    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    Scheduled Pinned Locked Moved Suunto Vertical
    743 Posts 135 Posters 239.0k Views 113 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      GKnoll
      For the Suunto Vertical is there an option to display the battery % or hours remaining during an activity such as running?
      I’ve looked at the Sport Mode Customisation options and could not see it there.
      I need this option for some events so I can plan for re-charging the battery in good time.
      SamuelPS 1 Reply Last reply Reply Quote 0
      • SamuelPS Online
        SamuelP Silver Members @GKnoll
        @GKnoll just long press the lower button to acces the “control panel”. It shows “battery %” and “hours left”
        Vertical All Black
        BrunoHB G 2 Replies Last reply Reply Quote 1
        • BrunoHB Offline
          BrunoH Gold Members @SamuelP
          @Samuel-Pirttikangas a quick reminder. Not all of us have Control Panel configured to the lower button long press. I used to have, but I had to change it because of the Control Panel carousel rendering problem. The problem stopped when I moved it to mid button short press. Weird, I know!
          Compasses: M-311, A-10, SK-7
          Diving: Finnlight Navy 90, Vyper
          Sports: Metron, S7, S9B and Vertical
          SportsfreundS SamuelPS 2 Replies Last reply Reply Quote -1
          • SportsfreundS Offline
            Sportsfreund Bronze Member @BrunoH
            @BrunoH er meint wenn du die untere Taste während einer laufenden Aktivität gedrückt hälst.
            • SamuelPS Online
              SamuelP Silver Members @BrunoH
              @BrunoH i ment if you hold down the bottom button during an ongoing activity then you get battery stats. 🙂
              Vertical All Black
              1 Reply Last reply Reply Quote 6
              • G Offline
                GKnoll @SamuelP
                @Samuel-Pirttikangas Thank you!
                • MarioPedrazaM Offline
                  MarioPedraza @OnlyoneKenobi
                  @OnlyoneKenobi Oops, sorry. Mine goes to technical support on Tuesday. I’ll cross my fingers.
                  • Abu bakar UmarA Offline
                    Abu bakar Umar @Klaane
                    @Klaane said in Battery drain:
                    The battery on my Suunto Vertical Solar has dropped from fully charged to 55% in only two days. Last night it dropped by 15% while I was sleeping with the watch on.
                    I have mobile notifications and 24/7 HR turned on but it still shouldn’t drain that fast, right? Standby backlight is off and I’ve used GPS for less than 10 minutes during those two days.
                    Do I have a defective battery or could this be some other issue?
                    It sounds frustrating! While mobile notifications and 24/7 HR can drain the battery, a 15% drop overnight seems excessive. Try resetting your watch or updating the firmware. If the issue persists, contacting Suunto support might help. 🔋
                    • Devil SchemeD Offline
                      Devil Scheme Banned
                      This post is deleted!
                      • Nicolas MarseilleN Offline
                        Nicolas Marseille
                        Hello everyone, since last firmware update to 2.50.26 version battery drain issue is strongly back ! Almost 10% per day ! This was a solved issue since months…
                        Do you know any way to rollback to a former firmware. The previous one was perfect from my point of view.
                        G 1 Reply Last reply Reply Quote 1
                        • G Offline
                          ggrego @Nicolas Marseille
                          @Nicolas-Marseille bonjour Long press the middle button to access the settings.
                          • Select general.
                          • Select about.
                          • Scroll down until you see data privacy at the end.
                          • Long press the bottom button to access the interface.
                          Scroll down and select
                          “Select the OTA package”.
                          You can see the current version and the previous version here.
                          Select the previous version to update
                          • G Offline
                            GKnoll
                            Re software 2.50.26: During last week’s Spine Challenger North I found that, after maybe a day of continuous tracking, when I had the navigation screen showing the backlight would turn on, often at high intensity, if I apparently raised my wrist - but I had disabled this function under General Settings and confirmed this post-event. Wrist raises occurred often because of the terrain so the backlight kept turning on. This caused me great concern because of the obvious effect on battery life and the need for good navigation at night up on the mountains in bad weather.
