    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 2.50.28 hot-fix Q4
    Scheduled Pinned Locked Moved Watches
    112 Posts 51 Posters 22.4k Views 50 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • E Offline
      Elipsus Gold Members @Elipsus
      Answearing to myself, my watch did turn off again this night, so it might not be related to alarms (none was active).
      I will hard reset it
      • Milan ŠádekM Offline
        Milan Šádek Bronze Member @Geoffwilli
        @Geoffwilli with this latest fw I have a stable daily drain of around 10% including 30 to 60 mins of GPS activity per day - SVTiSolar which I received as a replacement last September. I have a paired Polar H10, I suspect this may be the reason.
        G 1 Reply Last reply Reply Quote 0
        • Ilya Zherikov 0I Offline
          Ilya Zherikov 0
          My Suunto Race battery seems to be draining much faster than on the previous firmware, and it’s clearly not just me 😕
          • G Offline
            Geoffwilli @Milan Šádek
            @Milan-Šádek That seems a reasonable amount of drain per day. I’m experiencing around 35% drain every 24hrs with no activities on my race, so charging every other day. I have no faith in using the watch for anything over 50mile races. This is silly, as I purchased the watch for 100 miles races etc.
            Milan ŠádekM 1 Reply Last reply Reply Quote 0
            • TieutieuT Offline
              Tieutieu Platinum Member
              My race S also drain faster in daily use, I find myself to recharge it more often (1 day earlier ?) than before.
              Suunto’s devices at home :
              Vertical titanium solar
              Suunto Race S
              S9pp titanium sand
              Suunto Wing & Spark
              S9B titanium Ambassador edition, A3P, X6
                @Geoffwilli with my old unit I’d get 6–8% drain per day with an hour of GPS (sometimes even below 6%). I even remember finishing a 50km race and the watch still being at 23% ten days later.
                This replacement watch started off okay at around 6–7.5% on older firmware, but now it’s jumped to 10%+ daily. It’s a huge step backward and honestly pretty frustrating. Is anyone else seeing this jump after the latest update?
                G surfboomerangS Fenr1rF 3 Replies Last reply Reply Quote 2
                • G Offline
                  gkaempfer Bronze Member @Milan Šádek
                  @Milan-Šádek I don’t know which watch you have but if it’s a Race S (9 days with HR, without GPS => 11%/day) or Race 1 (13 days with HR, without GPS ==> 7-8%/day) then I think you are getting what you should expect (assuming you are NOT using AOD which reduces battery life further). No?
                  With my Vertical 2, latest firmware (2.50.28), I am getting 14 days with 25 hours of GPS (running, cycling) which is exactly what the V2 spec implies (21 days with HR, without GPS => 5%/day and 65 hours of best GPS => 1.5%/hour extra for GPS).
                  I don’t use external BT connectivity except for the Android App (on Android 16). You may get worse drain if you use external HR belts etc.
                  • B Offline
                    Benjamin 0 @Geoffwilli
                    I don’t know were you live but suunto repaired mine without any issue (race s - 1y1/2 old). In FR we have a 2y waranty.
                    G G 2 Replies Last reply Reply Quote 0
                      Milan Šádek Bronze Member @gkaempfer
                      @gkaempfer as mentioned earlier, I have Vertical 1 Ti Solar with Polar H10. So no AMOLED display.
                      S 1 Reply Last reply Reply Quote 0
                      • S Offline
                        Stavrogin @Milan Šádek
                        @Milan-Šádek Have you turned off the BT discovery? I feel like that helped me a little bit.
                        Suunto Vertical, Race, Race 2, Race S and Run. Rocking the Vertical 2 Titanium at the moment.
                        Garmin: Fenix 7X, Epix Pro 51mm, Forerunner 265.
                        Coros: Pace Pro, Apex 4
                        • 2 Offline
                          2b2bff Silver Members
                          Random Suunto bug hit my Race S yesterday. Put the Watch on the charger, dismissed some notifications and reseated it to get the charging screen. A couple of seconds later the Suunto logo greated me as the watch rebooted itself… Reliablity, man… 🤷
                          Race S
                          • surfboomerangS Offline
                            surfboomerang @Milan Šádek
                            @Milan-Šádek said in Suunto 2.50.28 hot-fix Q4:
                            I have the Vertical 1 Ti solar as well and paired with a Polar H9 but I don’t see this kind of battery drain. I see around 3% per day (no 24/7 HR and sleep)
                            Suunto Vertical Titanium Solar
                            OnePlus Nord 4
                              Milan Šádek Bronze Member @surfboomerang
                              @surfboomerang good hint, thanks. I will turn it off before charging to have a better idea about its real effect on the discharge.
                                Milan Šádek Bronze Member @Milan Šádek
                                I wanted to refer https://forum.suunto.com/post/185015
                                • Fenr1rF Offline
                                  Fenr1r @Milan Šádek
                                  Similar proportional jump on my SV1 after 2.50.26.
                                  • G Offline
                                    Geoffwilli @Benjamin 0
                                    @Benjamin-0 Hi Benjamin. Im in the uk, which i think is only a 1 year battery warranty. My issue is that the watch has failed and is not fit for purpose. If suunto don’t respond then i’m considering taking them to court under the Consumer Rights Act 2015.
                                    They have already offered my a 30% reduction on a replacement watch, but why should spend hundreds of pounds to get the same watch thats failed me!?
                                    Mads Hintz-MadsenM B 2 Replies Last reply Reply Quote 0
                                    • Mads Hintz-MadsenM Offline
                                      Mads Hintz-Madsen Silver Members @Geoffwilli
                                      @Geoffwilli have you tried a hard reset in case you for some reason have ended up in a situation where the watch can’t enter power saving states?
                                      I know it is no fun to do a hard reset but maybe worth trying instead of throwing the watch in the bin.
                                      • B Offline
                                        @Geoffwilli I can understand since I’ve had the same issue twice, probably there is a design issue on the battery. I don’t know if I will have battery drain again but now this is repaired and with the new HR algorithm (previous was failling measurement all the time during activites on me) I’m quite happy with my watch.
                                        • G Offline
                                          Geoffwilli @Mads Hintz-Madsen
                                          @Mads-Hintz-Madsen Hi, yes i’ve tried all of the practical suggestions to help ‘regain’ the battery how it was. Nothin has worked unfortunately. This is the first time i’ve had an issue with a suunto watch, previously had a suunto trainer, and then suunto 9 Baro. I’m awaiting to hear back from suunto to see if they can fix the watch, as you say you don’t want to just put it in the bin!
                                          • 2 Offline
                                            It happened again: My Race S completely stopped tracking anything some time after setting DND mode until I switched off DND again. Same thing like I wrote a couple of weeks ago here.
                                            No HR, no Resources, no Sleep… I didn’t do anything different than on the days it worked…
                                            Race S
                                            herlasH 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
