    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 717.6k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • wmichiW Offline
      wmichi @slurpnik
      @slurpnik I have similar issues as you, although not in direct sunlight. The backlight (or raise to wake) during activities is very unreliable. In direct sunlight it’s not a problem, but in a forrest with changing light conditions, the display is hardly readable, because the backlight never turns on. I have done soft resets and hard resets, no luck. I cannot even activate the backlight in the activity settings. It simply doesn’t make difference, the backlight stays off. Only when it’s generally dark, the backlight turns on when I raise my wrist. So my guess would be, that this backlight sensor is not working correctly.
      When I am sitting in the sun (during an activity) and I raise the wrist, backlight stays off (as expected). If i cover the display with my hand and I raise my wrist, it takes 5s to 10s until the backlight turns on, and most of the time it doesn’t turn on at all and I have to do the raise to wake gesture multiple times, until it finally turns on.
      This was definitely not a problem on the previous firmware.
      ? 1 Reply Last reply Reply Quote 1
      • ? Offline
        A Former User @wmichi
        @wmichi @slurpnik one thing you may want to also check is if this is selected off or on in battery mode.
        I run mine off in custom mode and wondering if that’s what you have set up. Could explain why it goes dark during an activity and wakes up when buttons are pressed. Wouldn’t hurt to confirm
        wmichiW 1 Reply Last reply Reply Quote 1
        • wmichiW Offline
          wmichi @Guest
          @Todd-Danielczyk I only use performance mode (I have also checked this setting). It’s not that the screen goes completely off, it’s just the backlight, that won’t turn on. Or let’s put it in another way: the backlight sensor takes a long time to react to changes of the lightning conditions. Much longer as on the previous firmware.
          ? GiPFELKiNDG 2 Replies Last reply Reply Quote 2
          • ? Offline
            @wmichi thank you for confirming
            • S Offline
              slurpnik
              Thank you all for great discussion! I took a few days to experiment and wanted to get back to you.
              @sartoric Indeed, very good eye! I did have a screen protector to address the smudges (different thread here on forum). I got rid of it and continued my testing without it. Sadly, it’s not the screen protector that seems to be the issue.
              @Egika my screen does not behave like you describe - somehow it is darker and less readable with more sunlight.
              After a lot of testing, I came to minimal reproducible steps: no activity just regular watchface, display brigtness medium, standby Off, raise to wake high, no power saving, at 93% battery. When hold my watch and walk outside the house, the screen gets progressively less readable the more sunlight there is. When outside and trying to raise hand to activate backlight, it never does.
              When I walk back inside the house, raise to wake starts working after a dozen seconds and with backlight the screen is usable again.
              This seems to be the exact issue that @wmichi described, and in addition it seems like my display has some issue on direct sunlight. Since the issue is present even outside of activity, I don’t believe any activity settings affect this behavior.
              I will try to capture some photos and share here. Do you think this is hardware issue with my watch? Anything else I should try?
              EDIT: maybe I wasn’t totally precise, so let me correct the " somehow it is darker and less readable with more sunlight.". My screen does get slightly better when going outside, from totally dark to barely readable on sunlight. Problem is without backlight, which never turns on outside on sunlight, it stays in the “barely readable” state and I can’t force it to enable backlight (“backlight: on” seems ignored in activity options in the newest version).
              Watch: Suunto Vertical (titanium solar canyon)
              D Zdeněk HruškaZ Mff73M 3 Replies Last reply Reply Quote 0
              • D Offline
                duffman19 @slurpnik
                @slurpnik said in Suunto Vertical: Bug Collection:
                I’d say it’s almost certainly a hardware issue. The behavior you’ve described and shown with your pictures is the exact opposite of how a MIP display should work. As others have said, it should appear easier to read when outside or under brighter light. It should look almost like black ink on white paper under sunlight, no backlight required.
                It almost appears as though there is a polarized filter in front of your screen, turned the wrong direction, causing the screen to appear darker under more light. Does anyone know how the Vertical’s screen is constructed, whether there might be a polarizing layer somewhere in there? If so, if it’s rotated 90 degrees in the wrong the direction, it might cause this exact behavior.
                I’d try to get it back to Suunto if you can. Something is definitely wrong with it.
