    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 678.1k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Martin VrskaM Online
      Martin Vrska @lauser
      @trailcafe Hello. Lately I’ve had this error: the media player seems to be greyed out, music is playing, even the track titles are changing, but it’s not controllable with the watch. I’ve tried powering the watch off/on, doing a soft reset, removing and basically adding the “media control” option, but nothing helps. Does anyone have any idea how to fix this? This error appeared long after the last SW update.DSC_0508.JPG
      Suunto Vertical 2 - Arctic Gray - 2.56.18
      Suunto Vertical - Steel Black, Strap Canyon Orange - 2.37.34 - SOLD
      Suunto 9 Peak Pro - Titanium Sand - 2.22.60 - my wife
      Sony Xperia 10 III - Android 13
      Suunto App 6.11.8 beta
      • ? Offline
        A Former User @Martin Vrska
        @Martin-Vrska I have the same; where it does not allow you to control the media from the touch screen. It will also hang up or not switch between various media platforms (music, podcasts, etc.) that are both native and added to my Android phone.
        Martin VrskaM 1 Reply Last reply Reply Quote 1
          Martin Vrska @Guest
          @Todd-Danielczyk Thanks for your response. I just don’t understand why this is happening for no apparent reason - as we have already stated - I have been observing this for the past week.
          • ? Offline
            @Martin-Vrska I didn’t see it grey out on previous firmware but have seen it on 2.33.14.
            The switching from media players (in my case Oto Music, Podcast Republic on Android) has been there since I’ve owned the Vertical. That and the media countdown timer not refreshing when replaying a track is something I have also seen.
              Martin Vrska @Guest
              @Todd-Danielczyk Unfortunately - even the update to 2.33.16 beta and resetting the watch, but didn’t help.
              S 1 Reply Last reply Reply Quote 0
              • S Offline
                Shrek3k @Martin Vrska
                I am quite annoyed, as my Vertical crashed / froze in the map view in the middle of an activity, after 4,6km of planned short 6,5km-Oslo-city run.
                After a restart the run was synchronized … at least the part until the Vertical froze.
                What was active/activated:
                • the route
                • map view
                • external HR-monitor (Wahoo Tickr Fit … as usual)
                • Burner-App
                Anything special? Not really, usual weather, changed the size of map once (shortly afterwards it froze)!
                using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
                OS - Android 16/Pixel Pro 7
                isaziI babychaiB 2 Replies Last reply Reply Quote 0
                • thanasisT Offline
                  thanasis Bronze Member
                  The tones and vibration seem not correct . Setting the tones as to vibration the watch still rings on notifications
                  • isaziI Online
                    isazi Moderator @Shrek3k
                    @Shrek3k did you send logs after the event?
                    Blog: isazi's home
                    • thanasisT Offline
                      thanasis Bronze Member @thanasis
                      @thanasis
                      Today I observed the oHR while at rest to start increasing to 150+… while the actual Hr was around 80-82 (measured via a medical device)
                      I changed it to various positions without any success
                      I had to turn off the switch and the turn oHR measurements and the watch started 85-86 (normalish values )
                      Never have I observed such a strange behaviour before
                      • babychaiB Offline
                        babychai Silver Members @Shrek3k
                        @Shrek3k
                        happened to me twice this year during hiking activity. Froze in the map view. So i need to do soft reset. After synchronized the ascent and descent value in SA is show zero. I didn’t turn on any Suunto+
                        Suunto Vertical Titanium Solar Black
                        S̶u̶u̶n̶t̶o̶ ̶V̶e̶r̶t̶i̶c̶a̶l̶ ̶B̶l̶a̶c̶k̶ ̶R̶u̶b̶y̶ ̶(̶S̶/̶S̶)̶
                        S̶u̶u̶n̶t̶o̶ ̶V̶e̶r̶t̶i̶c̶a̶l̶ ̶A̶l̶l̶ ̶B̶l̶a̶c̶k̶
                        Suunto 9 Peak All Black
                        Suunto Spartan Trainer Wrist HR (Black)
                        • S Offline
                          Shrek3k @isazi
                          @isazi unfortunately not. As I have no fully accessible computer with me I could not create the log-file … I will check when I am at home today what I can export before doing the next activity tonight. Depending on the result I will send the log and the fit-file to support.
                          isaziI 1 Reply Last reply Reply Quote 0
                          • isaziI Online
                            @Shrek3k logs are sent via the app, not a computer. But it is probably too late at this point, the log file is overwritten more or less every 24 hours as far as I know.
