    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 724.6k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Kurt68K Offline
      Kurt68 @Ketoohs
      @Ketoohs I also run a marathon on Sunday only comfortably, but I would still not like to see it happen at the competition. 🤔
      KetoohsK surfboomerangS 2 Replies Last reply Reply Quote 0
      • jjpazJ Offline
        jjpaz Bronze Member
        Yesterday, first run with my new Vertical, I found another “surprise”: “The Schödinger’s Suunto+ Screen”.
        I selected one Suunto+ App before start the activity, Training Peaks Rythm, and started the activity. I switched between screens and didn’t find the S+ screen.
        In the middle of the run I accessed the Menu and verified that S+ App was selected. I went back to activity and from that moment the S+ screen was showed…
        At the end of the activity all the S+ App was recorded from the beginning of the activity so it was working but without its own screen.
        Also, my screen was in “white” mode and the “TP Rythm” screen was showed in “dark” mode, is thar normal? In S9P S+ screens are showed in the same mode (white or dark) that all the other screens, isn’t that?
        Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
        isaziI 1 Reply Last reply Reply Quote 0
        • KetoohsK Offline
          Ketoohs Silver Members @Kurt68
          @Kurt68 What I am thinking is that I am going to use the basic running mode from Suunto (despite creating a custom mode), and not including any S+ apps.
          Just so I minimize the chance of something happening.
          Karoo3 (2024)
          Vertical allBlack (2023)
          9 Peak Black (2022)
          Spartan WHR Black (2017)
          Ambit 2 Black (2013)
          • isaziI Offline
            isazi Moderator @jjpaz
            @jjpaz this is also known
            Blog: isazi's home
            D 1 Reply Last reply Reply Quote 1
            • surfboomerangS Offline
              surfboomerang @Kurt68
              @Kurt68 I did 2 runs with everything enabled (GPS performance mode, 2 S+ apps, navigation etc) and everything went very smooth.
              Oh, and I use a custom sport mode. Not the basic running profile.
              OnePlus Nord 4
              Ivan De RasisI Kurt68K 2 Replies Last reply Reply Quote 1
              • Ivan De RasisI Offline
                Ivan De Rasis @surfboomerang
                Ieri ho provato il mio Vertical Lime/Black, funziona tutto in maniera egregia… L’unica cosa che non mi ha calcolato è il valore di V2O nonostante abbia corso per 40 minuti in zona aerobica/anaerobica
                Suunto 9 Baro
                Suunto Vertical
                • Kurt68K Offline
                  Kurt68 @surfboomerang
                  @surfboomerang for me it was the 3rd run. The first 2 worked perfectly. But I’ve already read here that I’m not the only one where the vertical crashed.
                  runomaticR 1 Reply Last reply Reply Quote 0
                  • seanvkS Offline
                    seanvk
                    Maps: Downloaded one US state overnight - Nevada. Maps not visible. Powered on/off device. Maps not visible. Only black screen, no grid. Watch is trying to get fix.
                    After you download a map region, do you have to get a gps fix to see the map or can it use your last known location? I had a fix before last night so I thought it would use that.
                    Default HR Zones: set running HR zones first. Came back to Default HR Zones and only Max HR rate was set. Rest was — for HR and n/a for percentage. Powered on/off device. Default HR now filled in.
                    Suunto Race Titanium
                    Suunto 9 Peak Pro Forest Green
                    Suunto 9 Peak Moss Gray
                    • isaziI Offline
                      isazi Moderator @seanvk
                      @seanvk to see maps you need a GPS fix
                      Blog: isazi's home
                      seanvkS D 2 Replies Last reply Reply Quote 1
                      • seanvkS Offline
                        seanvk @isazi
                        @isazi Worked! Thank you
                        • V Offline
                          vlado
                          Did couple of steady runs, 30min, HR135-140 all was good except in each of those runs there was couple of peaks where HR jumps to 170, stays there couple of seconds and comes back to 140
                          Suunto Ocean
                          Suunto Vertical Solar Canyon
                          Suunto Ambit 3 peak Sapphire
                          J zhang965Z 2 Replies Last reply Reply Quote 0
                          • J Offline
                            jakubdr Bronze Member @vlado
                            @vlado said in Suunto Vertical: Bug Collection:
                            Can confirm, the same happened today to me (at one time it showed 210, which is not even my cadence, so it could not have locked to it). Also it seems that it has slower reactions to sudden spikes (e.g. uphill running).
                            • J Offline
                              jakubdr Bronze Member @Dimitrios Kanellopoulos
                              @Dimitrios-Kanellopoulos said in Suunto Vertical: Bug Collection:
                              @jakubdr Do not reconnect if possible. just do a fake activity
                              Second time was the charm. Very slow to upload though.
                                surfboomerang
                                The raise-to-wake feature is a little bit overreactive. Minimal movement enables the backlight. It also seems that the watch is ignoring the light sensor. Even with bright light the backlight is still enabled sometimes.
                                OnePlus Nord 4
                                freeheelerF 1 Reply Last reply Reply Quote 0
                                • L Offline
                                  Likarnik Gold Members
                                  Just checked my HR zones:
                                  I set them on initial setup 3 days ago, I wanted to tweak some values…
                                  sartoricS L 2 Replies Last reply Reply Quote 0
                                  • zhang965Z Offline
                                    zhang965 @vlado
                                    I get an opposite result, running above 170, hr back to 140.
                                    Winners Wear Winners
                                    • sartoricS Offline
                                      sartoric Moderator @Likarnik
                                      @Likarnik
                                      Did you reset the watch ?
                                      SVTS - 2.50.28
                                      SSSWHR BARO Amber - 2.8.32
                                      Samsung A5 2016 - Android 7.0
                                      Suunto App Android 6.11.8 beta
                                      L 1 Reply Last reply Reply Quote 0
                                      • L Offline
                                        Likarnik Gold Members @sartoric
                                        @sartoric yes, it worked like 3days ago when setting power zones (post earlier in this topic). Just posting info for devs, not sure if root cause is same for all zone types… I hope hotfix will get rid of all those bugs.
                                        F herlasH 2 Replies Last reply Reply Quote 0
                                        • F Offline
                                          Freezer Bronze Member @Likarnik
                                          Excessive battery drain of approx 5% per hour when using S+ apps (Decoupling & Fat Burner). First noticed after a run that the battery percentage was suspiciously low(er) after a 1 hour run. Tested it again yesterday - during a bike ride - with both S+ apps selected the battery drain was 5% per hour.
                                          Additionally neither of the apps functioned correctly as they were selected after the start of the exercise. Decoupling was waiting for the start of the activity and Fat Burner was not adding up any energy expenditure. As a side note - For the before-mentioned run both of these S+ apps were selected before the start of the exercise and seemingly functioned as intended - but the battery drain was also present.
                                          @isazi, has this been noted or should I open a new thread?
                                          • freeheelerF Offline
                                            freeheeler @surfboomerang
                                            @surfboomerang
                                            you can set it from high to low and it will work as we are used to 🙂
                                            living sideways
                                            surfboomerangS 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
