    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch
    Scheduled Pinned Locked Moved Suunto Vertical
    186 Posts 57 Posters 45.9k Views 52 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • F Offline
      fedequei @jjpaz
      @jjpaz I actually have an iPhone… so after each activity, do you go to Settings → Connectivity → Paired devices and unpair everything that’s listed?
      And do you also perform a soft reset, which in any case resets the daily energy levels to 70% and messes up all the stats?
      jjpazJ 1 Reply Last reply Reply Quote -1
      • PavlasP Offline
        Pavlas @jjpaz
        @jjpaz I find that a very interesting thought. 👍
        🔺Vertical All Black
        ex:
        Ambit2 Black
        Ambit3 Peak Sapphire
        Spartan Ultra Stealth Titanium
        S9B All Black
        Ocean All Black (for testing only)
        >>> YouTube Channel <<<
        • E Offline
          Elipsus Gold Members @jjpaz
          @jjpaz said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
          (I’m wearing Race S for sleep tracking).
          I think this is pretty important, it seems that HRV tracking takes a toll on the battery, so if you don’t use the Vertical for sleep tracking that could explain why your battery drain is lower than what is obsreved on this thread
          jjpazJ 1 Reply Last reply Reply Quote 1
          • jjpazJ Offline
            jjpaz Bronze Member @fedequei
            @fedequei No, I don’t unpair devices, I keep then paired. I power off the BT device (turn off Coospo armband or disconnect H10 sensor in my case) and then I soft reset Vertical watch. With this process SV doesn’t try to connect to BT devices until I start a new activity. If I don’t reset the watch it tries to connect to BT devices even in watchface mode and draining battery.
            Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
            • jjpazJ Offline
              jjpaz Bronze Member @Elipsus
              @Elipsus I was wearing SV for sleep tracking several weeks ago and battery drain was around 1-2% by night (5-6% daily) so there wasn’t a huge difference. The big difference is if I don’t reset the watch and keeps trying to connect to the BT devices. In that case my daily battery drain was around 17-20% (with same sw version)
              • K Offline
                Kramble @jjpaz
                @jjpaz I am on Android and I do have battery drain
                Ambit 3 peak saphir
                Spartan Ultra (sold)
                S7 graphite copper
                S9 peak all black
                Vertical titanium green forest
                Wings
                • F Offline
                  fedequei @fedequei
                  @fedequei
                  After unpairing all Bluetooth devices from the watch, including the Suunto app itself (I also forgot the Suunto watch from my iPhone’s Bluetooth list), yesterday at 11:30 a.m. — this morning at 8:00 a.m. I was already down to 17%. So I lost another 10% (a bit more) in 24 hours. There’s clearly another issue that’s not related to Bluetooth.
                  sebchastangS 1 Reply Last reply Reply Quote 0
                  • sebchastangS Offline
                    sebchastang Silver Members @fedequei
                    @fedequei Have you restarted your watch after unpairing all Bluetooth devices? (To make sure there is no more Bluetooth related process still running in background)
                    Suunto Traverse
                    F 1 Reply Last reply Reply Quote 0
                    • F Offline
                      fedequei @sebchastang
                      @sebchastang Yes, I did that at 14:00
                      • inkognitoI Offline
                        inkognito Platinum Member
                        Has anyone tried using a different watch face? I’m wondering if certain faces or complications can be causing the drain with newer firmware versions…
                        SV: fingers crossed :D
                        S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
                        Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
                        Despite some pretty bad luck, I still love Suunto!
                        BelialB 1 Reply Last reply Reply Quote 1
                        • BelialB Offline
                          Belial @inkognito
                          @inkognito yes, I’ve changed the watchface for the least-demanding: only time and date. First, it seemed to help a bit (instead of 10-12%/24h consumption was about 6-8%). Now, after the night with DND-on , watch used 8% 😞
                          I was considering buying Vertical 2 but, to be honest, something wrong is going on with Suunto’s software development 😞
                          • JonasLarssonJ Offline
                            JonasLarsson
                            Has anyone tried standing on one leg screaming this sucks?
                            Vertical 2
                            1 Reply Last reply Reply Quote 7
                            • thanasisT Offline
                              thanasis Bronze Member
                              I think the sensitivity of the backlight has changed . I believe the watch has somehow become more sensitive in turning the backlight on
                              Ars VitaeA 1 Reply Last reply Reply Quote 0
                              • Ars VitaeA Offline
                                Ars Vitae Silver Members @thanasis
                                @thanasis What do you mean exactly? In what sense sensitive?
                                thanasisT 1 Reply Last reply Reply Quote 0
                                • thanasisT Offline
                                  thanasis Bronze Member @Ars Vitae
                                  @Ars-Vitae it’s easier to be turned on . I believe (as far as I can tell with one device ) that the backlight is turning on more times that it used to
                                  • Stefan KerstingS Offline
                                    Stefan Kersting Platinum Member
                                    @Dimitrios-Kanellopoulos
                                    Yesterday I used my polar h10 chest strap but the h10 was attached to the belt with at just one point, not at to. I do this usually to avoid that the watch and the belt try to connect via Bluetooth to avoid battery drain in my chest strap. But now my watch really often did a “beep” sound without showing something on the watch. After beeing very annoyed I set my watch into flight mode and there was no more beeping. So I think there’s an Bluetooth issue. Now I have disconnected the chest strap and set the watch in flight mode all the time. Will see if this affects battery drain.
                                    Instagram: https://www.instagram.com/helgelandsbukken/
                                    https://www.instagram.com/suunto_adventures/
                                    IG: Helgelandsbukken, suunto_adventures
                                    Vimeo: vimeo.com/helgelandsbukken
                                    Blogg: https://turblogg.midnattsola.com
                                    JacobusJ 1 Reply Last reply Reply Quote 1
                                      @Dimitrios-Kanellopoulos All right, I charged med watch sunday 12.10. 100 % at 19.00. Have 24/7 OHR and had the watch in flight mode all the time. Monday 13.10. 99 % left. That means 1 % battery drain in 16 hours vs. 12 % battery drain a day with blutooth connection on. See my previous post about the behaviour of the HR belt. I think the hotfix has to handle that in order to stopp the battery drain after tha last update.
                                      BelialB 1 Reply Last reply Reply Quote 3
                                      • BelialB Offline
                                        Belial @Stefan Kersting
                                        @Stefan-Kersting I have something interesting 🙂
                                        I’ve tried the same approach with Flight mode - watch is draining as before and syncing (or trying to sync to be more precise) despite flight mode on. I don’t know how this is even possible.
                                        Stefan KerstingS Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 1
                                          Stefan Kersting Platinum Member @Belial
                                          @Belial how is this even possible?
                                          OutdoorManO 1 Reply Last reply Reply Quote 0
                                          • OutdoorManO Offline
                                            OutdoorMan Silver Members @Stefan Kersting
                                            @Stefan-Kersting @Belial I think it was discussed somewhere recently, but I cannot find it. But… if you turn off airplane mode via control panel, then all the connections remain on. But if you do it via Settings - Connectivity - Airplane mode, then it turns everything off. I don’t know if it’s a bug or working as designed.
                                            SquirrelS 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
