    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 baro very low elevation gain vs other brands
    148 Posts 21 Posters 45.3k Views 20 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • sky-runnerS Offline
      sky-runner Platinum Member @cosme.costa
      @cosmecosta said in Suunto 9 baro very low elevation gain vs other brands:
      Suunto is not adding altitude in increments of 3 m. I do not know the algorithm but not all ascents are multiple of 3 m, as an example: today ascent 73 m (not multiple of 3),
      I spent a lot of time watching altitude and ascent fields together while running up and down. I actually have both altitude and ascent fields in feet which gives more precision. 3 meters or 10 feet is the threshold. The watch can increase the ascent by more than the threshold, but I’ve never ever seen it increasing ascent by less than that. Most commonly it adds 10-13 feet at a time, but sometimes more. Yes, the actual resolution is actually less than 1 meter. For example it may add 11 feet which is 3.35 meters. Furthermore once it has increased the ascent value, that seems to be a new baseline because it doesn’t change the ascent value again unless I go at least another 10 feet up.
      To give you an extreme example of how total ascent is counted, once I did tiny hill repeats because I ran in a very flat area and that was the best I could find. I did 30 repeats of 17 feet (5.2 m) each. That is about 500 ft total ascent. On the elevation graph in Movescount I could clearly see all 30 climbs and each was 17 (plus/minus 1) feet, which is clearly above the 10 feet threshold. Yet the watch had counted only about 300 ft of total ascent.
      As I said, that is an extreme example, but it does demonstrate the issue.
      Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
      Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
      1 Reply Last reply Reply Quote 3
      • OktanO Offline
        Oktan
        This issue is the only one which annoying and disturbing me in this watch 😕
        Suunto 9 Baro Titanium & Ambit 3 Peak
        Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
          Dimitrios Kanellopoulos Community Manager
          @sky-runner that is what I am talking about exactly. If you climb a hill and don’t spend let’s say about 1-3 seconds (stable altitude) on the top then the last 1-3meters might not be counted. Note: Vertical speed plays a role here for this to be triggered / used.
          We have several data “tests” over races and workouts to validate this ain’t a big issue.
          However this is there for a specific reason, to avoid wind gusts (sudden ascents that don’t last more than 1-3seconds) , rain drops, and your arm / clothing suddenly blocking the pressure holes thus registering ascent and descent.
          We don’t do stuff just because we think they should work better. We do deep analysis on data to find the middle group to both create accuracy and avoid problems that the user is facing.
          Additionally those parameters are tweaked for each sport mode.
          I would like not to expose more internal technology if that is ok with you. Many things have changed there since start of 2020.
          The user (OP) probably doesn’t have have this specific issue I think
          P.S. There is still one improvement not done and that is latch logic you had described. The reason for that is that as stated above, we cannot change something , without first having a strong RD plan / resource investment
          Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
          surfboomerangS 1 Reply Last reply Reply Quote 6
            Dimitrios Kanellopoulos Community Manager @Oktan
            @Oktan Did you do some analysis on your claim ?
            Would you like me Todo it ? Links and examples please
            OktanO 1 Reply Last reply Reply Quote 0
            • OktanO Offline
              Oktan @Dimitrios Kanellopoulos
              @Dimitrios-Kanellopoulos I registered to Runalyze and loaded the activity there. I’m a simple user and dont undestand what to do next or how to anylize or understand the numbers there, sorry.
              I attached the activity a few messages above (https://www.strava.com/activities/4486972002), so if you can test it, it would be great. If you need the gpx from Strava, I can maybe attach it here also.
              BTW, I looked today at other ride, 73 km long, which I did at 2019 with Ambit 3 Peak, and the same ride this year, 2020, with S9B.
              Ambit logged elevation gain of 1491 m (https://www.strava.com/activities/2101913528)
              S9B logged elevation gain of 1284 m (https://www.strava.com/activities/3138457224)
              Dimitrios KanellopoulosD cosme.costaC 2 Replies Last reply Reply Quote 0
                @Oktan can you pm me the suunto app links or fit files so I can analyse this?