                Vertical Ti / S9PP Ti / S9P Ti
                • Zdeněk HruškaZ Offline
                  Zdeněk Hruška Bronze Member @slurpnik
                  @slurpnik I am not sure how it works on your watch but generally you should not have any backlight outside on the sun. MIP displays are readable without it. So it should not be an issue if the backlight doesn’t work outside on the sun. But maybe I don’t understand the issue🤔
                  • Mff73M Offline
                    Mff73 @slurpnik
                    @slurpnik
                    maybe it is time to let your watch be back for RMA
                    SSU (retired), SV1, SV2
                    Wife : S9PP
                    SA: Always the latest beta :)
                    Android + Galaxy S205G
                    Brad_OlwinB 1 Reply Last reply Reply Quote 1
                    • S Offline
                      slurpnik
                      @duffman19 and all - thank you! One last test: I went outside and recorded this short video, trying to see if this is polarization issue:
                      vertical-display.mp4
                      As you can see, there is a very narrow angle at which the screen is super readable on sunlight, and as soon as I rotate even slightly outside of that angle, it is no longer readable.
                      Do you think this is polarization issue with the watch itself and I need to send it for repair?
                      sartoricS D 2 Replies Last reply Reply Quote 1
                      • sartoricS Offline
                        sartoric Moderator @slurpnik
                        @slurpnik
                        are you sure you have no residue from the screen protector?
                        is there a shadow over it at the end ?
                        that said, it acts exactly like a screen seen through a polarised lens while rotating.
                        I would file an RMA
                        out of curiosity, where did you bought it ?
                        SVTS - 2.50.28
                        SSSWHR BARO Amber - 2.8.32
                        Samsung A5 2016 - Android 7.0
                        Suunto App Android 6.11.8 beta
                        • D Offline
                          duffman19 @slurpnik
                          Yes, I’m pretty convinced by your video that it’s a polarization issue with your specific watch. I’m by no means an expert in screen technology, but a quick search yielded the following image (MIP on right):
                          This comes from here, a company that manufactures MIPs. I have no idea if the Vertical’s screen is the same, but it’s probably a safe bet that it also has at least one polarizing layer. And, for some reason, the one on your watch is not set correctly.
                          Not sure how that would have passed Suunto’s quality control, but I’d get it back to them for repair. There’s no denying that there’s something wrong with your specific watch.
                          • Brad_OlwinB Offline
                            Brad_Olwin Moderator @Mff73
                            @Mff73 said in Suunto Vertical: Bug Collection:
                            @slurpnik
                            I agree, mine does not behave this way.
                            Vector/T6c/Vertical 2 Ti
                            • S Offline
                              slurpnik
                              Thank you @sartoric @duffman19 @Brad_Olwin @Mff73 @Todd-Danielczyk @Egika for support, I really appreciate your replies and contributions to this awesome community forum!
                              I will be sending the watch for repair back to Suunto.
                              @sartoric I bought the watch directly from suunto.com eshop and they shipped it from Finland.
                              ? S 2 Replies Last reply Reply Quote 1
                              • ? Offline
                                A Former User @slurpnik
                                @slurpnik Let us know how it goes.
                                • I Offline
                                  Iggge
                                  Since my Vertical don’t work as expected with Polar H10 chest belt I don’t use it anymore.
                                  However, this is the results from my Vertical (HR with no belt) Screenshot_20240504_155035_Suunto.jpg
                                  Vs another brand.
                                  Why can’t my Vertical that are alot more modern and cost 10x more show this correct?
                                  cosme.costaC 1 Reply Last reply Reply Quote 0
                                  • cosme.costaC Offline
                                    cosme.costa @Iggge
                                    @Iggge What doesn’t work with the Polar H10 and the SV? I’m using the Polar Verity Sense and it works as expected but I also have the Polar H10 and I can test something to see if I see the same.
                                    Regarding the two pictures, why are you sure that the second one is the correct one? What is the avg HR in the SV and max and min? I see diferent scales in both axis, have you tried to show only the HR graph?
                                    I 1 Reply Last reply Reply Quote 0
                                    • I Offline
                                      Iggge @cosme.costa
                                      @cosme-costa With the Polar H10 the belt disconnects to often, and show constant 80 BPM sometimes.
                                      I can’t know for sure, but have compered with charge 2, Samsung Galaxy Watch and garmin 245 Music. All three have almost the same data, but the Suunto does not.
                                        cosme.costa @Iggge
                                        @Iggge But have you tried the Polar H10 with the Garmin or any other compatible device? Could be that you have run out of battery in the belt, I have had this several times with the H10.
                                        SV is bigger, thicker and probably heavier that the other 3 devices that you have used, this gives an advantage related to OHR accuracy. Have you tried to wear it two fingers higher in the arm, tighter or switch it to the other arm?
                                        • mlakisM Offline
                                          mlakis Bronze Member
                                          Many here, me included, are using H10 without problems, so check your batteries on the H10 sensor.
                                          • I Offline
                                            Iggge @cosme.costa
                                            @cosme-costa I did use H10 without any problem. The problems started after November update.
                                            I have changed battery two times, and I have been using it with my other watches and it worked just fine.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
