    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 2.50.28 hot-fix Q4
    Scheduled Pinned Locked Moved Watches
    101 Posts 47 Posters 13.9k Views 45 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • GiPFELKiNDG Offline
      GiPFELKiND Silver Members @GiPFELKiND
      Press the blue (i) button at your pace in the App in both training and you see if you have Others zones there, if yes your custom pace zones are deleted and you have to save your “older” zones new
      If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
      BastienhereB 1 Reply Last reply Reply Quote 1
      • mich hellerM Offline
        mich heller
        one more thing I noticed after this update - sleep summary is working again 🙂 👏
        Race 2 titanium + Wing 2 | 9 Baro titanium | Ambit3 Peak
        helgonet12H HighlandsH 2 Replies Last reply Reply Quote 0
        • Inge NallssonI Offline
          Inge Nallsson @Bastienhere
          @Bastienhere said in Suunto 2.50.28 hot-fix Q4:
          Before this update it was a nice smooth curve relatively mirroring my speed curve
          But… That’s just the Suunto App presentation, not FW related. And the ‘smooth’ Pace curve in relation to Speed is due to a silly left side Pace graph going from 04:36/km to 46:17/km! You can hardly see the real variations there. The top image example you give has discernable pace variations between the 05:32/km and 07:00 extremes. Using 20.0 and 0.0 km/h for the right side Speed graph is not how I would present it, but still, all that is an App issue.
          Suunto Race S
          BastienhereB 1 Reply Last reply Reply Quote 2
          • N Offline
            nseslija Bronze Member @duffman19
            @duffman19 Unfortunately you are right, the bug is still there.
            Ambit 2S
            Ambit 3 Peak
            Suunto 9 baro
            Suunto Vertical Ti Solar
            • BastienhereB Offline
              Bastienhere Bronze Member @Inge Nallsson
              @Inge-Nallsson you’re making some fair points although the places where my pace dipped from 04:36/km to 46:17/km (and the others in the graph) was when I was stopping for traffic lights.
              It’s just very inconsistent in the way it represents pace now, almost like I’m running like a drunk man lol. And to be fair I strongly think this is what is affecting my VO2Max readings.
                Bastienhere Bronze Member @GiPFELKiND
                @GiPFELKiND hmm I checked my latest run and another back in December and the pace zones are the same
                • L Offline
                  Likarnik Gold Members
                  Am I the only one that has problems after this update? First time for me. Vertical1. Yesterday I was sitting at the desk and noticed that backlight is on and watch is in settings menu. Touch and buttons were not working, so I performed 12s reset. Later that day I wanted to check before my run if my zones were still ok and I couldn’t enter settings. First menu was ok, but then when I went to training, watch went back to watchface. I tried a couple of times and then went for a run. At night I woke up and the watch was again lit up and in settings menu, unresponsible. I performed soft reset and went to sleep. But the watch did not wake up. Now it looks like dead, it sits on charger but nothing happens. No button press is waking it up. Is there some special combinaton to wake it up?
                  HighlandsH 1 Reply Last reply Reply Quote 0
                  • helgonet12H Offline
                    helgonet12 @mich heller
                    @mich-heller for me it was the first time sleep and sleep summary didn’t work on this latest software. I did a soft reset and the sleep stats came but not summary
                    • HighlandsH Offline
                      Highlands @mich heller
                      @mich-heller For me the morning report reappeared out of the blue 1-2 days before my V2 got updated to the latest stable software.
                      SV2&SV1
                        Highlands @Likarnik
                        *@Likarnik
                        The issue you’re describing—freezing in settings, unresponsive buttons/touch, appearing “dead” or blank after soft resets and while on the charger—is a known recurring problem with the Suunto Vertical (original model), especially around software updates like the recent 2.50.26 staged rollout that started January 7, 2026 (Q4 2025 firmware). It often ties into deep freezes, partial boot failures, or battery/charging glitches post-update or after repeated resets. Many users report similar sequences: backlight stuck on, menu lockups, then blank/unresponsive screen that doesn’t wake easily.
                        You’re not alone; identical symptoms appear in Suunto forums, Reddit, and Facebook groups from 2023 through 2026, including after charging or resets.
                        Step-by-Step Troubleshooting to Try Right Now (Escalating Order)
                        Start with the charger plugged into a strong wall adapter (5V/1A+ recommended, not a weak laptop USB port). Clean contacts if needed. Leave it attached undisturbed for at least 30–60 minutes initially—deeply discharged or frozen watches can take 20+ minutes just to show any sign of life.
                        1. Extended upper-button hold (most successful for blank/unresponsive cases)
                          While on the charger:
                          Press and hold the upper button (topmost on the right side) for at least 20–60 seconds continuously.
                          • Many users say it reboots after ~12 seconds but keep holding longer (up to 60s) to force a full recovery from deep freeze or “service mode.”
