    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    Scheduled Pinned Locked Moved Suunto Vertical
    760 Posts 137 Posters 348.1k Views 114 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • sartoricS Offline
      sartoric Moderator @Marien Perrot
      @Marien-Perrot
      Have you ever tried to rtfm ? 😉
      SVTS - 2.50.28
      SSSWHR BARO Amber - 2.8.32
      Samsung A5 2016 - Android 7.0
      Suunto App Android 6.11.12 beta
      • ? Offline
        A Former User @Marien Perrot
        @Marien-Perrot press and hold the upper right button until the screen turns off and the Suunto logo appears, indicating a reboot.
        Marien PerrotM 1 Reply Last reply Reply Quote 1
        • cosme.costaC Offline
          cosme.costa
          I think battery drain issue is not yet solved.
          First of all my SVTS has notifications, sleep, 24/7 and backlight off.
          With the last firmware, just after the update, I did 20 days with around 13/14 hours of activities with GPS (7/8 of them with maps all the time and following a route) + 2 hours of non GPS activities. That is pretty good for me.
          But the last charge cycle have been 3.5 days, with 2.5 hours of GPS activities (1.5 hours with one route loaded but not used) and my watch is at 83%.
          Consumption during activities is normal and good as always.
          I’m quite sure that if I do a soft reset the consumption will be normal again. If someone needs logs, let me know.
          1 Reply Last reply Reply Quote 4
          • Marien PerrotM Offline
            Marien Perrot @Guest
            @iterumtenta Thx for your answer. Sorry I didn’t saw this possibility in the rtfm… My bad.
            Since the last charge 4 days ago, only one activity of 1h.
            Batterie is at 84%.
            So it’s mean 4% dicrease per day.
            I do soft reset after every activities since today because I’m expecting it will be better.
            Hope the new firm will correct this malfunction.
            O Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
            • O Offline
              Outdoorsy @Marien Perrot
              @Marien-Perrot I’ll be happy with 4% drop power day. Mine, since new, drops about 8% per day without any activity. I have the HR on and screen high on rise in. DND from 10pm to 5am set everyday.
              Previous: Ambit 2, Ambit 3 Peak HR, 9 Peak Pro
              Current: Vertical non-solar
                Dimitrios Kanellopoulos Community Manager @Marien Perrot
                @Marien-Perrot isn’t 4% ok ?
                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                Marien PerrotM SuperFlo75S K 3 Replies Last reply Reply Quote 0
                  Marien Perrot @Dimitrios Kanellopoulos
                  @Dimitrios-Kanellopoulos Hi ! I mean 4% is for me too high juste for Time, BT, HR and notifications. No other functions or options are selected. And I don’t do many activities per days or per weeks.
                  I don’t remember if that was the case when I bought the watch.
                  The only one boring thing is I have too do soft reset after every activities but is it the good thing to do ? I don’t think so.
                  But with all your sensations about batterie drain, I recognize that I’m not in a very bad situation.
                  sartoricS 1 Reply Last reply Reply Quote 1
                  • sartoricS Offline
                    @Marien-Perrot
                    Do you have sleep tracking enabled ?
                    HR 24/7 ?
                    BT 24/7 ?
                    Vibration? Sounds?
                    4% daily with some activities doesn’t look bad at all to me
                    It means 20 days to go from full to 20% … not even completely drained
                    SVTS - 2.50.28
                    Marien PerrotM 1 Reply Last reply Reply Quote 0
                      Marien Perrot @sartoric
                      @sartoric said in Battery drain:
                      @Marien-Perrot
                      HR 24/7 ?
                      BT 24/7 ?
                      Vibration? Sounds?
                      No sleep tracking
                      HR on and only in use if I’m wearing the watch
                      BT on but link is not in use when my phone is night off.
                      Vibration On
                      Sounds Off
                      For now I think draining is normally as you said.
                      But to have this, I do soft reset after every activities.
                      Is it the right thing to do ?
                      I think I won’t try to do some soft reset after the next charge.
                      • SuperFlo75S Offline
                        SuperFlo75 Silver Members Bronze Member @Dimitrios Kanellopoulos
                        @Dimitrios-Kanellopoulos I would say that 4% is worse than before the summer update… before this update which changed the watch faces, I had to charge every 4 weeks, and now the battery lasts about 3 to 3,5 weeks… without changing any settings…
                        Suunto Vertical 2 Titanium Sage
                        Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                        Suunto Wing
                        Suunto 9 Peak Pro Titanium (owns my wife now)
                        Suunto Spartan Ultra
                        SA iOS 3.12.0 (22937)
                        Instagram @superflo75
                        sartoricS SuperFlo75S 2 Replies Last reply Reply Quote 2
                        • sartoricS Offline
                          sartoric Moderator @SuperFlo75
                          @SuperFlo75
                          After a soft reset and no activities ?
