    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Running in a tunnel caused issues in the total distance computation
    59 Posts 11 Posters 12.9k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      ddausw
      the same as before with my watch. the tunnel length is counted twice. in wuppertal there are many tunnels on my running routes. the evaluation is hardly useful.
      that seems to be a software bug and could be eliminated well ๐Ÿคจ
        Dimitrios Kanellopoulos Community Manager
        Hi all, we might have a fix for this on the next release. Hold on there.
        Creator of quantified-self.io โ€” a next gen training dashboard with MCP access, cross-service activity and route sync
        L 1 Reply Last reply Reply Quote 5
        • L Offline
          Likarnik Gold Members @Dimitrios Kanellopoulos
          @dimitrios-kanellopoulos Looks good after two tests with new firmware, thanks๐Ÿ‘
          L 1 Reply Last reply Reply Quote 4
          • D Offline
            ddausw
            The update does not result in a major improvement. Some tunnel distances are calculated correctly. Other tunnel distances are not evaluated correctly. Does it depend on tunnel length and GPS accuracy? I will verify it.
            Is it possible to downgrade to firmware 2.13.18? Everything worked fine there.
            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
              Dimitrios Kanellopoulos Community Manager @ddausw
              @ddausw please dont confuse posts. This was a bug fix for double distance.
              Distance in tunnels can vary due to calibration and other factors
              • L Offline
                Likarnik Gold Members @Likarnik
                Hm, looks like my tunnel is stubborn one ๐Ÿ™‚ Yesterday I ran my route again and bug has returned ๐Ÿ˜ฎ It was always 5,9km-6km, then bug arrived and route expanded to almost 6,5km, fix was at 6,2km (not perfect, but ok) and now again at 6,44km. Tunnel is around 230m in length, so running out and back 0,5km is added. Iโ€™ll test again and send logsโ€ฆ
                • tuxellaT Offline
                  tuxella Bronze Member
                  I did another test this morning (first time since a couple of months and firmware releases), and the tunnel was counted twice again ๐Ÿ˜ข
                  Firmware version: 2.20.30
                  You can find the track here: https://maps.suunto.com/move/thomas430851/6267d46cecb30d719c92f7d0
                  • Brad_OlwinB Offline
                    Brad_Olwin Moderator @tuxella
                    @tuxella Not clear on the issue here, I looked at your track. You did an out and back and went through the tunnel 2 times. correct?
                    Vector/T6c/Vertical 2 Ti
                    tuxellaT 1 Reply Last reply Reply Quote 0
                    • tuxellaT Offline
                      tuxella Bronze Member @Brad_Olwin
                      @brad_olwin Yes, I went past the tunnel for ~250m before going back into the tunnel.
                      I did the same thing and illustrated it here: https://forum.suunto.com/post/80538
                      • D Offline
                        ddausw
                        After the firmware update to 2.20.30, the tunnel distances are calculated incorrectly. It looks like the old bug (double tunnel distance) has crept back in.
                        Surprisingly, the tunnel distances are calculated correctly with the Bike setting.
                        My suspicion is that the error is something related to FusedSpeed.
                        H 1 Reply Last reply Reply Quote 2
                        • L Likarnik referenced this topic on
                        • H Offline
                          halajos Bronze Member @ddausw
                          This bug is definitely there in FW 2.20.30, confirmed by my unusual โ€˜cave runโ€™, as I described here: https://forum.suunto.com/post/107721
                          @Dimitrios-Kanellopoulos can my data help to fix it?
                          • tuxellaT Offline
                            I ran into the same issue today, in a shorter tunnel.
                            I was with a friend running with a suunto 9 peak as well, and she had the same issue.
                            Links to our activities:
                            https://maps.suunto.com/move/thomas430851/63302284911a6a6cd8036306
                            https://maps.suunto.com/move/oliviacolle/63302566d56fb73077f414e4
                            Letโ€™s hope the next firmware fixes this.
                            isaziI 1 Reply Last reply Reply Quote 1
                            • isaziI Offline
                              isazi Moderator @tuxella
                              @tuxella thanks Iโ€™ll report this today, hope that from your activities they can fix it.
                              Blog: isazi's home
                              H 1 Reply Last reply Reply Quote 1
                              • H Offline
                                halajos Bronze Member @isazi
                                @isazi I have an example with 2km in a cave counted twice, hopefully it can also help: https://maps.suunto.com/move/halajos/63132dce955dae0f3a247721
                                • isaziI Offline
                                  isazi Moderator @halajos
                                  @halajos what I can share is that the developers at Suunto are looking into this and plan to fix the issue. Unfortunately the next firmware release is already closed (and it is very close), so this will have to wait until the one after. I will keep you posted with information, if I get updates.
                                  Blog: isazi's home
                                  • J Offline
                                    Jaka Vogrincic Bizjak
                                    Hello,
                                    It is something new about tunnel issue. I have a short tunnel (280 m) but the same issue. In the tunnel my pace on S9 is like Kipchoge ๐Ÿ™‚
                                    When the new version it will be released.
                                    Thanks, Jaka.
                                    • G Offline
                                      grillaume
                                      Hello, any news about the distance counted twice ? ๐Ÿ™‚ I can report the same problem with my Suunto 9, v2.23.24โ€ฆ in the same tunnel as the previous messages in Paris
                                      isaziI J 2 Replies Last reply Reply Quote 1
                                      • isaziI Offline
                                        isazi Moderator @grillaume
                                        @grillaume it is fixed with next software update, available very soon if nothing happens.
                                        Blog: isazi's home
                                        • J Offline
                                          Jaka Vogrincic Bizjak @grillaume
                                          @grillaume now with the last update the problem is solved. I tested it yesterday in a tunnel. All OK with distance and pace.
                                          1 Reply Last reply Reply Quote 3
                                          With your input, this post could be even better ๐Ÿ’—
                                          Register Login
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
