    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch
    Scheduled Pinned Locked Moved Suunto Vertical
    186 Posts 57 Posters 44.2k Views 52 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • L Offline
      lessthanmore Bronze Member @Jugger
      @Jugger Might be related to the manufacturer of the belt.
      The H10 is off if not connected to the belt. With Garmin there’s no real “off” as far as I know.
      J 1 Reply Last reply Reply Quote 0
      • J Offline
        Jugger @lessthanmore
        @lessthanmore Could be that but overall battery lasts anyway over two weeks. Other users reports 10% per day consumption even without exercise.
        Also I’ve never had any problems with new FWs. Is this only effecting people who had dataloss after last update?
        Suunto Vertical Titanium Forest
        Suunto Vertical 2 Titanium Sage
        gone troppoG 1 Reply Last reply Reply Quote 0
        • gone troppoG Offline
          gone troppo Bronze Member @Jugger
          It’s not to do with the H10 as I only use the H10 and have the 10-12% drain per day
          gone troppoG AudaxjoeA 2 Replies Last reply Reply Quote 2
            gone troppo Bronze Member @gone troppo
            Further update I can confirm that disconnecting paired device (hr Monitor) did not help battery life still going down at same rate. There must be other potential causes of this that are unknown
            • Ars VitaeA Offline
              Ars Vitae Silver Members @surfboomerang
              @surfboomerang 2-3% - that’s too much without activities.
              sartoricS surfboomerangS 2 Replies Last reply Reply Quote 0
              • AudaxjoeA Offline
                Audaxjoe @gone troppo
                @gone-troppo I had data loss (first time with FW upgrade) battery consumption has not deteriorated.
                Suunto Vertical
                Suunto 9 BARO
                Garmin Fenix 3, 5
                Suunto Vector
                • sartoricS Offline
                  sartoric Moderator @Ars Vitae
                  @Ars-Vitae
                  Too much for a whole day ?
                  SVTS - 2.50.28
                  SSSWHR BARO Amber - 2.8.32
                  Samsung A5 2016 - Android 7.0
                  Suunto App Android 6.11.12 beta
                  Ars VitaeA 1 Reply Last reply Reply Quote 0
                  • surfboomerangS Offline
                    surfboomerang @Ars Vitae
                    @Ars-Vitae With notifications on an no power saving… I think it’s a good score.
                    The drain rate is the same as before the firmware update.
                    Suunto Vertical Titanium Solar
                    OnePlus Nord 4
                      Ars Vitae Silver Members @sartoric
                      @sartoric Without notifications, wrist HR off and no workouts mine is around 1-1.5% per day. And so it has been for two years.
                        @surfboomerang I’ve never checked, I don’t use notifications. So you’re probably right, it should be a good score.
                        • L Offline
                          larrybbaker
                          I’m on my second discharge/charge cycle now post firmware upgrade and it seems like the battery life is returning to previous. Also interestingly yesterday I gained back 1% of battery wing outside most of the day in the sun.
                          Vertical Ti Solar
                          Vertical 2
                          Race 2
                          iPhone 17 Pro
                          • F Offline
                            fedequei
                            I’m also trying to fully discharge the battery because the consumption data keeps getting worse.
                            I’m attaching a chart from the last recharge, which only shows two hours of recorded activity. I have HR tracking enabled all day, but notifications are turned off.
                            Ars VitaeA gone troppoG babychaiB 3 Replies Last reply Reply Quote 1
                              Ars Vitae Silver Members @fedequei
                              @fedequei said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                              Based on what you wrote and this table, you should record consumption at around 54%. 12 x 4 (normal consumption without notifications and HR - max. 2% + 2% wrist HR for 24 hours) and approx. 6% for 2 hours of activity. The consumption should be at around 45% on the last day. This is clearly an issue. In comparison, I have not noticed anything like this on my SV. The consumption is similar to what it was before the update. If more people are experiencing this issue, then history is repeating itself from a year ago. I hope for all of you that Suunto is aware of the problem and will solve it quickly.
                              • AntoineA Offline
                                Antoine Bronze Member
                                I have also noticed excessive battery drain since the last firmware update. I used to have a drain of around 5% per 24 hours without any activity (since the fixes made a few months ago: https://forum.suunto.com/post/158362).
                                Since the last update, I’m now at over 10% with the same watch settings.
                                It’s a bit disappointing to have these excessive battery drain issues again.
                                Suunto vertical solar
                                Coros arm HRM / Suunto wing 2
                                Android A55 Samsung
                                Suunto App latest official update
                                  gone troppo Bronze Member @fedequei
                                  Mine is similar to yours getting worse, in previous 24 hour it went down 24% and in last 24 hours went down 27% …. Basically every hour it drops 1%
                                  • babychaiB Offline
                                    babychai Silver Members @fedequei
                                    My battery consumption is almost the same as yours. Without any activity, it uses around 6.5% on average. I wear it 24/7, keep sleep tracking and HR on, but notifications are off.
                                    Suunto Vertical Titanium Solar Black
                                    Suunto 9 Peak All Black
                                    Suunto Spartan Trainer Wrist HR (Black)
                                    SquirrelS 1 Reply Last reply Reply Quote 1
                                    • SquirrelS Offline
                                      Squirrel Silver Members @babychai
                                      Did anyone check the battery consumption in airplane mode? 🤔
                                      Settings>Connectivity>
                                      Race S
                                      gone troppoG 2 Replies Last reply Reply Quote 0
                                        gone troppo Bronze Member @Squirrel
                                        I’m just about to get my old ambit 3 peak out of the cupboard it had better battery life than my vertical currently gets!!! Same as my sons sunnto 9 baro
                                          44% to 4% in last 24 hours wtf is going on? I have tried every possible fix to that this forum and fb groups have recommended and nothing works. Is suunto aware of this issue? Is there a fix coming for it ? My suunto vertical which was so great when it was released is now nothing more than an Apple Watch that needs constant charging. I have been with suunto for many years but this is a disgrace. My old ambit 3 peak doesn’t have these issues. I love the suunto app and how suunto ecosystem is I don’t want to change but this is borderline unusable. Watch drains more than 1% per hour when not even doing anything and every battery sucking setting disabled. What a joke
                                          AntoineA 1 Reply Last reply Reply Quote 0
                                            @Squirrel said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                                            Yes tried this it doesn’t help
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
