    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 767.0k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      Swaddy61 Silver Members @helgonet12
      @helgonet12 Hmmm… I don’t know what else to suggest! 😕
      SV Ti All Black, Coros Apex Pro, Ambit 3 Peak, Ambit 3 Sport (sold), Ambit 2 (Sold), X10 Mi (Retired), Quest (Sold), T3 (Sold), T6C (Retired as unfixable - Suunto gave me a big discount on Ambit 2!), Polar H10 belt, Suunto Smart Belt
      helgonet12H 1 Reply Last reply Reply Quote 0
      • helgonet12H Offline
        helgonet12 @Swaddy61
        @Swaddy61 thanks for trying. Let’s wait and see what the next update will bring.
          @Swaddy61 the HR readings are quite good compared to others. So it can’t be it. I have also tried different resting HR but with same results.
          The HRV results are also good. Does any one else have this problem or are your recourses work?
          • W Offline
            wakarimasen Gold Members
            I got lost with the previous discussion on this, but maybe changing your RHR would help?
            Suunto Race Titanium
            Suunto Ambit3 Peak
            Polar H10
            Polar OH1
              helgonet12 @wakarimasen
              @wakarimasen thanks for the answer but I have tried this but with same result.
              • flucaF Offline
                fluca Silver Members
                I noticed that after circuit training with backlight always on, the backligth stays on and to shut it off I have to either soft reset or today I hactivated the flashlight and it worked.
                  helgonet12
                  I don’t know if it is a bug and it has been reported before. But when pressing and holding the lower button you use the short cut and it goes to control panel. Which is correct. But it doesn’t show battery, alarm (if you have one active) and day , date and month. You need to press up to see this info. I use this short cut a lot since you cannot have date on the watch face. ( I know you can press the screen and change) but use the shortcut goes faster thang change it on the watch face because you need to first press the button to “wake” up the watch and the change it on the watch face and I often need to press multiple times before it reacts. Not always but often. And since the watch faces probably will not change ( according to a forum admin/ field tester in another tread) it would be nice if this gets fixed.
                  • flucaF Offline
                    I think I found another possible bug yesterday.
                    During my run with custom mode I realized that the option to turn off wrist hr during activity does not work.
                    I tried twice.
                    freeheelerF L 2 Replies Last reply Reply Quote 0
                    • freeheelerF Offline
                      freeheeler @fluca
                      @fluca
                      that’s known 🙈
                      living sideways
                      DrSilverthornD 1 Reply Last reply Reply Quote 1
                      • DrSilverthornD Offline
                        DrSilverthorn @freeheeler
                        I recently added an unsecured wifi network to my vertical (so now there are two networks set up, one secure (my home network), and the other the new unsecure one). I hooked it up to the charger, thinking it would download maps. However the watch would beep, then display a message about the map download being paused, and then to connect to a charger and wlan network). It would then start downloading, beep, and then the whole process would start over. It was similar behavior to the charger connection not being secure). So I tried cleaning the connections, with no change. I tried restarting, no change. I then removed the unsecure network, and everything was normal. But I can’t download maps, when I thought I’d be able to. The network seems solid, since I’ve been using it with my phone and tablet.
                        Suunto Race Ti, Vertical Ti, Vertical 2 Ti, Garmin Enduro 1/2, Polar VV2
                        Brad_OlwinB ? 2 Replies Last reply Reply Quote 0
                        • Brad_OlwinB Offline
                          Brad_Olwin Moderator @DrSilverthorn
                          @DrSilverthorn there may be characters in SSID that prevent adding a viable connection. I cannot remember what some of them were.
                          Vector/T6c/Vertical 2 Ti
                          DrSilverthornD 1 Reply Last reply Reply Quote 0
                          • ? Offline
                            A Former User @DrSilverthorn
                            @DrSilverthorn the work around for unsecured WIFi is to use your phone as a Hotspot and connect your phone to the unsecured WiFi.
                            https://forum.suunto.com/post/132541
                            I did exactly this in a hotel recently and got map updates.
                              DrSilverthorn @Brad_Olwin
                              @Brad_Olwin No usual characters in the SSID.
                                DrSilverthorn @Guest
                                @Todd-Danielczyk Thanks, will give this a try at next charge.
                                • ? Offline
                                  A Former User
                                  Hello everyone,
                                  I must be cursed! I received my second vertical yesterday at the end of the day. As soon as I started it, I got a message “the device recovered from an error”. It’s off to a good start! The first I got an error code 2.25.63…
                                  This does not give me confidence for the future.
                                  I still performed a soft reset then the latest update. The watch does not seem to be malfunctioning at the moment (apart the OHR values -> between 95 and 120 at rest, the counting of steps and the TSS, TCL data delayed with the application.
                                  • ? Offline
                                    A Former User
                                    And it continues !!!
                                    I don’t understand how a brand like Suunto can leave a watch on the market with so many bugs! As much as the construction of the product is impeccable, the software contains multiple bugs and malfunctions! In 2 days, I suffered 2 crashes while running. The step counter tells me more than 10,000 steps in a day where I spend 6 hours sitting at the office. Example of this afternoon where the watch counts 3467 while I vacuum. (with a cardio at 125 please) At this value, I am at 5:00 per km in running.
                                    This software is really a big piece of shit! My wife’s Forerunner 255 does much better!
                                    The chat does not respond. No support! Before it’s too late I think my Suunto adventure ends here! I will take advantage of the 14 days to return this watch and get a refund.
                                    TieutieuT zhang965Z 2 Replies Last reply Reply Quote 0
                                    • TieutieuT Offline
                                      Tieutieu Platinum Member @Guest
                                      @Fizzgig Sorry to hear that…unfortunatly as many times repeated, many of us don’t experiment what you are…
                                      It’s a shame you suffer of so much issues…
                                      Suunto’s devices at home :
                                      Vertical titanium solar
                                      Suunto Race S
                                      S9pp titanium sand
                                      Suunto Wing & Spark
                                      S9B titanium Ambassador edition, A3P, X6
                                      ? 1 Reply Last reply Reply Quote 3
                                      • zhang965Z Offline
                                        zhang965 @Guest
                                        @Fizzgig said in Suunto Vertical: Bug Collection:
                                        That’s a nice pace.
                                        Bon courage !
                                        Winners Wear Winners
                                        • ? Offline
                                          A Former User @Tieutieu
                                          @Tieutieu
                                          Poor suunto!!
                                          Even when synchronizing, the watch and the application do not give the same values ​​-. In addition to being completely false, the data does not match the application. Sunnto development is too strong!!!
                                          Sorry but I’m getting my 800 euros back which I’m going to give to the American giant! I’m willing to favor European manufacturing, carbon compensation, but then I have to spend 800 euros for crappy software, no, sorry !!!
                                          The Strongest !! 386 steps just while going to the toilet 😂 😂 😂
                                          S 1 Reply Last reply Reply Quote 3
                                          • S Offline
                                            soisan @Guest
                                            @Fizzgig No need to feel sorry! You are happy with Garmin, we are happy with Suunto, no hard feelings! Enjoy your sports!
                                            1 Reply Last reply Reply Quote 5
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
