    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 771.5k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Y Offline
      Yonialony
      Good morning everyone
      I would appreciate your assistance…
      In the last two weeks, the data on the cumulative climb (ascent) that there is in the run, which is illogically high for the terrain itself, identical routes that I ran with a Garmin Phoenix 6 or with a friend who ran with Coros, showed drastically different data (for example, running with 150 meters of cumulative height, the Suunto showed me 1100 meters…) I also did an automatic reset for the barometer and the altitude sensors Do you know or have met him?
      Do you know how to handle it?
      • jjpazJ Online
        jjpaz Bronze Member @Sergei Ladeishchikov
        @Sergei-Ladeishchikov Below 20% battery level vibration level is lowered, I have noticed that behavior in my Suunto Vertical.
        It’s a bit annoying because I can train several days with battery below 20% before recharge it.
        I could understand a “battery saving mode” below 10% or 5% battery level but, below 20% with the new battery lifes??
        Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
        Sergei LadeishchikovS 1 Reply Last reply Reply Quote 0
        • Sergei LadeishchikovS Offline
          Sergei Ladeishchikov Bronze Member @jjpaz
          @jjpaz I also noticed a decrease in vibration intensity of about 13%, it seems like a barely noticeable vibration.
          kriskusK 1 Reply Last reply Reply Quote 0
          • kriskusK Offline
            kriskus Bronze Member @Sergei Ladeishchikov
            @Sergei-Ladeishchikov Seems like some early-stage energy saving mode which should normally be fully triggered at 10%. I have also noticed this (no vibrations) at around 20%
              Sergei Ladeishchikov Bronze Member @kriskus
              @kriskus If this is some kind of power saving mode, it definitely does not affect the backlight, notifications and sounds.
              isaziI 1 Reply Last reply Reply Quote 0
              • isaziI Offline
                isazi Moderator @Sergei Ladeishchikov
                @Sergei-Ladeishchikov as far as I know the vibration is adaptive and less strong as the battery goes down. I agree that for a device like the Vertical 20% is too early to stop vibrating, I will open a ticket with Suunto and see if they can change the threshold.
                Blog: isazi's home
                Sergei LadeishchikovS 1 Reply Last reply Reply Quote 2
                  Sergei Ladeishchikov Bronze Member @isazi
                  @isazi The intensity of vibration, in my opinion, remains constant as the discharge progresses, except for the moment before it disappears.
                  • EgikaE Offline
                    Egika Platinum Member @Yonialony
                    @Yonialony see Q6: https://forum.suunto.com/topic/9960/more-faq?_=1718105302645
                    • S Offline
                      suuntastic Bronze Member
                      Sorry, didn‘t scroll through whole thread. Is there a know issue with sudden touchscreen lag (not usable anymore) / unresponsiveness? Will it be corrected via SW update or broken touchscreen? Thanks?
                      • isaziI Offline
                        isazi Moderator @suuntastic
                        @suuntastic unresponsive touchscreen on Vertical should be fixed with next update I believe.
                        Blog: isazi's home
                        S 1 Reply Last reply Reply Quote 5
                        • S Offline
                          suuntastic Bronze Member @isazi
                          @isazi thanks! 🙏
                          • L Offline
                            Likarnik Gold Members
                            I had a very replenishing shower on Saturday after a 100k trail race 😄 resources went high, and after 10,5h sleep I had 99%. It was probably too late so send logs when I finally saw that.
                            • thanasisT Do not disturb
                              thanasis Bronze Member
                              I trie the indoor swimming today . Well it seems it’s way off when calculating the distance in the pool. In a 25 m pool it gave almost random numbers :
                              On a freestyle mode once it gave me 4times the distance (so all the metrics are completely off as it indictaing that I am probably a world record type of swimmer - while I am not ) and the other time just 2… (so still probably a very competitive athlete that should be ok at the Olympics this year 👊 )
                              I think it needs some adjustment and I hope the next firmware fixed it as it really does not offer anything to record such a unstable and random numbers
                              ManueleM 1 Reply Last reply Reply Quote 0
                              • ManueleM Offline
                                Manuele @thanasis
                                @thanasis Hi!
                                I have used the indoor swimming feature many times (with a 7, a 9, and Vertical), and in my experience, I found it pretty reliable, maybe few times was overestimating the lengths but nothing major. (The 7 was the less precise definitely)
                                The timing was all right, and the style recognition was a bit off sometimes, but I think that is quite difficult to catch precisely.
                                I think that the algorithm is picking a sudden change of direction as the end of the pool, so maybe that is playing a role, and sensors may be tricked by some movements.
                                Is this helpful?
                                • helgonet12H Offline
                                  helgonet12
                                  Hi all. Really excited about the new software version that is coming soon. So many good stuff makes it hard to wait. Great job Suunto.
                                  thanasisT 1 Reply Last reply Reply Quote 1
                                    thanasis Bronze Member @helgonet12
                                    @helgonet12 how do you know of the details ? Anything released ?
                                    kriskusK helgonet12H 2 Replies Last reply Reply Quote 0
                                    • kriskusK Offline
                                      kriskus Bronze Member @thanasis
                                      @thanasis Well, the new Race S was just revealed today. And Vertical gets the same features.
                                        helgonet12 @thanasis
                                        @thanasis as @kriskus wrote i assume the same 🙂
                                          the usual thing i do when wanting to leave the watch and wear something else is
                                          : turn on the power saving (which also turns off the oHR sensor), turn upside down (the screen on the table’s side ) and leave it in a closet.
                                          i did the same since last night but I also enabled the airplane mode (so both switches were on) and the watch today was with 33% of battery from 78% …
                                          i don’t know what the issue is but i think it is a bug
                                          • I Offline
                                            Iggge
                                            Since the new update (2.35.34) I don’t get any notifications on the watch at all.
                                            Other that that this is a absolutely great update! All kudos to Suunto for this new software update.
                                            sartoricS 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
