    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    Scheduled Pinned Locked Moved Suunto Vertical
    760 Posts 137 Posters 348.1k Views 114 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • sartoricS Offline
      sartoric Moderator @BastMaSVSRS9PP
      @BastMaSVSRS9PP said in Battery drain:
      This is not a solution .
      In fact it’s a workaround as said several times in this thread.
      resetting also resets your steps
      Not with a soft reset (12sec button press)
      and resources for the day
      maybe the graph, didn’t check the value before resetting
      SVTS - 2.50.28
      SSSWHR BARO Amber - 2.8.32
      Samsung A5 2016 - Android 7.0
      Suunto App Android 6.11.12 beta
      • ? Offline
        A Former User @sorinus
        @Sorin-C This has been shared multiple times on the forum. The battery drain issue is still under investigation. We’ve already had an update that addressed some of the reported problems. I don’t have any more info than anyone else, but I know it’s a priority for Suunto.
        B 1 Reply Last reply Reply Quote 0
        • D Offline
          duffman19 @surfboomerang
          @surfboomerang said in Battery drain:
          I think Suunto is aware of the issues.
          I hadn’t seen it mentioned that they are aware of the battery drain while not wearing the watch, but I hope you are correct. I’ve been sharing my experience in hopes of helping to find a solution. For me, the drain appears to be directly related to how the watch is positioned when off the wrist. I would think this would imply a sensor issue, but which sensor, I don’t know.
          I no longer have the post-activity drain after the last update, whether I enter the activity settings menu or not, while wearing the watch. I’m only seeing it when removed from the wrist.
          Vertical Ti / S9PP Ti / S9P Ti
          • B Offline
            BastMaSVSRS9PP Bronze Member @Guest
            Yes it has been shared multiple times in this forum but this post has been created in May 2023!!! One and a Half year later the issue still persists. One and a half year!!! I’ve been patiently waiting but the last battery drain event during a trail running / camping trip weekend got me upset
            Winter and ski touring and such is coming up. I really want it to work seemingly without fiddling around with soft resets constantly . I love my Suunto it’s a wonderful watch but this is one issue driving me nuts.
            SR, SVti (Mammut Edition), SR2, Suunto Wing
            1 Reply Last reply Reply Quote 8
            • L Offline
              larrybbaker @duffman19
              @duffman19 I have put my watch on it’s side this week - instead of face down… maybe… less drain?
              Vertical Ti Solar
              Vertical 2
              Race 2
              iPhone 17 Pro
              ? D 2 Replies Last reply Reply Quote 1
              • ? Offline
                A Former User @larrybbaker
                @larrybbaker Why not just turn off 24/7 wrist HR tracking when you leave the watch on the table?
                L 1 Reply Last reply Reply Quote 0
                • L Offline
                  larrybbaker @Guest
                  @iterumtenta it is off.
                  Vertical Ti Solar
                  Vertical 2
                  Race 2
                  iPhone 17 Pro
                  • D Offline
                    duffman19 @larrybbaker
                    @larrybbaker I did a very short experiment, but it is telling none the less. Last night I took my watch off and placed it on its side. Overnight (~8 hours) it lost 0% (91-91%). In the morning, I turned it face down. It lost 6% in less than 3 hours (91-85%). I then recorded a 2 hour activity and saw a 3% drop (as expected). I have since left the watch face up and it has yet to drop a percentage (only about 2 hours so far).
                    For my watch, position clearly makes a difference. Something about having it face down causes a severe battery drain. Whether it’s related to the ambient light sensor or perhaps the gyroscope/accelerometer, I really don’t know. It makes no sense, but it is clearly happening.
                    • L Offline
                      @duffman19 interesting since that is supposed to be it’s “sleep mode” if I recall.
                      Vertical Ti Solar
                      Vertical 2
                      Race 2
                      iPhone 17 Pro
                      • ? Offline
                        A Former User
                        Last night, I performed a soft reset and left the Vertical on the table as usual. However, I didn’t notice that the top right button was accidentally pressed, which kept it in the activities menu and resulted in a 15% battery drain overnight.
