    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch
    Scheduled Pinned Locked Moved Suunto Vertical
    186 Posts 57 Posters 45.4k Views 52 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
      Dimitrios Kanellopoulos Community Manager @Belial
      @Belial yes please validate its turned on
      Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
      BelialB 1 Reply Last reply Reply Quote 0
      • BelialB Offline
        Belial @Dimitrios Kanellopoulos
        @Dimitrios-Kanellopoulos said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
        I’m sure the switch was active (in control panel).
        Now I’ve checked, it’s still on and watch is syncing, with connection icon displayed on watchface 🙂
        • SquirrelS Offline
          Squirrel Silver Members @OutdoorMan
          @OutdoorMan said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
          if you turn off airplane mode via control panel, then all the connections remain on. But if you do it via Settings - Connectivity - Airplane mode, then it turns everything off. I don’t know if it’s a bug or working as designed.
          Surely a bug in the watch firmware. In Control panel it simply doesn’t work despite showing the switch as enabled.
          @Belial said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
          Well then disable it in Control panel, then go to Settings > Connectivity > Airplane mode and enable it there. Double check that it can not connect to phone, and then monitor power consumption.
          Race S
          gone troppoG 1 Reply Last reply Reply Quote 0
          • gone troppoG Offline
            gone troppo Bronze Member @Squirrel
            I’ve tried turning aeroplane mode on mine in the settings that did not stop the battery drain.
            • F Offline
              fedequei
              I’m also trying to test leaving the watch in airplane mode, but I don’t see any real improvement — maybe about 1% less battery drain per day, but it still loses around 8% daily.
              Please, Suunto, do something about this… it’s really starting to get annoying.
              • thanasisT Offline
                thanasis Bronze Member
                putting the watch into energy saving mode works like a charm . So it’s obviously some process (?) that is consuming the battery
                • JacobusJ Offline
                  Jacobus @Stefan Kersting
                  @Stefan-Kersting I used to do this in the past, attaching it to a single button, but it would then try to connect, so I’ve since removed it entirely.
                  This has nothing to do with the latest update.
                  • Stefan KerstingS Offline
                    Stefan Kersting Platinum Member
                    After almost exactly 72 hours I have left 91 % and to hours of gps activity included the watch used 9 % energy. In my opinion there s something wrong with the Bluetooth WiFi connection. Airplane mode always on
                    Instagram: https://www.instagram.com/helgelandsbukken/
                    https://www.instagram.com/suunto_adventures/
                    IG: Helgelandsbukken, suunto_adventures
                    Vimeo: vimeo.com/helgelandsbukken
                    Blogg: https://turblogg.midnattsola.com
                    • surfboomerangS Offline
                      surfboomerang
                      For reference…
                      I’m not suffering from the battery drain and have these connectivity settings configured:
                      Airplane mode: off
                      Paired devices: Mobile app
                      Wireless network: On/Auto
                      Discovery: Off
                      Suunto Vertical Titanium Solar
                      OnePlus Nord 4
                      K 1 Reply Last reply Reply Quote 0
                      • K Offline
                        Kramble @surfboomerang
                        @surfboomerang Can you be more precise? OHR 24 ? sleep tracking? daily battery consumption without activities ?
                        Thanks
                        Ambit 3 peak saphir
                        Spartan Ultra (sold)
                        S7 graphite copper
                        S9 peak all black
                        Vertical titanium green forest
                        Wings
                        surfboomerangS 1 Reply Last reply Reply Quote 0
                          surfboomerang @Kramble
                          @Kramble
                          24/7 OHR: Off
                          Sleep tracking: Off
                          Notifications: On
                          Daily consumption: 2-3% (with almost no solar power)
                          OnePlus Nord 4
                          M 1 Reply Last reply Reply Quote 0
                          • M Offline
                            maszop Bronze Member @surfboomerang
                            @surfboomerang If you turn everything off and use it like a Casio watch from the 1990s, it’s no wonder that the battery drain problem doesn’t occur 🙂
                            E L 2 Replies Last reply Reply Quote 8
                            • E Offline
                              Elipsus Gold Members @maszop
                              @maszop and Casios have 10 years battery life (with probably a smaller battery)
                              M 1 Reply Last reply Reply Quote 3
                              • M Offline
                                maszop Bronze Member @Elipsus
                                @Elipsus Apples to apples, not oranges.
                                • L Offline
                                  Luis Andés Olmedo Bronze Member @maszop
                                  @maszop said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                                  Casios had no GPS 🙂
                                  I do have exactly the same settings as @surfboomerang. Well, in fact no… my notifications are OFF 😛
                                  • F Offline
                                    fedequei
                                    I’ve also tried unpairing all Bluetooth devices and changing the watch face, but the result is the same… I can see there are now reports about the Vertical 2 as well, so I really hope they’re working on a solution.
                                    • F Offline
                                      fedequei
                                      Shall we give up on the reports in this thread? Should we wait for the December update and hope they’ve figured out what’s causing the problem?
                                      OutdoorManO W 2 Replies Last reply Reply Quote 0
                                      • OutdoorManO Offline
                                        OutdoorMan Silver Members @fedequei
                                        @fedequei I don’t know but I gave up, in general. I put the Race 2 up on sale - and nobody wants it.
                                        • W Offline
                                          Wilson75 @fedequei
                                          @fedequei said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                                          and hope they’
                                          I am having the same problem since this update. I also reported watch charging issue. All we can do it to leave with it + wait for the next update.
                                          Really hope that the next release will not be too long to receive. I am charging my watch every 5days now + checking every 5min if the watch is currently charging.
                                          Super annoying at this time…
                                          Suunto Wing
                                          SA (bêta) on Pixel 9pro
                                          S9B Titanium (sold)
                                          SSU (sold)
                                          S 1 Reply Last reply Reply Quote 2
                                          • S Offline
                                            slash1111 @Wilson75
                                            Before the update my battery cycle was 15-17 days (Vertical 1). After the update it dropped to 8-10 days. Then I did hard reset and the cycle is back on 16-18 days.
                                            I’m guessing it has something to do with the new sensor management.
                                            After the update, every time I switched on the Polar Verity Sense it connected to the watch instantly.
                                            After the hard reset it connects only when I select any sport activity.
                                            thanasisT 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