                            I also note that if I select ‘endurance’ gps accuracy (that is, ‘good’ rather than ‘best’) only breadcrumb navigation is now available, whereas in the previous software version I could select outdoor mapping for navigation for ‘good’ gps (that, I found, is perfectly adequate for navigation in open countryside). Was this change a bug fix or was it to remove an apparently better battery life than the Vertical 2 in the good/endurance gps mode?
                            D M 2 Replies Last reply Reply Quote 1
                            • D Offline
                              duffman19 @GKnoll
                              @GKnoll There is a bug in the current software that causes the backlight to inadvertently activate when entering an activity. Several of us have posted about it in several locations ( here, here, here, and here), but have had no recognition of the issue.
                              Vertical Ti / S9PP Ti / S9P Ti
                              G 1 Reply Last reply Reply Quote 0
                              • G Offline
                                GKnoll @duffman19
                                @duffman19 Thank you, I’ll review the links you kindly provided.
                                D 1 Reply Last reply Reply Quote 0
                                • D Offline
                                  duffman19 @GKnoll
                                  @GKnoll I created a separate topic for this here: https://forum.suunto.com/topic/14502/backlight-bug-2.50.26
                                  Maybe you can post about your experience so it’ll gain some traction and attention from Suunto. It’s odd that they haven’t recognized this yet.
                                  M 1 Reply Last reply Reply Quote 1
                                  • F Offline
                                    franky23
                                    My Vertical titanium solar has battery draining from the biginning, more than two and half years ago. I don’t use notification from phone, but I use hr and sleep monitor. Of course backlight off and rise on low.
                                    My best results with some firmware where 7-8% for 24 hours whitout activity, maximum with some activityes from fully charge to 5-6% was two weeks, sometimes 15 or 16 days.
                                    Now after last two or three update I’m on 11- 12 days maxymum, about 8-9% per day. I tried everithing in the past: discharge till 0%, soft reset, soft reset pressing for a long period (also one minute), hard reset. Never changed.
                                    After last update and this worst performance, I tried to recalibrate, but now it is impossible to totally discharge, because at 2% the watch enter in a safe mode and you have to wait many hours to drain the last enerergy, without can using it (before this energy saving mode I used to switch on the torch to quick discharge from 1% to 0).
                                    Probably there are lucky and unlucky watch for battery…
                                    SquirrelS 1 Reply Last reply Reply Quote 0
                                    • M Offline
                                      Mattg576 @GKnoll
                                      @GKnoll How did your race go in that horrendous weather & did your Suunto last the distance (to keep the mods at bay for going off topic) ??
                                      A friend of mine did the Challenger South & said it was some of the worst weather he’s experienced in this country, he finished in just over 53hrs😨
                                      Race
                                      9 Peak
                                      Ambit 3 Peak
                                      Ambit 2R (sold)
                                      Suunto T3d (expired)
                                      • SquirrelS Offline
                                        Squirrel Silver Members @franky23
                                        @franky23 You should have sent it for battery replacement at the beginning while under warranty. There certainly are faulty batteries with much smaller capacity than designed out there, or it could also be another hardware problem causing excessive power consumption.
                                        F 1 Reply Last reply Reply Quote 0
                                        • M Offline
                                          Matúš Bronze Member @duffman19
                                          @duffman19 said in Battery drain:
                                          Maybe, they’re still deciding if taking this bug seriously or just replying “I’m not affected by this bug.”, just saying…
                                          Suunto 9 Peak Pro Titanium Slate
                                          Suunto Spartan Sport
                                          #swatt
                                          • F Offline
                                            franky23 @Squirrel
                                            @Squirrel
                                            You are probably right, but I asked to a firned of mine, tester for Suunto, and is opinion was that suunto probably would sent me back my watch without any change, because battery fault has to be very serious to have warranty replacement. Anyway, now I’m in late…
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
