    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 780.6k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • I Offline
      Iggge
      Did give my Vertical a new chance the last 5 days as my daily, am not fully satisfied with the results.
      Sleep;
      During the last days the sleep analysis have been 2 days of 5 days way off (4 hours instead of 7+)
      Steps;
      My steps are ridiculous low on Suunto. Get to 10.000 steps is really hard and usually only get to around 6000, at the same time my watch 7 shows over 10.000 and phone low 11.000.
      The data where so off with steps and the irregular sleep analysis so I started to wear my watch 7 again at the same time to be able to do a comparison.
      I still use the Vertical During training because that is where it really shines!
      But as a daily health watch Suunto have some work to do and I hope this get some attention from devs
      JonasLarssonJ stromdiddilyS 2 Replies Last reply Reply Quote 1
      • JonasLarssonJ Offline
        JonasLarsson @Iggge
        @Iggge said in Suunto Vertical: Bug Collection:
        Sleep;
        Steps;
        Same problem here. Sleep is wrong and steps are to low. But what’s most confusing is that sleep used to be correct.
        Vertical 2
        • darxmurfD Offline
          darxmurf Platinum Member
          Quick update about the HR sensor issue. I disabled the daily HR stats and I’m not losing the sensor anymore when leaving the watch on a flat surface.
          https://www.instagram.com/darxmurf/ - https://www.instagram.com/omch.swiss/
          • stromdiddilyS Offline
            stromdiddily Gold Members @Iggge
            Sleep;
            Steps;
            They tweaked the steps algo as it was definitely over counting prior to the latest firmware but I think they over corrected a bit. There has been a lot of feedback on this so hopefully they’ll tweak it a bit further.
            As for sleep, gotta be sure your resting heart rate value is set correctly. If it is, then I’d probably reach out to support.
            Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
            User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
            I 1 Reply Last reply Reply Quote 0
            • I Offline
              Iggge @stromdiddily
              @stromdiddily they sure did a tweak with the steps.
              Today is one of those days when my steps are ridiculous far from the truth.
              My Suunto is at 4500.
              My phone and watch 7 16700.
              The Suunto does count steps very good during training, but on a day to day basis it sometimes just stops and it feel like it have a hard time all other activity besides training.
              When I for example have been in a chair and after a while leave it it sometimes does not recognise that I am moving, and won’t count any steps at all. This is happening several times every day
              • mlakisM Offline
                mlakis Bronze Member
                Using latest firmware, started a hike with all the default options (Performance GPS, Weather app, OHR, no sensors etc), and a POI for navigation.
                Although GPS was working and I was seeing the past track getting recorded on the map, no distance, speed etc was getting recorded.
                The same applied when I synced it to the app.
                On the way back, all same settings, a new POI etc, everything was alright.
                • darxmurfD Offline
                  It looks like the battery drain issue stopped since I disabled the daily HR stats.
                  • ? Offline
                    A Former User @darxmurf
                    @darxmurf Did you turn off the 24/7 HR tracking under activity menu?
                    darxmurfD 1 Reply Last reply Reply Quote 0
                    • darxmurfD Offline
                      darxmurf Platinum Member @Guest
                      @obhikkhu yes
                      • ? Offline
                        @darxmurf said in Suunto Vertical: Bug Collection:
                        @obhikkhu yes
                        Thanks for the tip. Any idea if this has an effect on sleep tracking and HRV?
                        MarynM 1 Reply Last reply Reply Quote 0
                        • MarynM Offline
                          Maryn Silver Members @Guest
                          @obhikkhu it will stop to track HRV
                          Suunto Vertical, Suunto Race, Edge 530, Vantage V, Suunto Wings, Polar H10&Verity Sense
                          • mlakisM Offline
                            Another small finding .
                            If you set a timer and while it’s entering the last 10 seconds you are in the exercise selection menu, you won’t get a last 10 second countdown screen, neither any sound or vibration, even when the countdown reaches zero and you have navigated already to home screen or any other screen.
                            • Tami999T Online
                              Tami999 Silver Members
                              I have created new topic but saw “bug collection” one, so i post screen to full my thread.
                              https://forum.suunto.com/topic/11470/weather-widget-stuck-on-main-screen
                              My SV don’t sync weather widget on main screen., it freezes. Weather page seems update 100% true, but on main screen temperature freezes for hours (I can sync app few times and nothing changes, than after some times it changes on main screen to freeze again for few hours)
                              • thailonT Offline
                                thailon Bronze Member
                                @isazi : SW update 2.37.34 Q3 Installed. I saw several watch faces marked as installed, but only default one was in watch (Vertical). I uninstalled and installed again, but still the default one was in watches (and 0/9 shown in SuuntoApp Watch faces section). I had to uninstall them all again, KILL the app (iOS) and install it again. It was ok then, I have installed faces in watches and counter shows correct installed number).
                                T3c, Quest, Ambit3 Peak, 9PP, Vertical
                                isaziI 1 Reply Last reply Reply Quote 1
                                • isaziI Online
                                  isazi Moderator @thailon
                                  @thailon the first sync takes time, after update the watch needs to check and/or reload all your S+ apps, guides, watch faces. It should be fine from now on.
                                  Blog: isazi's home
                                  1 Reply Last reply Reply Quote 3
                                  • M Offline
                                    matus69
                                    update 2.37.34
                                    • map is in grey mode
                                    • watch face also without colors
                                    restart did not help
                                    please fix this
                                    Mff73M 1 Reply Last reply Reply Quote 0
                                    • Mff73M Offline
                                      Mff73 @matus69
                                      @matus69 said in Suunto Vertical: Bug Collection:
                                      update 2.37.34
                                      check the map option if not setup to high contrast
                                      SSU (retired), SV1, SV2
                                      Wife : S9PP
                                      SA: Always the latest beta :)
                                      Android + Galaxy S205G
                                      • M Offline
                                        matus69 @Mff73
                                        @Mff73 no, it is on Outdoor.
                                        However I changed to all possible modes, but it is remains grey all the time
                                        • Mff73M Offline
                                          Mff73 @matus69
                                          @matus69
                                          Strange. Either delete the map and redownload it or wait for more expert advise.
                                          Wife : S9PP
                                          • M Offline
                                            matus69
                                            I apologize, after all it is my mistake. Somehow the map got to full zoom and as I was in residential area, there were only buildings, no forest, no main road…that is why all appeared grey
                                            After zooming out I see it in color.
                                            So sorry for confusion…
                                            Fenr1rF 1 Reply Last reply Reply Quote 5
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