                          Because there are still some drain issues, so it should be taken into consideration when doing comparisons
                          SVTS - 2.50.28
                            SuperFlo75 Silver Members Bronze Member @SuperFlo75
                            @sartoric I really think that there are still some drain issues… I do about 3 hours Running activity per week, HR is 24/7 on, sleep tracking is on, but normally I don’t do a soft reset… the only thing I changed now is that I use ZoneSense and the HR belt… I didn‘t use a belt before the ZoneSense app…
                            Suunto Wing
                            K 1 Reply Last reply Reply Quote 1
                            • K Offline
                              Kramble @Dimitrios Kanellopoulos
                              @Dimitrios-Kanellopoulos said in Battery drain:
                              Sadly, not, before battery drain, it was around 2 % with HR and BT 24/7 for sure.
                              The big drain is out but not the short one.
                              Ambit 3 peak saphir
                              Spartan Ultra (sold)
                              S7 graphite copper
                              S9 peak all black
                              Vertical titanium green forest
                              Wings
                              • K Offline
                                Kramble @SuperFlo75
                                @SuperFlo75 said in Battery drain:
                                Of course, Suunto announced 60 days of daily use when the vertical was out. And it was that until update caused battery drain.
                                Ambit 3 peak saphir
                                S7 graphite copper
                                S9 peak all black
                                Wings
                                • surfboomerangS Offline
                                  surfboomerang @thanasis
                                  @thanasis said in Battery drain:
                                  I think I identified a new pattern for the battery drain without actually starting the exercise
                                  Navigate to quick start menu of a exercise (eg running)
                                  Configure setting
                                  Abort (go back)
                                  Did it twice after I had resettled the watch from an exercise and I got like 1% drain per hour on idle
                                  @isazi Do you know if this one is also confirmed by Suunto (and not fixed yet)? I think I ran into the same issue last week.
                                  During an evening run, I enalbed the backlight of the watch during the activity. Afterwards, I went into the options of my running profile to check if it was a one time setting or that the backlight was enabled now for every future running activity. It was off, so I exited the config menu.
                                  After that, I noticed a huge battery drain of around 10% per day where 1-2% per day is my baseline.
                                  Suunto Vertical Titanium Solar
                                  OnePlus Nord 4
                                  • colakovitzC Offline
                                    colakovitz
                                    I charged my suunto vertical solar to 100% on 20.10.
                                    I do only weight exercises twice a week and have 24/7 hr and sleep tracking on. Battery is 20% at the time od writing this post. Maybe best solution would be to sell the watch and go back to garmin…
                                    sartoricS GiPFELKiNDG jjpazJ 3 Replies Last reply Reply Quote 2
                                    • sartoricS Offline
                                      sartoric Moderator @colakovitz
                                      @colakovitz said in Battery drain:
                                      Sure, if it will make you happy.
                                      SVTS - 2.50.28
                                      colakovitzC 1 Reply Last reply Reply Quote 1
                                      • GiPFELKiNDG Offline
                                        GiPFELKiND Silver Members @colakovitz
                                        @colakovitz seems that suunto cannot solve this drain issue 🤣 is your watch made in China? 🤣 Perhaps contact the chinese support 👋🏼
                                        If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                                        S 1 Reply Last reply Reply Quote -6
                                        • S Offline
                                          Shrek3k @GiPFELKiND
                                          Roughly 2 hrs activity with map and navigation, HRV with watch … end of the day, battery consumption was 9% … not really convincing 😕
                                          using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
                                          OS - Android 16/Pixel Pro 7
                                          • jjpazJ Offline
                                            jjpaz Bronze Member @colakovitz
                                            @colakovitz Suunto Vertical (no Solar) charged to 100% on october 22th.
                                            After 13h of activities (11h outdoors with GPS) battery is now at 34% (13 days). With these numbers I think I’ll recharge on thursday with battery around 20%. This is 15-16 days from full recharge. Before the summer upgrade I recharged watch every 18-20 days (4-4,5% battery cosumption every day), now I recharge every 15-16 days (around 5% battery consumption per day) so battery consumption is higher than before.
                                            Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
