    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 678.1k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • surfboomerangS Offline
      surfboomerang @freeheeler
      @freeheeler I always had it on low but I still have the feeling that it is much more sensitive than my S9P.
      Also, if I’m not mistaken, the high/low setting has nothing to do with the sensitivity but only with the intensity of the backlight
      Suunto Vertical Titanium Solar
      OnePlus Nord 4
      freeheelerF 1 Reply Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @surfboomerang
        @surfboomerang
        I did not read the manual yet 🙈 but I’ve tried while sitting at the desk and noticed that high/low must be the reactivity. otherwize it would be named bright/low?
        living sideways
        mikekoski490M 1 Reply Last reply Reply Quote 0
        • mikekoski490M Offline
          mikekoski490 Bronze Member @freeheeler
          @freeheeler
          From the manual 😊
          Automatic backlight
          The backlight has three features that you can adjust: the level of brightness (Brightness), how the standby backlight activates (Standby), and whether the backlight activates when you raise and turn your wrist (Raise to wake).
          The backlight features can be adjusted from the settings under General » Backlight.
          The Brightness setting determines the overall intensity of the backlight; Low, Medium or High.
          The Standby setting controls the screen brightness when there is no active backlight turned on (e.g. triggered by button presses). Standby can be toggled to on or off:
          On: Standby light is on all the time.
          Off: Standby light is off.
          The Raise to wake feature activates the backlight when raising your wrist to look at the watch. The three options for Raise to wake are:
          High: Raising your wrist activates high intensity backlight
          Low: Raising your wrist activates low intensity backlight. Note that this intensity is same as standby intensity, i.e. if standby light is set to ON, raising your wrist will not change the light.
          Off: Raising your wrist does nothing
          Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
          Current: Suunto Race Ti
          Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
          Suunto App running on Google Pixel 8/Android 14
          freeheelerF 1 Reply Last reply Reply Quote 3
            freeheeler @mikekoski490
            @mikekoski490
            I need to double check. I was convinced I notice it reducing the reactivity
            edit: ok, another test gave another impression 🙄
            … wishful thinking 😉
            living sideways
            • K Offline
              kamarasm Bronze Member
              Today is the first - since SV arrived - when we have clear sky here in Hungary. The weather forecast shows this for the coming night.
              Is this by design or a bug?
              (I mean sun icon can see for the whole night. I think a moon would be better choice. 😉
              ? isaziI 2 Replies Last reply Reply Quote 4
              • ? Offline
                A Former User @kamarasm
                @kamarasm It’s always sunny in Philadelphia Hungary.
                K 1 Reply Last reply Reply Quote 4
                • K Offline
                  kamarasm Bronze Member @Guest
                  @NickK Would be fine, but not. 😉
                  • isaziI Offline
                    isazi Moderator @kamarasm
                    @kamarasm known, the “clear sky” icon is a sun, even for the night
                    Blog: isazi's home
                    K 1 Reply Last reply Reply Quote 1
                    • K Offline
                      kamarasm Bronze Member @isazi
                      @isazi is there a plan to change it in the future?
                      • ? Offline
                        A Former User
                        I don’t want to create a new entry, but I think there’s a map bug. There are currently two New York states in the United States, one is slightly bigger than the other.
                        List with New York and New-York:
                        Two states that look fairly similar:
                        • MiniForkliftM Offline
                          MiniForklift Platinum Member
                          Sorry, had a quick search and can’t find the solution. What’s the deal if you’re just getting that awful grid in the background of a map? I tried loading up a route - which I can see but the only background behind it is a grid. No colours, markings… nothing. Updates have all been done and everything else seems okay, thanks in advance 👍
                          SV Titanium Solar Forest
                          isaziI 1 Reply Last reply Reply Quote 0
                          • herlasH Offline
                            herlas Silver Members @Likarnik
                            @Likarnik this is the screen we got when configuring the power zones, number was not displayed and when trying to exit, stuck on this message, 12 sec restart did it here to.
                            SRS Ti
                            SRun (primarily road runner so testing SRun is a must ;))
                            L 1 Reply Last reply Reply Quote 2
                            • isaziI Offline
                              isazi Moderator @MiniForklift
                              @MiniForklift first check this thread https://forum.suunto.com/topic/8851/no-map-problem/
                              Blog: isazi's home
                              MiniForkliftM 1 Reply Last reply Reply Quote 0
                                MiniForklift Platinum Member @isazi
                                @isazi said in Suunto Vertical: Bug Collection:
                                Thanks, yeah I have read through all of that thread but I’m obviously missing something. Even with GPS and Wifi I can’t get even a sniff of a map on the screen. I’m sure it’s likely user error rather than the watch but I’m not exactly sure what I’m not doing right as most people have seem to have found the maps pretty easy and intuitive
                                • K Offline
                                  During this morning training session I faced a very interesting behaviour.
                                  I could ran out from the map 🙂
                                  Got the feeling that this is just a render problem, so tried to:
                                  • zoom in, zoom out,
                                  • scroll on the map,
                                  • change display,
                                  • pause activity,
                                  • stop running and wait a bit,
                                    but nothing helped.
                                    Then - almost 20 mins, magically I putted back to the map and worked fluently until end of my session.
                                    Have anybody met with this?
                                  isaziI 1 Reply Last reply Reply Quote 2
                                  • isaziI Offline
                                    @kamarasm can you send where this happened, possibly with coordinates?
                                    Blog: isazi's home
                                    surfboomerangS K 2 Replies Last reply Reply Quote 0
                                      surfboomerang @isazi
                                      @isazi do you want this information for every occurrence?
                                      OnePlus Nord 4
                                      • K Offline
                                        @isazi it was here: 47,59863° N, 18,98694° E
                                        • isaziI Offline
                                          isazi Moderator
                                          @surfboomerang if there are spots where the maps don’t work, send logs (right after the activity) and share coordinates
                                          Blog: isazi's home
                                          surfboomerangS 1 Reply Last reply Reply Quote 0
                                            @isazi 👍 will do
                                            OnePlus Nord 4
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
