    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 2.50.28 hot-fix Q4
    Scheduled Pinned Locked Moved Watches
    112 Posts 51 Posters 22.4k Views 50 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Manuel ExtremeM Offline
      Manuel Extreme Silver Members @Александр Даниленко
      Vertical 2 v2.56.18
      • E Offline
        Elipsus Gold Members @Ecki D.
        @Ecki-D. yup, the HR thing going offline happened twice with the latest update, and i’m having very erratic behavior when the watch turned iself of on multiple occasion last weeks, it “seems” to be ok now, i charged it again to 100% and let it idle on the charger for 2 more hours.
        I had to find a “dumb” charger as the others wouldn’t charge the watch above 90ish percent (i think the current is too low and the charger goes offline, i’ve seen this especially on power banks
        • M Offline
          misu763 Bronze Member
          Since the latest update and the hotfix, I experienced the HR unexpected off three time… all the time I activated a soft reset and the sensor started to work again quickly.
          Luckily I noticed the fact as I started the training record and the HR was not synced…
          I hope a new hotfix could delete this annoying problem…crossed fingers here!
          S9PP Ti Slate
          Ecki D.E 1 Reply Last reply Reply Quote 1
          • Ecki D.E Offline
            Ecki D. Bronze Member @misu763
            @misu763 It helps me to have the passcode function enabled.
            So everytime the hr sensor fails, the watch thinks it is not on the wrist anymore and locks itself.
            So as soon as I have to dial in the passcode I know something is wrong.
            https://www.strava.com/athletes/37982563
            https://www.instagram.com/macdev
            M 1 Reply Last reply Reply Quote 1
            • M Offline
              misu763 Bronze Member @Ecki D.
              @Ecki-D.
              Clever strategy! Thank you for the suggestion!
              S9PP Ti Slate
              • T Offline
                The_77 Silver Members
                I have nothing exciting to note other than my alarms both went off 50 minutes later than planned today, on 9PP. I suppose it’s possible I snoozed them both 5 times or slept through them but I have doubts.
                Suunto Spartan Trainer Wrist HR / 9PP Refurb
                D 1 Reply Last reply Reply Quote 2
                • Ádám PatkósÁ Offline
                  Ádám Patkós @Ecki D.
                  @Ecki-D. The OHR sensor doesn’t work for me either, the latest firmware. I restored it to 2.50.26 and it’s been perfect ever since.
                  • D Offline
                    duffman19 @The_77
                    @The_77 Any chance the watch face could have been touching your skin when the alarm was supposed to go off? The touch screen activates a moment before the vibration or sound does when an alarm goes off, making it possible to snooze or dismiss it without even knowing. It’s possible this could have happened 5 times if you didn’t move.
                    Old software required a button push to turn off or snooze the alarm. This is the way it should be. Not sure why it changed.
                    Vertical Ti / S9PP Ti / S9P Ti
                    T 1 Reply Last reply Reply Quote 2
                    • T Offline
                      The_77 Silver Members @duffman19
                      @duffman19 I mean, I was wearing long sleeves, so theoretically they could have been touching the surface, if that’s the case then it’s plausible.
                      I guess if it happens again I’ll find out!
                      • Ecki D.E Offline
                        After latest FW: ~1%/h drain in smartwatch mode (~4d total) 9PP.
                        • No activities
                        • GPS perf OK (~37–40h)
                        • Static WF
                        • Soft reset → no change
                        • Flight mode → still ~1%/h
                        HW seems fine → likely FW idle/deep sleep regression.
                        I think I’ll roll back FW.
                        Ecki D.E 1 Reply Last reply Reply Quote 0
                        • OutdoorManO Offline
                          OutdoorMan Silver Members
                          Race S, no issues until the latest hotfix. Now issues with sleep detection. There is also no data on the watch. Should I open a separate thread?
