Last reply Reply Quote 0
            stromdiddily Gold Members @Brad_Olwin
            @Brad_Olwin said in Suunto Vertical: Bug Collection:
            Ok - do you want me to submit logs if it happens again? I too am on production firmware unfortunately 😉
              @stromdiddily I think this is fixed in new firmware so probably not.
              • T Offline
                tkernen
                I’ve been having on and off BLE connectivity issues for at least the last couple of months. I start an activity and none of my paired BLE devices connect to my SV (Polar H10, Stryd), even the Suunto App on my phone doesn’t sync.
                The workaround is for me to put the SV into airplane mode, exit the menu, then back into the menu and disable airplane mode. It fixes the issue each time.
                I still can’t figure out what does trigger this lack of BLE connection with paired devices.
                I think, but I’m not sure that BLE devices connected via apps such as Core and Train.Red don’t see to suffer from this issue (TBC).
                The current SW on my SV is 2.30.38, Bluetooth is 3.0.28
                Anyone else has come across this issue?
                Ambit 3 Peak, S9 Baro Ti, S9 Peak Ti, Vertical 1 Ti, Vertical 2 Ti
                • I Offline
                  Iga6101 @isazi
                  @isazi
                  I have same problem. Cant update Vertical Solar.
                  Could you help me pls
                  • seanvkS Offline
                    seanvk
                    Just today - had an alarm scheduled to go off at 8:30AM but I could not shut it off.
                    Latest Vertical firmware.
                    1. Set Alarm to 8:30 AM the night before
                    2. Alarm goes off at 8:30 AM the next day
                    3. Press “Dismiss”, display returns to watch face.
                    4. Alarm continues to go off.
                    5. The Alarm will not stop.
                    6. Power off watch.
                    Suunto Race Titanium
                    Suunto Vertical Titanium
                    Suunto 9 Peak Pro Forest Green
                    Suunto 9 Peak Moss Gray
                      Brad_Olwin Moderator @tkernen
                      @tkernen I have two Vertical watches, one behaves like yours and the other does not. I am concerned this may be a hardware issue. I filed a bug report with Suunto but do not know whether it is hardware or firmware. Running either production or field-test firmware does not alter the BT connection problems. I tend to think hardware-related but cannot be sure. Mine seems to be getting worse. I would contact support. Neither a hard reset or soft resets fix the issue for me.
                      T 1 Reply Last reply Reply Quote 0
                      • L Offline
                        lilaceo @Tieutieu
                        @Tieutieu my latest firmware is 2.30.26 NO NEW UPDATES, maybe de difference are what kind of Vertical you have ? Solar o no ?
                        mine is NOT solar
                        TieutieuT 1 Reply Last reply Reply Quote 0
                        • TieutieuT Offline
                          Tieutieu Platinum Member @lilaceo
                          @lilaceo you should have the 2.30.38 fw
                          It’s the same for solar or no solar SV
                          Suunto’s devices at home :
                          Vertical titanium solar
                          Suunto Race S
                          S9pp titanium sand
                          Suunto Wing & Spark
                          S9B titanium Ambassador edition, A3P, X6
                          • pilleusP Offline
                            pilleus
                            @pilleus said in Suunto has nailed sleep:
                            For a week now, I’ve been tracking my naps during the day in addition to my nighttime sleep. The Vertical records the times without any problems and reliably.
                            There’s just one problem with it. The sleep times are added up on the Vertical, but not in the Suunto app. The HRV values ​​are added up in the Suunto app, but not on the Vertical.
                            So I have different values ​​in the watch and in the app that can never match.
                            Something needs to be improved here. 🤔
                            Reference to this problem with sleep tracking …
                            https://www.instagram.com/moves.are.life/
                            Suunto Vertical Black Lime
                            Suunto 9 Peak Pro Black
                            Suunto Spartan Ultra Stealth Titanium
                            • I Offline
                              Iga6101 @markman8
                              @markman8
                              Hei. I have same problem. How did you solved it
                              • I Offline
                                Iga6101 @GiPFELKiND
                                @GiPFELKiND
                                Hello.
                                I have exactly the same problem markman8 and cant update watch.
                                Can you help me pls
                                • T Offline
                                  tkernen @Brad_Olwin
                                  @Brad_Olwin Thanks for your input. It seems that now none of the SuuntoPlus seem to work either (Core, Train.Red, the new Stryd app). Nothing connects.
                                  And yes it happens more and more frequently. I’ll reach out the Suunto support.
                                  • D Offline
                                    duffman19
                                    I’ve found a bug associated with the Map widget. It seems to “remember” the last Battery Mode (aka GPS setting) used for the previous activity rather than defaulting to Performance (aka multiband). So, if you start and end an activity using any Battery Mode other than Performance, and then later scroll to the Map widget, you’ll get a black breadcrumb screen with no background map image.
                                    In order to get maps back, you’ll need to start and end an activity using the Performance Battery Mode.
                                    Vertical Ti / S9PP Ti / S9P Ti
                                    Brad_OlwinB D 2 Replies Last reply Reply Quote 0
                                      Brad_Olwin Moderator @duffman19
                                      @duffman19 I think the maps are simply off if you were in Endurance, Ultra or Tour mode. Simply scroll down when in the map widget and turn the map you want to on. Not a bug.
                                      D 1 Reply Last reply Reply Quote 0
                                      • D Offline
                                        duffman19 @Brad_Olwin
                                        @Brad_Olwin Ah, yes, this somewhat solves it. But I still think this behavior is incorrect. The Map widget should operate independent of any Activity settings. Recording an activity in something other than Performance shouldn’t turn the map in the Map widget off.
                                        This is the same behavior that we have with Media Controls. Turning Media Controls off in the activity options completely disables the Media Controls widget. I know this has confused quite a few folks.
                                        Activity options simply shouldn’t impact widget functions. Any idea if this is being addressed?
                                        Brad_OlwinB 1 Reply Last reply Reply Quote 1
                                        • mlakisM Offline
                                          mlakis Bronze Member
                                          A not so persistent bug happened yesterday.
                                          After a hike, the CTL value on the Vertical sky-rocketed to 487!
                                          A couple of syncs didn’t solve the problem at first. I think a sync after several hours did it.
                                          • M Offline
                                            Marko1478
                                            This is not a bug, but a nuisance. Vertical doesn’t seem to have any oleophobic coating on the screen. It gets very smudgy and wiping with a shirt sleeve doesn’t help. I tried two different Verticals and they were the same. Now I have the Suunto Race and it doesn’t seem to have this problem, but I would still prefer the Vertical aesthetics.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