                I would prefer 1 activity to start with with a format like this:
                FIT File or suunto app link
                • Expected ascent (ie what other services say)
                • Registered ascent
                • cosme.costaC Offline
                  cosme.costa @Oktan
                  @Oktan said in Suunto 9 baro very low elevation gain vs other brands:
                  No offense here but all the ascent values that are in Strava when they are pushed from Movescount are not reliable because is not what the watch registered, this ascent is corrected by Strava. Strava only shows the watch ascent if it is pushed from SA. I understand that the activity with the A3 was uploaded using Movescount, have you checked the ascent value in Movescount for that activity?
                  Dimitrios KanellopoulosD pilleusP 2 Replies Last reply Reply Quote 1
                    Dimitrios Kanellopoulos Community Manager @cosme.costa
                    @cosmecosta correct. Movescount doesn’t push the ascent to Strava so Strava recalculates that
                    • pilleusP Offline
                      pilleus @cosme.costa
                      @cosmecosta you can upload the gpx file manually to Strava. If there is the additional information “with Barometer” in the creator tag of the gpx file, Strava trusts the watch and shows the ascent of the watch and you can use the ascent from the A3 or change it to the ascent of Strava. If not, add it with an editor before uploading the file. A good way to compare watch and Strava data.
                      https://www.instagram.com/moves.are.life/
                      Suunto Vertical Black Lime
                      Suunto 9 Peak Pro Black
                      Suunto Spartan Ultra Stealth Titanium
                      cosme.costaC 1 Reply Last reply Reply Quote 1
                      • freeheelerF Offline
                        freeheeler
                        @sky-runner @Dimitrios-Kanellopoulos
                        I see that we have a calculation that is not summing up for extreme conditions and hence might under calculate the total ascent. On the other hand I’m glad the watch does not count gusts or when I bent down to fiddle around with the buckles or the climbing bails…
                        so it follows as usual the common rule of development: it is a compromise and all the developers can do is find the best compromise for the majority of athletes 👍
                        If we’d let people tweak settings like that they would be disappointed due to propably wrong settings, too.
                        I remember that QS has a function to filter a bit towards more or less sensitivity on that, please correct me if I’m wrong!
                        I did not touch this setting as I think that Dimitrios as set it to a reasonable setup.
                        living sideways
                        1 Reply Last reply Reply Quote 5
                        • surfboomerangS Offline
                          surfboomerang @Dimitrios Kanellopoulos
                          @Dimitrios-Kanellopoulos said in Suunto 9 baro very low elevation gain vs other brands:
                          Wind does affect altitude a lot. Below a screenshot with a part of a windsurfing session. According to the data it would have been a bumpy ride 😄
                          (To be honest, I have no idea why altitude is recorded for an activity type like windsurfing)
                          Suunto Vertical Titanium Solar
                          OnePlus Nord 4
                            cosme.costa @pilleus
                            @pilleus Thanks for the trick, but what I want to state is that sometimes people put a lot of trust in Strava when the values are wrong. Without any trick an uploaded activity from Movescount, the ascent in Strava doesn’t match the watch, so you can’t compare directly two activities in Strava, if one is pushed from MC and another from SA. Here @Oktan should compare the values from MC and the values from SA to seek discrepancies.
                            I mean, I use Strava for the social part but I do not trust much the values, at least you have to be aware of the downsizes/tricks. As an example, today I did a trail run with very steep parts, that I had to walk, so Strava decided that I was under their threshold and has decided to improve my pace from the real one 5:26 min/km to 5:19 min/km, I know the trick that only doing a one second pause in the watch, then Strava shows the real pace. So, sometimes, when you see some values in strava they do not need to be correct.
                            For me the only right values are the ones coming from the watch directly, knowing that an algorithm is an algorithm and can be tuned in different ways.
                            pilleusP 1 Reply Last reply Reply Quote 3
                            • pilleusP Offline
                              With my old Spartan Ultra I experienced for cycling activities no noteworthy differences between ascent of the watch and ascent of Strava’s GPS based ascent.
                              I usually have 850 to 1000 meters of climbing on a distance of 35 km with the mountain bike. The difference is usually about 10 to 15 meters between SSU and Strava, if I use the option to use the ascent of Strava.
                                @pilleus Well mi experience is different, in trail running differences can be very big, more than one hundred meters in a 400 m ascent run.
