    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 2.50.28 hot-fix Q4
    Scheduled Pinned Locked Moved Watches
    109 Posts 49 Posters 19.2k Views 48 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      gagbo @Benjamin 0
      @Benjamin-0 when I RMA’d mine I just got a “your battery’s fine, here’s your watch back”, so lucky you 😄
      • T Offline
        The_77 Silver Members @The_77
        Just to add, had the same issue yesterday with the route dropping temporarily when in conjunction with a guided so every new interval caused a “route lost”/“back on route” combo.
        Also, the watch hung on a zonesense screen, with nothing happening when buttons were pressed. Happily before I soft reset I tried the long press bottom button to escape to a menu, and then exited out, all was fine. Avoided the zonesense screen the rest of the run, but if someone else has that they may resort to soft resetting.
        Appreciate it’s a bit late in the cycle of watch updates to report, but any idea if these have been fixed in new SW update or are unreported? @egika @dimitrios-kanellopoulos
        Suunto Spartan Trainer Wrist HR / 9PP Refurb
        • T Offline
          tmclr Bronze Member
          Just replied to a post in the 9PP forum specific to this issue, but probably more appropriate to mention here…
          After the last firmware update I started getting frequent phantom alerts/vibrations - several per day with no message on the screen or apparent reason.
          In my case, this behaviour it disappeared after a few days without me taking any action, however over the last few days it has spontaneously started again - frequent phantom alerts/vibrations.
          Not sure if this was acknowledged as a bug in the latest s/w and we can expect a fix in the imminent release?
          • isaziI isazi unpinned this topic on
          • helgonet12H Offline
            helgonet12
            Does any one know when this will be fixed? (Vertical 1)
            1. The solar widget, the one that shows how much sun the watch have harvested during the week does not update. Only if you soft reset the watch. I think it has bees like this since the release of the vertical 1.
            2. When in an activity the rise to wake does not work. Even if it is enabled. This one is a really pain, especially now during spring/ summer and you trail run in the forest. The screen is really hard to read in a glance, if you are not in direct sunlight. or if you press a button. which then tae you to the next screen. which is another pain.
            L 1 Reply Last reply Reply Quote 2
            • L Offline
              larrybbaker @helgonet12
              @helgonet12 I have not seen either of those issues in my V1 Ti Solar. I’m presuming you have reviewed all your settings and at least soft reset the watch?
              Vertical Ti Solar
              Vertical 2
              Race 2
              iPhone 17 Pro
              helgonet12H 2 Replies Last reply Reply Quote 0
                helgonet12 @larrybbaker
                @larrybbaker that is verry strange. I have had the watch since release and what I can remember it has never worked. But I could be wrong. And yes I have tried everything.
                  @larrybbaker So you mean that your widget does not look like this? no matter how much or little the watch harvest sun the widget remains the same. It has done so since launch of vertical 1IMG_1030.jpeg
                  sartoricS 1 Reply Last reply Reply Quote 1
                  • sartoricS Offline
                    sartoric Moderator @helgonet12
                    @helgonet12
                    yep, it refreshes only if you restart the watch
                    SVTS - 2.50.28
                    SSSWHR BARO Amber - 2.8.32
                    Samsung A5 2016 - Android 7.0
                    Suunto App Android 6.8.9 beta
                    helgonet12H 1 Reply Last reply Reply Quote 0
                      helgonet12 @sartoric
                      @sartoric ok thanks for the info. I guess it will never be fixed then.
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
