    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 678.1k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • L Offline
      Likarnik Gold Members @herlas
      @herlas yes, this is the screen.
      Another possible bug. I was weight training and put my Vertical on a shelf next to me as I always did with my S9B and S9P. I checked my hr every couple of minutes (screen went blank), but after certain time no hr was shown, only --. I was using H10 and was never more than 2m away. I could not to get it to work, so I ended activity and start new one, same belt, same position and it started measuring hr without problems. I was picking up my watch more often (prevent deep sleep?) and it went ok till end of my workout. Did it go to deep sleep and forget to measure hr? Never happened with previous watches when I did workouts up to 1.5h. Anyone else with this problem? I’ll try to reproduce it…
      • ? Offline
        A Former User @Likarnik
        @Likarnik Did happen to me several times with S9B a few years ago. First it would cut out, then report erratic measurements. In my case H10 died several sessions later. I’m talking pod, not a strap.
        Not saying this is your problem, but could be strap related and not a watch.
        • StangerS Offline
          Stanger
          Hey there,
          today, first time using my vertical outdoors on a 7h trailrunn. Back home i put it on the charger, and now it starts and stops the charging process again and again like forever. (screnn goes from charging, to menu and back again, with sound signal) A soft reset did not solved the problem.
          isaziI plopes73P 2 Replies Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @Stanger
            @Stanger it happens if the charger is not perfectly aligned, or if the contact points are dirty (somehow).
            Blog: isazi's home
            • Mff73M Offline
              Mff73
              Bug or not? Each time I want to use maps, I need to calibrate the compass. 😔.
              I didn’t put the watch on magnet charger since a while, so… It is not that.
              [edit] not each time, but way more often I was used to with S9PP
              SSU (retired), SV1, SV2
              Wife : S9PP
              SA: Always the latest beta :)
              Android + Galaxy S205G
              1 Reply Last reply Reply Quote 4
              • F Offline
                fritzbt2013 Bronze Member @Guest
                @NickK Any idea what the difference is between the two New York’s and which to download. I see they are both the same area. I was just going to download the one with the larger file size, perhaps it has a little more detail somewhere. I see you download both.
                Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                  Dimitrios Kanellopoulos Community Manager @fritzbt2013
                  @fritzbt2013 it should be fixed soon if not already
                  Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                  • plopes73P Offline
                    plopes73 @Stanger
                    @Stanger Hi,
                    Don’t know if it helps but I’ve had the same issue with S9P and found out that ir was the head charger as I used a cell phone fast charger. I’m not sure if these modern chargers need a certain amount of V, below those Volts they stop, then start, seconds after they stop…
                    Since I change the head charger for an old one from a nokia phone (Lumia) I never had that behaviour again.
                    Cheers
                    S9 Peak 2.18.18
                    Vertical
                    Android 10
                    Suunto App 4.45.5
                    StangerS 1 Reply Last reply Reply Quote 0
                    • grekuG Offline
                      greku Bronze Member
                      I observed that not all notification from phone are visible on the screen. I have an iPhone ,and I jumped from s9b and s9p ,so I notice that it’s different.
                      I have abit to check ‘the message’ / quick preview on the watch. When I go to second screen on vertical ( mid button 1 press) , all notification are there. It looks like not all of them shows at the main screen.
                      Also iOS suunto app (Im using beta versions ) not identity Vertical watch
                      • AlexndreA Offline
                        Alexndre
                        Hi, I’m Alex, French and new SV user after few Fenix…
                        I’m really happy with my new and first Suunto.
                        Nevertheless, I have some bugs…
                        1 - During the night, if I wake up and go for drink, sleep tracking stop…
                        2 - I ran during 1 hours / 10km… My SV give me more than 1400 cal ! It’s impossible !
                        Someone else have this bugs ?
                        Suunto Vertical
                        ChrisAC 1 Reply Last reply Reply Quote 0
                        • ChrisAC Offline
                          ChrisA Platinum Member @Alexndre
                          @Alexndre
                          1. I think that depends how active you are during that drinking. When you have to walk downstairs and upstairs again raising your HR etc. for example the Watch will assume you ended sleeping. Make sure the sleep times are set at least two hours before your actual sleep time and also look if your resting hr is correct (for me thats about 10 to 12 beats above the minimal HR at night.)
                          2. Weight, height, gender and age is correct? HR Zones are set up correctly (max HR) ?
                          Currently Race I
                          AlexndreA 1 Reply Last reply Reply Quote 2
                          • AlexndreA Offline
                            Alexndre @ChrisA
                            @ChrisA
                            Thanks for reply
                            1 - I set a new period for sleep tracking… hope it will be ok
                            2 - man, 38, 178cm, 90kg, HR zones set by default but seems ok
                            Suunto Vertical
                            • ChrisAC Offline
                              @Alexndre you may try the anaerobic threshold test from the SuuntoPlus Store for more accurate HR settings.
                              Currently Race I
                              AlexndreA 1 Reply Last reply Reply Quote 1
                              • J Offline
                                Jole13
                                I went for a walk today. 1.72km and the watch recorded 392 steps. I assume this is a bug.
                                • AlexndreA Offline
                                  Alexndre @ChrisA
                                  @ChrisA
                                  Ok i’ll try thx 😉
                                  Suunto Vertical
                                  • surfboomerangS Offline
                                    surfboomerang
                                    I noticed that the watch sometimes doesn’t lock after a minute of inactivity on the watchface. It keeps showing the seconds in the display.
                                    After swiping the touchscreen or pressing the button, the watch is functioning normal again and locks after a minute.
                                    Not confirmed but highly suspected is that the watch is even unlocking itself sometimes. I’m pretty sure I didn’t press any buttons, but still see the seconds displayed on the watchface.
                                    Suunto Vertical Titanium Solar
                                    OnePlus Nord 4
                                    isaziI 1 Reply Last reply Reply Quote 0
                                    • isaziI Offline
                                      isazi Moderator @surfboomerang
                                      @surfboomerang which watchface? It never happened to me, and I usually use the new one.
                                      Blog: isazi's home
                                      surfboomerangS D 2 Replies Last reply Reply Quote 0
                                        surfboomerang @isazi
                                        @isazi I also use the new watchface (the one with the solar bars). I don’t see it very often, but will try to capture it when it happens again
                                        OnePlus Nord 4
                                        • ChrisAC Offline
                                          ChrisA Platinum Member @surfboomerang
                                          @isazi I have „gaps“ in the Resources (on the watch and corresponding in the app )
                                          I never had this with other Suuntos. Is this happening to others too? Does not bother me too much, but maybe a small bug, so reported here.
                                          Currently Race I
                                          GiPFELKiNDG D isaziI ? 5 Replies Last reply Reply Quote 1
                                          • GiPFELKiNDG Offline
                                            GiPFELKiND Silver Members @ChrisA
                                            @ChrisA I see this on my app too 🤔🙈
                                            If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
