    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch
    Scheduled Pinned Locked Moved Suunto Vertical
    186 Posts 57 Posters 45.9k Views 52 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • CharlesC Offline
      Charles Bronze Member @ddamico
      Same problem for me. battery drains à around 1% an hour during daytime, 0.5% per hour during the night.
      I’m pretty unlucky since I already had a sync problem last year with a new update.
      • Stefan KerstingS Offline
        Stefan Kersting Platinum Member
        support recommended a hard reset. Anybody done that?
        Instagram: https://www.instagram.com/helgelandsbukken/
        https://www.instagram.com/suunto_adventures/
        IG: Helgelandsbukken, suunto_adventures
        Vimeo: vimeo.com/helgelandsbukken
        Blogg: https://turblogg.midnattsola.com
        OutdoorManO 1 Reply Last reply Reply Quote 0
        • OutdoorManO Offline
          OutdoorMan Silver Members @Stefan Kersting
          @Stefan-Kersting got same feedback and not going to do that.
          Stefan KerstingS CharlesC 2 Replies Last reply Reply Quote 0
            Stefan Kersting Platinum Member @OutdoorMan
            @OutdoorMan what is the problem with a hard reset? Never don it…
            • F Offline
              fedequei
              This is the situation after the last 100% charge on September 17.
              On September 25 I installed the update, and in the following days I didn’t do any sports due to illness.
              The battery consumption still seems very high to me, as I was used to much longer battery life until June
              • CharlesC Offline
                Charles Bronze Member @OutdoorMan
                @OutdoorMan Well you would lose all your recorded data without any garantee that the reset will fix the problem
                  @Stefan-Kersting basically a factory reset = all data gone, I believe you’ll need to calibrate your HRV for two weeks and such things. So nope.
                  Stefan KerstingS 1 Reply Last reply Reply Quote 0
                    @OutdoorMan ok, that is not an option
                    gone troppoG 1 Reply Last reply Reply Quote 0
                    • gone troppoG Offline
                      gone troppo Bronze Member @Stefan Kersting
                      @Stefan-Kersting said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                      It won’t work anyway didnt for me
                      • K Offline
                        Kramble
                        Without activities, OHR 24, I have 6 % per day , it was 3 % before the update. I don’t use any belt or other Bluetooth…
                        Ambit 3 peak saphir
                        Spartan Ultra (sold)
                        S7 graphite copper
                        S9 peak all black
                        Vertical titanium green forest
                        Wings
                        • K Offline
                          Kramble
                          Anybody knows if Suunto is aware of this battery drain issue ?
                          Ambit 3 peak saphir
                          S7 graphite copper
                          S9 peak all black
                          Wings
                          • Sergey BalbirS Offline
                            Sergey Balbir
                            There is definitely a problem with the algorithm that estimates the battery level. The watch needs to be reset from time to time to recalibrate. The reset itself is not safe and can cause the watch to stuck in a “recovery loop”.
                            I don’t think it is relevant to some specific version update (but might be related to the update process or even to a simple on/off ) and this also seems to happen on all the Suunto models.
                            This situation is quite disappointing for me because one of the major pros to go with Suunto was the promised battery life 😞
                            thanasisT 1 Reply Last reply Reply Quote 1
                            • thanasisT Offline
                              thanasis Bronze Member @Sergey Balbir
                              @Sergey-Balbir I think there is an issue lately though. I get significantly higher consumption per day despite trying to deplete the the battery and recalibrate . I even started thinking it may have been some change in the throttling of the the cpu to support the ui smoothness . I don’t believe that it was on purpose to promote the newer generation of the watches as I have read on some other posts in social media
                              Mff73M 1 Reply Last reply Reply Quote 2
                              • Mff73M Offline
                                Mff73 @thanasis
                                @thanasis said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                                . I don’t want to think that it was on purpose to promote the newer generation of the watches as I have read on some other posts in social media
                                If you don’t want to think, why would not not want to write it?
                                No specific to you only, but could one really think that (thus write it) “bugs” are introduced on purpose. Come on…
                                SSU (retired), SV1, SV2
                                Wife : S9PP
                                SA: Always the latest beta :)
                                Android + Galaxy S205G
                                • thanasisT Offline
                                  thanasis Bronze Member @Mff73
                                  @Mff73 said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                                  (Btw I edited my post prior to your reply , but yet I think I need to clarify )
                                  Since the new watches are currently based on the same platform you could argue that one (the people developing it ) ) does not care on the impact the implementation has on previous models because they want to promote the new ones . Not that you create bugs so that you ruin the experience on purpose . It’s an argument that you can purposely take : we need to have consistent experience hence the old ones need to take a hit on something … aka the battery life .
                                  M 1 Reply Last reply Reply Quote -3
                                  • K Offline
                                    Kramble
                                    Full cycle battery, 20 days with OHR24 and three activities each week (same time as usual since 2 years).
                                    It used to be 30 days before the last update since the precedent fix drain battery issue about one year ago.
                                    Ambit 3 peak saphir
                                    S7 graphite copper
                                    S9 peak all black
                                    Wings
                                    • M Offline
                                      MeazzaS9 @thanasis
                                      @thanasis The battery issue has already happened a few updates ago, Suunto doesn’t want the battery to last less, they will try to fix it as soon as possible as battery life is one of the strong points of our watches.
                                      Suunto Race S Gravel Gray (2024)
                                      Suunto Vertical Black Lime (2023)
                                      Suunto 7 Graphite Copper (2021)
                                      Suunto 9 Baro Black (2020) sold
                                      F 1 Reply Last reply Reply Quote 3
                                      • F Offline
                                        fedequei @MeazzaS9
                                        @MeazzaS9 I hope so, i’m still stuck in 10% day with my vertical solar
                                        M 1 Reply Last reply Reply Quote 1
                                        • M Offline
                                          MeazzaS9 @fedequei
                                          @fedequei I honestly waited to update (set it to non-automatic) as soon as I read about the problem. They’re definitely already working on it.
                                          OutdoorManO K 2 Replies Last reply Reply Quote 0
                                            OutdoorMan Silver Members @MeazzaS9
                                            @MeazzaS9 and where is this information coming from?
                                            M 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
