    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    Scheduled Pinned Locked Moved Suunto Vertical
    755 Posts 136 Posters 339.2k Views 113 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      GKnoll @Mattg576
      @Mattg576 Well, I got to the end in one piece! Yes, the weather was pretty awful at times up on the mountains. Freezing rain and black ice were additional hazards during the first night and one poor chap was limping badly as he came back into the village of Thwaite having slipped on the ice.
      As a matter of course I put the watch on charge at each main checkpoint. I had no idea how bad the backlight issue was affecting battery life and did not want to risk losing navigation.
      M 1 Reply Last reply Reply Quote 3
      • M Offline
        Mattg576 @GKnoll
        That’s a great achievement @GKnoll , well done mate .
        I hope Suunto sort the backlight issue so you don’t need to worry about it when you undertake the full Spine next year😀
        Race
        9 Peak
        Ambit 3 Peak
        Ambit 2R (sold)
        Suunto T3d (expired)
        • Fenr1rF Offline
          Fenr1r
          Under 2.50.26, I notice that my overnight, off-wrist battery consumption approximately doubles (vs 2.46…)
          My only change for the new FW was to enable North-up mapping.
          2.50… did add the wifi weather updates (which do not work for me … could there be repetitive attempts by the watch to connect to wifi and the App that drain power?)
          • thanasisT Offline
            thanasis Bronze Member
            There is still a battery drain issue.
            Yesterday : leaving the watch next to my polar h10 (i forgot to remove the sensor from the strap and i usually use Suunto’s strap but i had to clean it this time so i used the h10…) , vertical 1 dropped from 85% to 55% overnight . …30% !!
            One could argue about minor deviations of 1-2% difference or whatever being random observations/glitches or whatever , but this is a very strong indication that something is not OK. It is very hard to classify it as a hardware/battery degraded related because it’s not consinted against various changes in the setup . (E.g. removing HR , turning off , Bluetooth or removing WiFi , brings makes the watch operate in a rather expected long lasting way, even just wearing the watch overnight is a lot better than taking it off and leaving it on the bench with a Bluetooth/wifi device nearby ).
            I know Vertical 2 , Race 2 etc are a lot fancier and great to talk about but this is device is still sold, (supposingly being) supported and is promoted as the top of the line for it’s long lasting battery etc. In my opinion… someone needs to look over it again because it seems there is something wrong here
            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 4
              Dimitrios Kanellopoulos Community Manager @thanasis
              @thanasis if you left the watch facing down on the table that could have happened as it was using full power trying to detect ohr.
              Was this the case ?
              AGAIN: there is not active connection to a belt. Even if that was the case it does not burn so much.
              If you hav 24/7 HR on and leave it on a table it will try to read HR and bump up the ohr readings. If that was not the case then some WIFI culprit is suspected.
              Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
              sartoricS 1 Reply Last reply Reply Quote 1
              • sartoricS Offline
                sartoric Moderator @Dimitrios Kanellopoulos
                @Dimitrios-Kanellopoulos
                so, ooc, if I left it on the table should I put it face up ?
                SVTS - 2.50.28
                SSSWHR BARO Amber - 2.8.32
                Samsung A5 2016 - Android 7.0
                Suunto App Android 6.11.8 beta
                Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                  Dimitrios Kanellopoulos Community Manager @sartoric
                  @sartoric yup
                  sartoricS 1 Reply Last reply Reply Quote 0
                  • sartoricS Offline
                    ok. because when I place it face down I don’t see led blinking while they blink (for a while) when it is face up
                    I have the loop strap so it’s almost always behind the sensor
                    SVTS - 2.50.28
                    jjpazJ G 2 Replies Last reply Reply Quote 1
                    • jjpazJ Offline
                      jjpaz Bronze Member @sartoric
                      @sartoric Be careful when placing your watch on any surface because, depending on the strap, the optical sensor might be activated due to the strap’s reflection…
                      This doesn’t happen to me with the black silicone strap, but it does with the others, including the Velcro ones.
                      And the optical sensor looking for heart rate is very battery consuming.
                      Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
                      • sartoricS Offline
                        sartoric Moderator @jjpaz
                        @jjpaz
                        yep I know 🙂
                        most of the time I place it on its side
                        SVTS - 2.50.28
                        • G Online
                          Gunnar Bronze Member @sartoric
                          @sartoric said in Battery drain:
                          I have the same experience with race s. I always put it face down, no issues yet.
                          SportsfreundS 1 Reply Last reply Reply Quote 0
                          • SportsfreundS Offline
                            Sportsfreund Bronze Member @Gunnar
                            Why are you taking off your watch? 🤷🏼‍♂️
                            • thanasisT Offline
                              Another crazy drain whilst leaving the watch with hr off in the drawer . 40% drop in 2 days . I sent the logs right now in case anyone finds anything interesting
                              thanasisT Danny polegD 2 Replies Last reply Reply Quote 0
                              • thanasisT Offline
                                thanasis Bronze Member @thanasis
                                Again , watch left on tonight , another 12% consumed overnight.
                                • Danny polegD Offline
                                  Danny poleg Silver Members @thanasis
                                  @thanasis For me it’s about 9% per day without training.
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