                        • martintrailM Offline
                          martintrail Silver Members
                          I have Vertical Solar for the first week. What is your average battery consumption per week? Is 40% per week normal? I use 24/7, average an hour/hour and a half of activity each day, notifications off. I can’t use solar much anymore, no sun when it’s fall/winter 😄
                          Vertical Ti Solar
                          TieutieuT gerasimosG 2 Replies Last reply Reply Quote 0
                          • TieutieuT Offline
                            Tieutieu Platinum Member @martintrail
                            @martintrail With this use, normal day use is around 2-4% max/ day with no exercice. 1 to 1h30 activity / day should add around 2% of consumption/day.
                            If it’s you’re first battery cycle, you need a full cycle first, battery should calibrate properly.
                            Suunto’s devices at home :
                            Vertical titanium solar
                            Suunto Race S
                            S9pp titanium sand
                            Suunto Wing & Spark
                            S9B titanium Ambassador edition, A3P, X6
                            • gerasimosG Offline
                              gerasimos Bronze Member @martintrail
                              @martintrail
                              2.37.48 installed
                              1st November 100% charge battery
                              18 November 38% remaining
                              -training hours 29 (trail run mainly- openwater swim - mtb)
                              • always PERFORMANCE battery mode-
                                sometimes with map navigation and backlight ON at 6 night sessions.
                                hr always ON
                              *daily use everything OFF hr / steps / no connections with mobile / etch… only watchtime use.
                              Godzilla battery!!🔺 💪
                              Suunto Vertical Ti
                              Suunto S9 gen1
                              Suunto Ambit3 peak
                              thanasisT 1 Reply Last reply Reply Quote 6
                              • thanasisT Offline
                                thanasis Bronze Member @gerasimos
                                @gerasimos hard reset yesterday…
                                full setup
                                full charge to 100% at 08.15
                                test training (walking) to see if things work at 08.30 for 7 min
                                battery at 12.15 : 93%
                                so 7% In 4 hours
                                ? gerasimosG 2 Replies Last reply Reply Quote 0
                                • ? Offline
                                  A Former User @thanasis
                                  @thanasis A friend of mine has a S9PP with a new battery and it lasts only a few days. In the evening the watch has 20% and in the morning 2%-3%. The watch is unusable at the moment.
                                    my battery consumption is higher than others here report. I get 8-10% a day with use as I write. I’ll wait for it to discharge to 0 and then we’ll see. So far it’s not too bad, but nothing great either 😄
                                    Vertical Ti Solar
                                    • U Offline
                                      Ultrawalker
                                      My Vertical had monday evening 79% battery when i left my watch in the closet.
                                      2 days later without using watch i only have 57% left…
                                      All those updates later Suunto can’t solve the problem of huge battery drain…
                                      When will this be solved? Or never…???
                                      Suunto Spartan Ultra
                                      Suunto 9 Peak Pro All Black
                                      Suunto Vertical
                                      martintrailM 1 Reply Last reply Reply Quote 0
                                      • L Offline
                                        larrybbaker
                                        I tried resting my watch on its side as opposed to face down when not using it. I am still seeing the unusual drop. What is interesting to me is that it seems like up to 65% of battery is a slower loss but once it gets below that it seems to drain faster?
                                        Vertical Ti Solar
                                        Vertical 2
                                        Race 2
                                        iPhone 17 Pro
                                          gerasimos Bronze Member @thanasis
                                          @thanasis never dohard reset.
                                          I just drained battery once time 0% and the others about 15%-20% and full charge again.
                                          After last update i charge as usual and i have the results above.
                                          Small faster drain Problems i had only in the first software for two or three cycles of charge again now im ok
                                          Suunto Vertical Ti
                                          Suunto S9 gen1
                                          Suunto Ambit3 peak
                                          thanasisT M 2 Replies Last reply Reply Quote 0
                                            martintrail Silver Members @Ultrawalker
                                            @Ultrawalker I also noticed that it doesn’t discharge as quickly during activity as it does during normal wear. That’s really weird.
                                            Vertical Ti Solar
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
