    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    Scheduled Pinned Locked Moved Suunto Vertical
    759 Posts 136 Posters 348.1k Views 113 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • thanasisT Offline
      thanasis Bronze Member @gerasimos
      @gerasimos it drained 14% today . That’s a lot !!
      gerasimosG 1 Reply Last reply Reply Quote 0
      • M Offline
        misu763 Bronze Member @gerasimos
        @thanasis never dohard reset.
        I just drained battery once time 0% and the others about 15%-20% and full charge again.
        Is it useful to drain battery till 0%? I am not sure if it is a good action or not for battery life…I am just curious as I read a lot of different opinions about this.
        S9PP Ti Slate
        • gerasimosG Offline
          gerasimos Bronze Member @thanasis
          @thanasis i think this drainage it’s a lot… Maybe you can go at local Suunto service and measure the power and capacity of battery if it’s ok .
          Suunto Vertical Ti
          Suunto S9 gen1
          Suunto Ambit3 peak
          1 Reply Last reply Reply Quote -1
          • thanasisT Offline
            17% drop in 24 hours with just 7min of test training .
            Obviously there is an issue
            The only change made : I switched to this watch face :
            gerasimosG jjpazJ 2 Replies Last reply Reply Quote 0
              gerasimos Bronze Member @misu763
              @misu763 its not official suggestion and not necessary. With this way recalibrate the battery if you have issues after big software updates and only for once time… you dont need do this every time
              Suunto Vertical Ti
              Suunto S9 gen1
              Suunto Ambit3 peak
                @thanasis i don’t think watchface cause drain problems… only the background backlight , wifi / Bluetooth ON etch in watch time mode.
                I have always off WiFi and Bluetooth and my watch connected automatically in my phone after first pair.
                Everyday my setup:
                Sleep tracking off
                Blood oxygen off
                Hrv tracking 24/7 off
                Mobile notifications off
                Brightness medium / standby off / raise to wake off / backlight OFF
                Activities always performance everything ON
                Also i have Ocean watchface still 33% from 1 November IMG_20241121_080940.jpg
                Suunto Vertical Ti
                Suunto S9 gen1
                Suunto Ambit3 peak
                thanasisT martintrailM 2 Replies Last reply Reply Quote 0
                • thanasisT Offline
                  @gerasimos turning mobile notifications off is not
                  Something that I want to do and I don’t think that Suunto are calculating their estimations on such conservative an approach .
                  Thanks !!
                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                  • TieutieuT Offline
                    Tieutieu Platinum Member
                    Have you disabled main « backlight on » setting ?
                    Suunto’s devices at home :
                    Vertical titanium solar
                    Suunto Race S
                    S9pp titanium sand
                    Suunto Wing & Spark
                    S9B titanium Ambassador edition, A3P, X6
                    • Dimitrios KanellopoulosD Online
                      Dimitrios Kanellopoulos Community Manager @thanasis
                      @thanasis About 3% drain with this watchface for me… What happens if you disable BLE ? And reboot
                      Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                      martintrailM 1 Reply Last reply Reply Quote 0
                      • martintrailM Offline
                        martintrail Silver Members @Dimitrios Kanellopoulos
                        @Dimitrios-Kanellopoulos what is BLE? 😄
                        Vertical Ti Solar
                        Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                          Dimitrios Kanellopoulos Community Manager @martintrail
                          @martintrail bluetooth
                            martintrail Silver Members @gerasimos
                            @gerasimos but if you have everything turned off, there’s no point in talking about it 🙂
                            Vertical Ti Solar
                              @martintrail the advertised battery is not with everything on especially backlight. That needs to be off.
                              So its up to 1 month and that does not include lets say 100 vibrations + notifications (backlight) per day.
                              thanasisT 1 Reply Last reply Reply Quote 2
                              • thanasisT Offline
                                thanasis Bronze Member @Dimitrios Kanellopoulos
                                @Dimitrios-Kanellopoulos said in Battery drain:
                                the backlight is set to auto (wake to raise or how it is called)
                                turning off the BLE will disable the notifications i think, which i want to have. I have less than 100notificiations and the overnight it consumed like 6% (zero notifications, and turned face down , so the HR/ blood was off)
                                in the past this was not the case for sure. Also before the hard reset (which is did to test the other item i reported on the offset… which apparently is not related) the drain is significantly higher than before.
                                  @thanasis well just to test the ble is not the culprit on that 14% of drain. Maybe its the notifications?
                                  I dont think hard resets are going to help here so don’t waste your time with that.
                                  • Mff73M Offline
                                    Mff73 @Mff73
                                    @Mff73 said in Battery drain:
                                    Fully charged mine yesterday from 0%
                                    9% lost in 24 hours without any activity.
                                    No soft reset, just charged.
                                    [edit]
                                    24/24 HR on
                                    notifications on
                                    Sleep tracking on
                                    SPO2 on
                                    everything like when i purchased it at launch
                                    today’s stats :
                                    Charged from 0% to 100% on Oct 6th.
                                    Today : 22% left --> 78% lost in total in 12 days
                                    17% battery lost in 9h36 of GPS activity
                                    So 61% lost for 12 days, non include GPS activity (avg = 5% / day)
                                    today’s stats :
                                    Charged from 10% to 100% on Nov 11th.
                                    Today : 15% left --> 85% lost in total in 10 days
                                    32% battery lost in 17h50 of GPS activity
                                    So 53% lost for 10 days, non include GPS activity (avg = 5.3% / day)
                                    @Dimitrios-Kanellopoulos (hello 🙂 ), do you think it is in the normal range, please ?
                                    In addition to my above settings (not changed), i also have raise to wake on and auto DND from 21h30 to 8h00.
                                    SSU (retired), SV1, SV2
                                    Wife : S9PP
                                    SA: Always the latest beta :)
                                    Android + Galaxy S205G
                                    Dimitrios KanellopoulosD Mff73M 2 Replies Last reply Reply Quote 0
                                    • sorinusS Offline
                                      sorinus
                                      If I have the backlight off, “raise to wake” on low: Does this affect the stated battery life in time mode only?
                                      Besides the backlight setting I have disabed everything (24/7 hr off, blood oxygen off, sleep tracking off, notifications off) and it looks like it consumes about 5% of battery since monday when I received the watch and set it up. No exercise yet. Overnight I leave it on my desk and battery doesn’t drop a bit. So could be the raise to wake consume that much even on low brightness?
                                      P.S. I also fiddled with the watch settings, widgets quite a lot these first days, so that added an additional hit to the battery but still…
                                      Suunto Vertical Ti
                                        Dimitrios Kanellopoulos Community Manager @Mff73
                                        @Mff73 sounds ok for raise to wake + tracking hr + hrv etc.
                                          maybe a feature “low consumption” battery mode for watchtime use could be useful , and the watch automatically use only necessary functions for ultra extended power management .
                                          -just a suggestion
                                          Suunto Vertical Ti
                                          Suunto S9 gen1
                                          Suunto Ambit3 peak
                                          Nicolas MarseilleN 1 Reply Last reply Reply Quote 1
                                          • Nicolas MarseilleN Offline
                                            Nicolas Marseille @gerasimos
                                            @gerasimos : there is an “power saving” mode which switch off everything else than “time”. Last summer my watch ran during more than 3 weeks, including numerous workouts, without any power charge.
                                            https://www.suunto.com/en-gb/Support/Product-support/suunto_vertical/suunto_vertical/settings/power-saving/
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
