    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 779.5k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • TieutieuT Offline
      Tieutieu Platinum Member
      I can confirm that the map doesn’t center automatically like before, if you move the map.
      To make it centered again on position, just tap once on screen.
      I don’t think it’s a bug, but more likely a welcome update. First I was disturbed but in fact it’s pretty cool because when you move the map that’s because you want to see another area. Before it was almost impossible to navigate on map due to auto-center.
      I just tested it accidentally this afternoon during a trail running on a place I didn’t know ; I was forced to change from the route I had prepared due to submerged roads (overflowing), and it was very cool to navigate on map without auto center. One tap on screen and it’s back on center.
      (Ruler was disabled)
      So for me, nice improvement.
      Suunto’s devices at home :
      Vertical titanium solar
      Suunto Race S
      S9pp titanium sand
      Suunto Wing & Spark
      S9B titanium Ambassador edition, A3P, X6
      C 1 Reply Last reply Reply Quote 3
      • TieutieuT Offline
        Tieutieu Platinum Member @surfboomerang
        @surfboomerang if I tap one time it centers again
        Suunto Race S
        S9pp titanium sand
        Suunto Wing & Spark
        • C Offline
          Carlos97atz @Tieutieu
          @Tieutieu Ah vale, ya me estaba preocupando jajajja. Pues si, es una buena idea para explorar. Tengo otra pregunta no se si es mejor preguntar aqui o en otro apartado.
          He visto gente que mientras esta de ruta siguiendo un track en el reloj, entra en ese mismo track en la aplicación y sale el track y su ubicación actual. Yo no se hacerlo. Es una muy buena idea para explorar tambien de la aplicación.
          Gracias!
          cosme.costaC 1 Reply Last reply Reply Quote 0
          • cosme.costaC Offline
            cosme.costa @Carlos97atz
            @Carlos97atz said in Suunto Vertical: Bug Collection:
            Gracias!
            Hola Carlos, recuerda que la lengua “oficial” del chat es el inglés, llegarás a más gente, que te podrá ayudar, si escribes en inglés.
            Lo que comentas creo que lo puedes hacer si entras a editar la ruta dentro de la aplicación, cuándo lo haces te da tu posición. No se si lo sabes pero con Suunto puedes enviar diferentes rutas al reloj aunque estés en medio de una actividad, la envías y después desde el reloj la puedes cargar.
            Hi Carlos, remember that the “official” language of the forum is English, you will reach more people, that will be able to help you if you write in English.
            Regarding your comment, you can do it if you edit the route in the Suunto App, doing that it will show your position. I do not know if you know that with Suunto you can send different routes to the watch mid activity and the you can load them from the watch.
            • Jakub SliacanJ Offline
              Jakub Sliacan
              Hi!
              As others noticed, there definitely was a regression in the latest sw update (to 2.33.12). When I put the watch on charge, the display goes off and never wakes up. Luckily, it recovers after a long press of the upper button. As far as I remember, this behavior wasn’t there before, but is there consistently after the update.
              Given that this makes charging pretty awkward, a bug-fix release would be appreciated!
              Thanks,
              Jakub
              AudaxjoeA 1 Reply Last reply Reply Quote 1
              • AudaxjoeA Offline
                Audaxjoe @Jakub Sliacan
                @Jakub-Sliacan I did have this charging issue when I first purchased the Vertical (November). So on the old software. It only happened once.
                And I saw post of other people saying the same issue before the update, it may not be update related.
                Suunto Vertical
                Suunto 9 BARO
                Garmin Fenix 3, 5
                Suunto Vector
                • darxmurfD Offline
                  darxmurf Platinum Member
                  Hi all,
                  Quick bug here, the heart rate is like auto disabled when I leave the watch on the table even for like 1h. I have to restart the watch to have it back. Without restart, I can’t check my heart rate from the widget and I don’t have it either during sport.
                  https://www.instagram.com/darxmurf/ - https://www.instagram.com/omch.swiss/
                  freeheelerF 1 Reply Last reply Reply Quote 1
                  • freeheelerF Offline
                    freeheeler @darxmurf
                    @darxmurf
                    rule number 1: the watch has to be on the wrist, ALWAYS! 😉
                    seriously… did you try multiple times?