                          • Release, wait 10–30 seconds, and see if the screen lights up, vibrates, or shows the logo/charging indicator. Repeat 3–5 times if no response.
                        2. Alternative button combos while charging
                          • Hold upper + middle buttons together for 15–20 seconds.
                          • Hold all three right-side buttons simultaneously for 15–30 seconds.
                            These have revived “dead” screens for some after normal 12s reset failed.
                        3. Charge longer + periodic attempts
                          Leave it charging undisturbed for 2–4 hours total (even overnight if possible). Every 30–60 minutes, try the extended upper-button hold again. Some watches enter a recovery state only after sustained power.
                        4. If it wakes up at any point
                          • Immediately do a factory reset via watch menu: Settings → General → Reset settings → confirm (erases everything unsynced—try to sync to app first if it connects).
                          • Re-pair with the Suunto app, check for any pending updates (this firmware 2.50.26 includes bug fixes for crashes/button issues), and test thoroughly.
                          • Avoid rapid on/off or repeated soft resets right away to prevent re-triggering the freeze.
                        If Nothing Works After Several Hours/Attempts
                        • This points to a deeper software lock (sometimes called “service mode” with blank or partial screen) or rare hardware/battery fault.
                        • Contact Suunto Support right away: Use the in-app chat (if app sees the watch), their website support form, or email/phone your regional service center. Provide:
                          • Serial number (on box or under watch).
                          • Proof of purchase (for warranty—Vertical 1 is typically 2 years).
                          • Describe symptoms + what you’ve tried (including firmware version if known).
                            Many users in similar “bricked after update/reset” situations got warranty replacements or repairs quickly.
                        No special “secret” recovery combination beyond the above is documented for the Vertical. Avoid draining it fully on purpose right now (as some battery-drain threads suggest), since it’s already unresponsive.
                        Try the extended hold first—it’s revived quite a few “dead” Verticals. Update me on what happens after attempting these!*
                        So sorry about your issue. Got this response from Grok. Hopefully, it helps you solve the problem.
                        SV2&SV1
                        L 2 Replies Last reply Reply Quote 3
                        • L Offline
                          Likarnik Gold Members @Highlands
                          @Highlands thanks, so far no luck.
                          • B Offline
                            Benjamin 0 @Dimitrios Kanellopoulos
                            I own a race Myself and I had to send it back 2 times because an import battery drain issue (whiching drifting over the time). @geoffwilli I think you are facing the same Issue, not sure it is SW…
                            G 1 Reply Last reply Reply Quote 0
                            • L Offline
                              @Highlands heh, watch just magicaly woke up after 3 days, it’s like Jesus😂 too bad I already ordered coros…
                              HighlandsH 1 Reply Last reply Reply Quote 1
                                Highlands @Likarnik
                                @Likarnik
                                I’m really glad the watch has “come back to life” — fingers crossed it’s just a small hiccup and nothing more serious.
                                Which Coros model did you go for?
                                Whichever of the two you end up keeping, I wish you lots of great adventures with it! 😊
                                SV2&SV1
                                L 1 Reply Last reply Reply Quote 1
                                • L Offline
                                  @Highlands thanks, I ordered apex 4 and dura combo as I was already looking for a bike computer
                                  • Horizontal_2H Horizontal_2 referenced this topic on
                                  • E Online
                                    Elipsus Silver Members
                                    For the second time since i have the 2.50.xx version, my watch stopped recording HR (the HR sensor light doesn’t turn on), only turning it off and on again fixed it.
                                    This bug was present 1ish year ago and was supposedly fixed, I think there’s a regression here ^^
                                    • E Online
                                      And today I wanted to get up early for a morning running sesh.
                                      I set up my watch alarm to wake up at 6:10AM.
                                      I woke up to my wife alarm at 6:50AM
                                      my watch was “off” (despite being well charged).
                                      I sent the logs as soon as the watch turned on.
                                      its really frustrating to not be able to trust a watch to do things so basic, fortunately it’s just a missed run, but I used this function to catch planes before, I will never do it again because there’s a non zero chance the thing will never wake me up… 😞
                                      E 1 Reply Last reply Reply Quote 0
                                      • T Offline
                                        tmclr Bronze Member
                                        Once again, my 9PP updated to this latest s/w overnight, despite Automatic updates being disabled.
                                        • G Offline
                                          Geoffwilli @Benjamin 0
                                          @Benjamin-0
                                          Thats useful to know. My battery drains a third every day, without any activities. My watch is close to two years old so I think suunto will refuse to look at it. I’m so annoyed by this as i’ve been a suunto user for 15+years, and have never had a problem. I bought the watch to use for long Ultra races, which I now don’t feel comfortable in using.
                                          E Milan ŠádekM B 3 Replies Last reply Reply Quote 1
                                          • E Online
                                            Elipsus Silver Members @Geoffwilli
                                            @Geoffwilli if its not two years old you might still be under warranty, its worth a try
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