                          2 1 Reply Last reply Reply Quote 0
                          • 2 Offline
                            2b2bff Silver Members @OutdoorMan
                            @OutdoorMan no need to open a new thread. It is already known to Suunto, it seems… https://forum.suunto.com/post/185192
                            Race S
                            OutdoorManO 1 Reply Last reply Reply Quote 0
                              OutdoorMan Silver Members @2b2bff
                              @2b2bff I see, thanks. Let’s wait then…
                              • Ecki D.E Offline
                                Ecki D. Bronze Member @Ecki D.
                                Update – S9PP idle drain
                                Observed ~1%/h drain in normal mode.
                                In flight mode: ~0.25–0.5%/h (normal).
                                BT on (watch) + BT off (phone): normal drain.
                                Fully connected to iPhone: ~1%/h again.
                                So it seems related to active BT/App communication, not hardware or general FW idle.
                                Now testing with background app refresh disabled.
                                Will report back.
                                Ecki D.E 1 Reply Last reply Reply Quote 2
                                • J Offline
                                  JuanPh Bronze Member
                                  Hi everybody,
                                  Does the North-up option work? I think I tried just after release of version 2.50.26 and it worked, but now on 2.50.28, it doesn’t work, even after a soft reset, any clue?
                                  • HonzaSH Offline
                                    HonzaS
                                    Just found small bug. The next alarm time in morning report is not right, because it does not reflect alarms set for workdays. I think it only counts with general time.
                                    If I have set alarms for 6:00 and 10:00 on workdays and morning report shows up on saturday at 8:00, it shows next alarm at 10:00 but next alarm will be on monday at 6:00.
                                    Suunto Vertical 2
                                    • Ecki D.E Offline
                                      S9PP – Idle drain investigation (final update)
                                      I initially observed ~1%/h drain in smartwatch mode after the latest FW.
                                      Testing over the last 24h:
                                      • Flight mode → ~0.25–0.4%/h (normal)
                                      • BT on (watch) + BT off (phone) → normal
                                      • Background App Refresh OFF → normal overnight drain
                                      • Activities (no GPS / short GPS) → within spec
                                      • With Background App Refresh ON → slightly higher idle, but not consistently reproducible 1%/h anymore
                                      Conclusion so far:
                                      • HW is fine (training battery life fully in spec)
                                      • Deep sleep works
                                      • High drain seems related to iOS app communication state
                                      • Not a permanent FW idle regression
                                      For now I’ll keep Background App Refresh disabled and continue monitoring.
                                      • thanasisT Offline
                                        thanasis Bronze Member
                                        regarding the drain/battery management or whatever is related to the indication the watch provides … I am a bit disappointed… after letting the watch deplete and recharged it , I used and for 2 days it consumed like 2% per day - which gave me some smiles… (with oHR and notifications off though) … then I went for a run , using Suunto HR Belt, enabled the notifications and it lost 10% over 1 hour…
                                        it is what it is , but it’s definitely not great
                                        • Ecki D.E Offline
                                          Ecki D. Bronze Member @thanasis
                                          @thanasis if you like you can check battery usage during workout in https://smlanal.szmigiel.design from @łukasz-szmigiel
                                          Export the json form the workout in suunto app and upload it there.
                                          I haven’t checked yet but I guess the permanent sync with the HR Belt or other sensor is using much more battery. I did a MTB Ride this morning only with the OHR and best GPS and it uses about 2,8% / Hour.
                                          Edit:
                                          Uploaded a 10k run from December with Suunto HR Belt, it says 4,04%h. Still have to re-check with latest FW and App version.
                                          • T Offline
                                            Interesting bugs today, probably easy repeatable if someone wants to check.
                                            Imported a Suunto guide from intervals.icu and set up a run with a route. Firstly, I previously had media on, and it wasn’t possible to turn off from the menu when running (long press bottom right).
                                            Secondly, every time a new section started of the training, the watch would tell me it was off route, before confirming I was back on route about 10s later. Which if you combine with the vibration from getting into the correct zone, vibration to start the interval and so on, is a lot of buzzing on the wrist, especially if you have a short (100m or so) interval.
                                            I’ll try and replicate it whenever I do a quality session next, probably earliest the weekend or next week I guess.
                                            T 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