                    I never use the HR widget on my daily watch, but I have watches laying around for days and they show my HR instantly when I put them on my wrist.
                    living sideways
                    darxmurfD 1 Reply Last reply Reply Quote 0
                    • darxmurfD Offline
                      darxmurf Platinum Member @freeheeler
                      @freeheeler huh, with the watch collection I have, it will be hard to keep them all on my wrist 😅 yep I tried multiple times, the green light is simply off under the watch and I have to restart it to have it back.
                      Brad_OlwinB 1 Reply Last reply Reply Quote 1
                      • Brad_OlwinB Online
                        Brad_Olwin Moderator @darxmurf
                        @darxmurf Should not happen and you have 24/7 HR on I assume?
                        Vector/T6c/Vertical 2 Ti
                        darxmurfD 1 Reply Last reply Reply Quote 1
                        • darxmurfD Offline
                          darxmurf Platinum Member @Brad_Olwin
                          @Brad_Olwin yep.
                          Mff73M 1 Reply Last reply Reply Quote 0
                          • Mff73M Online
                            Mff73 @darxmurf
                            @darxmurf
                            Did you put directly the watch sensor on contact iwth the table or the watch is laying on its band? Is the led flickering like trying to measure your table Heart rate 😁?
                            If the table surface has some reflection, the sensor might try to search and maybe after long time it “bugs” with results?
                            Just speculating…
                            SSU (retired), SV1, SV2
                            Wife : S9PP
                            SA: Always the latest beta :)
                            Android + Galaxy S205G
                            • darxmurfD Offline
                              darxmurf Platinum Member @Mff73
                              @Mff73 weird, I specially tried today, on a “wooden” surface and a classic white ikea cupboard and the sensor is still working 😂 I love those random bugs
                              • darxmurfD Offline
                                Sensor still working 😅 it reminds me the chemistry machines we have st work, 3 or 4 reboot are required to make them working again 😂
                                freeheelerF darxmurfD 2 Replies Last reply Reply Quote 2
                                • Mff73M Online
                                  Mff73 @darxmurf
                                  @darxmurf said in Suunto Vertical: Bug Collection:
                                  Which one as the highest HR? 😂
                                  Wife : S9PP
                                    @darxmurf
                                    similar with my kids… they wouldn’t listen by the first time either…
                                    but they are great and I love them 😍
                                    living sideways
                                    darxmurfD 1 Reply Last reply Reply Quote 2
                                    • R Offline
                                      rpearce1475
                                      I’ve had my suunto vertical since early March. Mostly happy with it but for the past week it keeps crashing when I’m on runs. It only happens when using gps tracking, not when just tracking workouts via calorie. The screen switches to “restoring this watch to a safe mode” then nothing happens. I’ve waited up to an hour, no change, so I then hold down the power button and turn the watch back on which ends up doing a full factory reset and gives me “Error 1403,1301,1301”. This has happened now 4 times; I updated my software and it is still happening. Any thoughts/advice?
                                      R 1 Reply Last reply Reply Quote 0
                                      • darxmurfD Offline
                                        darxmurf Platinum Member @darxmurf
                                        okay, sensor is of again 🤔 there is clearly something wrong here
                                        • darxmurfD Offline
                                          @freeheeler If you say so 😆 I don’t have kids, I leave this pleasure to others 😆
                                          • R Offline
                                            rpearce1475 @rpearce1475
                                            Ok so it is now just stuck on the “device is being restored to a safe state” screen and no longer rebooting when I hold down the power button (even when left alone for a few hours). I tried holding down the upper and middle buttons for service mode, the screen for that came up then when I held down the upper button it went back to the same reboot screen.
                                            S 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
