    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 725.9k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • L Offline
      lauser Bronze Member
      • S+ App CoreBodyTemp stays in “calculating” and does not show any values or even records them
      • S+ App Climb sometimes has some UI glitches in the top/top left corner where number of climbs are shown on the wrong position
      • Maps sometimes disappear and reappear again in a non-reproducable way
      Bugs already reported to Suunto via press SPOC
      ChrisAC Luís PintoL S BrunoHB Martin VrskaM 6 Replies Last reply Reply Quote 0
      • ChrisAC Online
        ChrisA Platinum Member @lauser
        @trailcafe i cant make maps work at all. Tried twice (here’s what I do:)
        • Set up wlan connection
        • choose region I am in
        • watch starts downloading, app shows progress
        • watch reports download complete
        • when going outdoors, theres just no map on the watch, neither with or without workout active. Zoomed in and out and panned around, no map. GPS position is correct.
        Any hints? Bug?
        Currently Race I
        zhang965Z Brad_OlwinB 2 Replies Last reply Reply Quote 1
        • zhang965Z Offline
          zhang965 @ChrisA
          @ChrisA said in Suunto Vertical: Bug Collection:
          Any hints? Bug?
          Have you contacted suunto support?
          Winners Wear Winners
          ciniak77C 1 Reply Last reply Reply Quote 0
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @ChrisA
            @ChrisA Is Navigation on in the watch and do you have maps on and a map selected (Outdoor, etc.)? Or scroll down from main menu to Map and select allow a GPS fix and there should be a map.
            Vector/T6c/Vertical 2 Ti
            • S Offline
              SirMcKey Bronze Member
              Good morning,
              god my beautiful SV yesterday at 11 0´clock. Downloaded one region of the map: Germany, “Regierungsbezirk Stuttgart”.
              Tried it two times, but there´s no map showing on the watch. Everything as described above. A bug? Or am I a little bit stupid ? 🙄
              ChrisAC EgikaE 2 Replies Last reply Reply Quote 1
              • L Offline
                You are all on FW 2.25.48 I assume.
                With a former FW version I had the same issue but with a full reset (General -> Reset settings) it worked. Maybe try a soft reset (hold upper button for 12sec) first and have a loom it works!?
                ChrisAC 1 Reply Last reply Reply Quote 0
                • ChrisAC Online
                  ChrisA Platinum Member @SirMcKey
                  @SirMcKey same here, for me its the neighbouring ‘Regierungsbezirk Tübingen’. Is this a problem with the southern German areas?
                  Will try a hardreset as @trailcafe recommends.
                  Currently Race I
                  • ChrisAC Online
                    @trailcafe yes, firmware 2.25.48. Will try a hard reset later today.
                    Currently Race I
                    freeheelerF 1 Reply Last reply Reply Quote 0
                    • freeheelerF Offline
                      freeheeler @ChrisA
                      @ChrisA
                      please get in touch with @Dimitrios-Kanellopoulos prior to hard reset ✊
                      living sideways
                      • V Offline
                        vlado
                        I know it is not that important but do you guys have icon on watchface for missed notification, i dont?
                        Suunto Ocean
                        Suunto Vertical Solar Canyon
                        Suunto Ambit 3 peak Sapphire
                        surfboomerangS 1 Reply Last reply Reply Quote 0
                        • surfboomerangS Offline
                          surfboomerang @vlado
                          @vlado No, there is a separate widget for that.
                          Suunto Vertical Titanium Solar
                          OnePlus Nord 4
                          V 1 Reply Last reply Reply Quote 0
                          • V Offline
                            vlado @surfboomerang
                            @surfboomerang does not have that much sense but ok
                            Suunto Ocean
                            • L Offline
                              Likarnik Gold Members
                              I had bug when I tried to set running power zones for the first time. There were no default zones set, only – instead of number. When I set all of them, none was displayed and I could not go back, because error was popping up, something like ‘you must set distinct power zones’ or similar (like zones were overlaping). I was stuck, only 12s upper button with soft reset saved me and after reboot there were problems setting zones. I did not take pictures as I said to myself, if I can reproduce it, then I’ll send the bug 🙂
                              jjpazJ 1 Reply Last reply Reply Quote 4
                              • V Offline
                                vlado
                                Also missed call notification on the widget still no possibility to remove
                                Suunto Ocean
                                renton82R 1 Reply Last reply Reply Quote 0
                                • Dimitrios KanellopoulosD Dimitrios Kanellopoulos moved this topic from Watches on
                                • KetoohsK Offline
                                  Ketoohs Silver Members
                                  Regarding notifications. Does anybody else notice, that notifications are worse than on your previous watch (9p). Sometimes the notification is lagging and sometimes it does not even arrive (Outlook, Viber). On the 9p it was spot on.
                                  Karoo3 (2024)
                                  Vertical allBlack (2023)
                                  9 Peak Black (2022)
                                  Spartan WHR Black (2017)
                                  Ambit 2 Black (2013)
                                  zhang965Z surfboomerangS 3 Replies Last reply Reply Quote -1
                                  • zhang965Z Offline
                                    zhang965 @Ketoohs
                                    @Ketoohs said in Suunto Vertical: Bug Collection:
                                    My S9PP had getting notifications for first months, and now I don’t get any notification, I don’t know why.
                                      surfboomerang @Ketoohs
                                      @Ketoohs Yes, noticed it once this morning. Thought nothing of it but I will keep an eye on it.
                                      OnePlus Nord 4
                                      • renton82R Offline
                                        renton82 Platinum Member @vlado
                                        @vlado said in Suunto Vertical: Bug Collection:
                                        The Return of living dead notifications 😂 ! I noticed it as well!
                                        • EgikaE Offline
                                          Egika Platinum Member @SirMcKey
                                          @SirMcKey hey! Following up from our FB conversation here:
                                          Can you please do the following:
                                          • bring up maps screen (with or without activity)
                                          • pan and zoom around
                                          • if you get only the grid display:
                                            Watch back to watch face
                                            Connect to Suunto app
                                            Send logs from the Suunto App
                                            Tell me the email of your SA account in a private message and approx time when you sent the logs.
                                          Thx!
                                          • M Offline
                                            Mi_chael Bronze Member
                                            If i select a map to download before i set a wifi connection, the iOS app tell that the watch is busy and nothing happens.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