                            Blog: isazi's home
                            • S Offline
                              Shrek3k @isazi
                              @isazi OK. I searched for a description how to create log-files, as I could not find the option in the app, and found a description in the lounge, which mentioned the computer. I will check and search, and will be prepared the next time … (Although another crash might create more intense reactions 😇 )
                              • isaziI Online
                                @Shrek3k currently sending logs is in “Settings”, then all way to the bottom of that screen.
                                Blog: isazi's home
                                M 1 Reply Last reply Reply Quote 0
                                • M Offline
                                  maszop Bronze Member @isazi
                                  @isazi Given the number of software problems, the option to send logs should be easier and more intuitive.
                                  Or even an official bug tracking system where you can report them and see the progress of work on solving them.
                                  EgikaE isaziI 2 Replies Last reply Reply Quote -2
                                  • EgikaE Online
                                    Egika Platinum Member @maszop
                                    @maszop bug tracking in Suunto is not a platform open to the public. It would just explode from the many users that THINK they found a bug but their device but it’s actually working as designed.
                                    E 1 Reply Last reply Reply Quote 1
                                    • isaziI Online
                                      isazi Moderator @maszop
                                      @maszop as already specified elsewhere in the forum, that function is only there to be used when requested by support, not on your own, so it should not be too prominent in the interface.
                                      Because some people here can fill in bugs for Suunto we sometime requests users to do it (if they want) and tell them how to do it. But this is just voluntary, we are not support.
                                      Blog: isazi's home
                                      • E Offline
                                        Elipsus Gold Members @Egika
                                        @Egika while I definitely agree, that its good that tickets are not open to all, I still think the process is much harder that it needs to be (and I speak as a QA engineer…)
                                        • the fact that we have absolutely no control (we can’t even see, from a privacy standpoint that’s a big no-no) over what is sent, i already mentioned it elsewhere, but just providing a sample, or allowing to store the file locally would be enough
                                        • we can’t add remarks, that would GREATLY help the people receiving, for example, i could say “the problem XXX happened at precisely 8h31am, when the watch was supposed to vibrate for the 2nd km of the run”
                                        • we don’t know how “deep/long” a log is, we are very, very, very much in the dark, even when asked by support.
                                        It needs to be better, even for me its too involved and convoluted
                                        EgikaE 1 Reply Last reply Reply Quote 1
                                        • EgikaE Online
                                          Egika Platinum Member @Elipsus
                                          @Elipsus as the bug reporting process is not open to the public, all the things you mention are not needed for the public.
                                          If you don’t feel like you should press that “send logs” button, just don’t do it. No obligation.
                                          1 Reply Last reply Reply Quote -1
                                          • S Offline
                                            slurpnik @slurpnik
                                            @slurpnik said in Suunto Vertical: Bug Collection:
                                            Thank you @sartoric @duffman19 @Brad_Olwin @Mff73 @Todd-Danielczyk @Egika for support, I really appreciate your replies and contributions to this awesome community forum!
                                            I will be sending the watch for repair back to Suunto.
                                            @sartoric I bought the watch directly from suunto.com eshop and they shipped it from Finland.
                                            A quick update: I have sent the watch back to Suunto on May 4th and it was received the next day. Then it waited in received status for almost a month. Since I have trip to Mont Blanc coming up, I decided to talk to support - they were helpful and said they will escalate the case with technician. The watch was repaired AND shipped the very next morning, and I received it the next day - I was impressed!
                                            The watch seems to be repaired with new display, and the issue with unreadable display seems solved when I do sports outside. Curiously, the behavior of backlight changed and I suspect it’s due to light sensor being replaced with the display too: before the repair, backlight would never turn on outside. After the repair, I had backlight turn on upon raising hand when running during day in the forest, or sometimes even when overcast with clouds. In these lower light conditions, the watch is much more eager to use backlight than it was. I think some other user had issues on this forum as well (can’t remember the thread now).
                                            A quick side note: apart from the long wait (long backlog of service requests?), the whole service process was super smooth - quick, efficient, clear communication and very customer friendly. I was impressed and mentioning it here for other’s benefit. I know we are sometimes unimpressed with answers from support telling us to wipe and reset watch even for known bugs, but actual servicing of the watch was really good in my case.
                                            Thank you again for advice!
                                            Watch: Suunto Vertical (titanium solar canyon)
                                            ? 1 Reply Last reply Reply Quote 2
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
