    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch
    Scheduled Pinned Locked Moved Suunto Vertical
    186 Posts 57 Posters 43.0k Views 52 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • AntoineA Offline
      Antoine Bronze Member @gone troppo
      @gone-troppo said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
      44% to 4% in last 24 hours wtf is going on? I have tried every possible fix to that this forum and fb groups have recommended and nothing works. Is suunto aware of this issue? Is there a fix coming for it ? My suunto vertical which was so great when it was released is now nothing more than an Apple Watch that needs constant charging. I have been with suunto for many years but this is a disgrace. My old ambit 3 peak doesn’t have these issues. I love the suunto app and how suunto ecosystem is I don’t want to change but this is borderline unusable. Watch drains more than 1% per hour when not even doing anything and every battery sucking setting disabled. What a joke
      You can stop (throught parameters) and restart the watch. It seems it has solved temporarily the problem… (now 4% in 24h as before).
      But sure there is something to correct, because before restart i was at more than 12% per 24h.
      I hope that suunto team is avare of that and it will be solved soon.
      Suunto vertical solar
      Coros arm HRM / Suunto wing 2
      Android A55 Samsung
      Suunto App latest official update
      F 1 Reply Last reply Reply Quote 0
      • F Online
        fedequei @Antoine
        @Antoine said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
        what do you mean with “You can stop (throught parameters) and restart the watch”, doing a hard reset?
        thanks!
        gone troppoG AntoineA 2 Replies Last reply Reply Quote 0
        • gone troppoG Offline
          gone troppo Bronze Member @fedequei
          I’ve decided to send my watch back to suunto after talking to suunto support. Let’s see what they come back with.
          F Max maxilifeguardM 2 Replies Last reply Reply Quote 1
          • F Online
            fedequei @gone troppo
            @gone-troppo let us know!
            • Max maxilifeguardM Offline
              Max maxilifeguard @gone troppo
              @gone-troppo Be patient, in total it’s been more than two months since the first repair, now it’s been another month since I sent it to be repaired for the second time, and they don’t know when it will be ready, Suunto’s repair service is a disgrace… it’s going to be the last time I buy a product from this brand, in my case Suunto Vertical Titanium
              Suunto vertical titanium
              Lifeguard 🛟🛟🛟 Guardavidas 🇦🇷🇦🇷🇦🇷
              Surfing, climbing and exploring the word 🏄🏽‍♂️🧗🏼‍♂️⛵️🛟🗺️
              gone troppoG 1 Reply Last reply Reply Quote 0
              • AntoineA Offline
                Antoine Bronze Member @fedequei
                @fedequei said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                thanks!
                On Vertical :
                Parameters->general->stop the watch
                Then restart (6s on upper right button)
                Android A55 Samsung
                SquirrelS 1 Reply Last reply Reply Quote 0
                • SquirrelS Offline
                  Squirrel Silver Members @Antoine
                  On Vertical :
                  In English:
                  Settings > General > Power off
                  But you can simply achieve the same by holding the top button for about 12 seconds to restart / soft reset.
                  Race S
                    gone troppo Bronze Member @Max maxilifeguard
                    @Max-maxilifeguard said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                    Oh no I don’t want to hear this what the heck!!! I don’t know what else to do my $1000 plus watch I bought two years ago went through another 36% battery in last 24 hours it’s stuffed. I will likely be moving away from sunnto after this watch as well. My ambit 3 peak is a more reliable unit then the vertical more than 10 years old.
                    • Mahatma BonsiM Offline
                      Mahatma Bonsi
                      Have someone tried 60 seconds upper button reset? I think it worked for my Vertical.
                      The watch must be on the charger. You have to press and keep pressed the upper button for 60 seconds. It will reboot after 12 seconds, but you must keep pressing the button. It will perform several reboots. Take the time with a clock. I pressed for 62 seconds to be sure.
                      My watch used to discharge 12% about every day.
                      After this I came back to 3% about.
                      And after months I didn’t see 100% battery but only 99%, it finally now fully charge up to 100%.
                      B safariS 2 Replies Last reply Reply Quote 0
                      • B Offline
                        buttercup_alex @Mahatma Bonsi
                        @Mahatma-Bonsi
                        Hi, I’ve tried this option, but for my Race watch.
                        Unfortunately, it didn’t solve the issue.
                        Also, tried hard reset on weekend, at first I thought that it was a solution, but after a night with sleep tracking, the battery was drained about 25-30%.
                        hope that the next update will fix this issue
                        Mahatma BonsiM 1 Reply Last reply Reply Quote 0
                        • safariS Online
                          safari @Mahatma Bonsi
                          @Mahatma-Bonsi
                          I walked for a total of 6 hours over the weekend with the HR Belt. I also used it as a watch for two days, with sleep tracking and notifications turned on.
                          I left Saturday morning at 100%, and when I got home Sunday night, it was at 80%. I think that’s a decent battery drain.
                          But every Belt battery was at 100%, and after 6 hours of use, it was at 70%. 🙂
                          history:
                          Suunto Vertical 2 titanium Black
                          suunto vertical solar titanium
                          suunto 9 baro
                          suunto ambit 3
                          suunto ambit 2
                          Suunto Heart Rate Belt
                          Suunto Smart Heart Rate Belt
                          suunto App: apple iphone 14 pro
                          • Stefan KerstingS Offline
                            Stefan Kersting Platinum Member
                            I tried an hard and a soft reset and it didn’t solved the battery drain problem. After some hikes of 3 hours at the weekend the battery doesn’t last even a week. In my opinion not acceptable
                            Instagram: https://www.instagram.com/helgelandsbukken/
                            https://www.instagram.com/suunto_adventures/
                            IG: Helgelandsbukken, suunto_adventures
                            Vimeo: vimeo.com/helgelandsbukken
                            Blogg: https://turblogg.midnattsola.com
                              Mahatma Bonsi @buttercup_alex
                              @buttercup_alex sorry, I forgot to say that the watch must be on the charger
                                gone troppo Bronze Member @Mahatma Bonsi
                                @Mahatma-Bonsi said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                                Yep I already tried this too didn’t work. I tried every single possible option from this forum and the various fb groups none worked
                                K 1 Reply Last reply Reply Quote 0
                                • K Offline
                                  Kramble @gone troppo
                                  I can confirm battery drain even after last hot fix update.
                                  Ambit 3 peak saphir
                                  Spartan Ultra (sold)
                                  S7 graphite copper
                                  S9 peak all black
                                  Vertical titanium green forest
                                  Wings
                                  Stefan KerstingS F 2 Replies Last reply Reply Quote 0
                                    Stefan Kersting Platinum Member @Kramble
                                    @Kramble I can confirm the same
                                    • OutdoorManO Offline
                                      OutdoorMan Silver Members
                                      This affects also other watches, not only Vertical.
                                      K 1 Reply Last reply Reply Quote 1
                                      • K Offline
                                        Kramble @OutdoorMan
                                        @OutdoorMan Pfffffffff…
                                        Ambit 3 peak saphir
                                        S7 graphite copper
                                        S9 peak all black
                                        Wings
                                        • F Online
                                          fedequei @Kramble
                                          @Kramble I confirm same for me! incredible…
                                          • D Offline
                                            ddamico
                                            For me, on a Race 1, the battery drain actually seems quite a bit worse after the update. “For what it’s worth”.
                                            CharlesC 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