                                For the MTB, I’m using a dedicated barometric GPS that has always overrode the Strava correction, and Strava shows the GPS value but I have checked using Strava’s correction and:
                                GPS: 803 m / Strava 766 m
                                GPS: 697 m / Strava 635 m
                                GPS: 711 m / Strava 630 m
                                And this are 3 random activities that I checked.
                                So…
                                pilleusP 1 Reply Last reply Reply Quote 1
                                • pilleusP Offline
                                  @cosmecosta I think the problem is the terrain. A GPS track 3 meters away from the path or street in steep and hilly terrain will cause a miscalculation of Strava’s GPS based data.
                                  And I experienced that my SSU is more accurate recording the ascent than my S9B.
                                  • OktanO Offline
                                    Expected
                                    I dont know how to send you a private message so I loded it here:
                                    1. This is the FIT file from Suunto App (with elevation gain 1243 m):
                                      MountainBiking_2020-12-18T06_44_10.fit
                                    2. The elevation gain in Strava is: 1542 m.
                                      @Oktan
                                      So this is what I do.
                                      I go to https://runalyze.com/activity/new-upload and upload the fit file.
                                      Then I go to course and elevation data and I correct them with the various DEDB (elevation databases) that the great Runalyze offers
                                      Look at the thresholds! Even Runanalyze defaults to 3m but take a good look and see what is produced with other thresholds as well
                                      1. Racemap elevation service
                                      2. Geotiff
                                      3. Geonames
                                      4. Geonames ASter
                                      To be honest all show less actually than Strava.
                                      Now since you are using comparing whahoo I had seen this video at the past https://www.youtube.com/watch?v=bPyEtZH3QaU about how much positioning could affect a garmin computer. But I suppose the same flaws can happen with the S9.
                                      My conclusion is that it’s up to you to judge how much ascent you did and with what threshold.
                                      As a reference example here is an analysis of my 16km almost flat bikeride at Netherlands. It is completely almost flat here so:
                                      1. No correction (still 13m)
                                      2. Racemap
                                      3. Geotiff
                                      4. Geonames
                                      5. Geonames aster -> Completly wrong
                                      Now, this is my personal opinion.
                                      If you get bothered and you want those extra meters to show at your Strava / Other service or your friends get more ascent etc my advice as I would give to a friend is to get the same device that their friends use or the one that gives you what you want to see for your data.
                                      Why this advice ? Because it all about perspective and no perspective can fit everyone.
                                      I hope this helps
                                      PS: The highlight on the screenshots shows what Runalyze prefers it’s not me highlighting that .
                                      1 Reply Last reply Reply Quote 7
                                      • OktanO Offline
                                        Oktan
                                        Racemap
                                        Thank you for your time.
                                        I played with it a bit.
                                        Threshold = 1 , without correction -> 1529, this is what I expected to get.
                                        Maybe we are lossing too much elevation with Threshold = 3.
                                        It was great if the user could have set it in his watch settings.
                                        • M Offline
                                          Marco Stranieri @Oktan
                                          @Oktan I think soo. My Suunto 9 sometimes it shows up to 100-150m of elevation difference regarding other brands or even with Suunto spartan and suunto 7. (Talknig about just for 500m of elevation gain). For example my suunto shows 479m gain and friends’ one it shows 580m
                                          • EgikaE Offline
                                            Egika Platinum Member
                                            There’s one important thing missing in the discussion about thresholds etc.
                                            It is the sensor accuracy itself.
                                            We are talking about a measurement device that only works down to a certain precision.
                                            Plus it is affected by influence like wind turbulence while moving.
                                            In a perfect world or laboratory setting it could probably register pressure changes that are as small as 1ft or 1m causes it.
                                            But in real life there is noise to the data.
                                            This is why it totally makes sense to use thresholds, filtering and other logical information like sport mode or speed etc.
                                            If you switched the threshold to 1m, you would just see a lof of this sensor noise in your data which just don’t make sense.
                                            My 2c from an engineer perspective specializing in measurement technology
                                            Dimitrios KanellopoulosD OktanO 2 Replies Last reply Reply Quote 7
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
