    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 baro very low elevation gain vs other brands
    148 Posts 21 Posters 45.3k Views 20 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • fazelF Offline
      fazel Bronze Member @Fenr1r
      @Fenr1r “Hilly” for me. I think we are doing just under three loops. The 50K is four full loops and 4900’ according to the Ambit when I wore it for the race.
      https://www.strava.com/activities/1434473944/overview
      Okay @Fenr1r @TELE-HO I’ll plan on wearing both watches.
      1 Reply Last reply Reply Quote 3
      • Brad_OlwinB Offline
        Brad_Olwin Moderator
        Sorry all @stromdiddily @sky-runner @fazel @TELE-HO @Oktan @Dimitrios-Kanellopoulos , I would like this to end… I find NO differences between A3P, S7 and S9B. Here ya go, a SkiMo and a Trail Run.
        SkiMo
        Trail Run : A3P and S9B had FusedAlti kick in as you can see.
        Vector/T6c/Vertical 2 Ti
        Dimitrios KanellopoulosD stromdiddilyS 2 Replies Last reply Reply Quote 7
          Dimitrios Kanellopoulos Community Manager @Brad_Olwin
          @Brad_Olwin me too. Thanks buddy. This is much appreciated
          Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
          • stromdiddilyS Offline
            stromdiddily Gold Members @Brad_Olwin
            @Brad_Olwin the “issue” isn’t with bigger/distinguished climbs.
            Same day, just over 5 mile route on rolling type terrain…22% difference in altitude.
            Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
            User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
              Brad_Olwin Moderator @stromdiddily
              @stromdiddily said in Suunto 9 baro very low elevation gain vs other brands:
              I often compare my altitude gain with corrections in TrainingPeaks, which I find highly accurate. I do not see this problem with my S9B as you can see below for runs with little altitude gain…I have dozens of these runs too if not hundreds. In fact, I find the S9B overestimates altitude gains on low altitude runs.
              stromdiddilyS 1 Reply Last reply Reply Quote 1
                @Brad_Olwin your experience does not match my own. But I will leave this topic here.
                May “missing” elevation be the worst of our problems in 2021 🍻
                Brad_OlwinB 1 Reply Last reply Reply Quote 1
                  My point from your last post was the A3P may not be providing the “correct” altitude gain/loss for comparison. I agree that larger gains/losses typically are more accurate for me and the low altitude runs are substantially more variable. However, when comparing with correction algorithms I find the watches are overestimating more often than underestimating. Altitude is tough to get correct and my benchmarks when running or on skis is to compare the actual summit altitude with the watch, the watches are often quite close. As has been discussed before, clothing, wind, and I suspect arm movements affect the calculations and the sensor. In my experience none of the Suunto watches I have are different from each other. My only other comparison is with an Apple Watch and I found excellent agreement with gain/loss on Apple Watches compared to Suunto. I can post a large number of those comparisons too.
                  On a final note, many of you know I field test for Suunto. This is part of the field testing and many testers compare more than one brand. Based on what I know and what I have observed from my experience and others I don’t believe there is a consistent problem here with watches that have barometers. The GPS altitude watches are another story and I have a different opinion there.
                  1 Reply Last reply Reply Quote 4
                  • fazelF Offline
                    fazel Bronze Member
                    @Brad_Olwin how are you running both watches? Pairing and unpairing in Suunto App? I’m still likely to run with both watches to satisfy my own curiosity. Nice “hill” repeats 😉
                      Brad_Olwin Moderator @fazel
                      @fazel said in Suunto 9 baro very low elevation gain vs other brands:
                      Thanks @fazel!. I run often with 2, 3 or 4 watches. Two on one arm, one on one wrist and holding one or one under a hat. I connect/disconnect all to SA on one iPhone and delete all duplicates. I have my exercises set to private so they post only when I have edited those out I am not keeping…daily routine of a tester…
                      fazelF 1 Reply Last reply Reply Quote 1
                      • fazelF Offline
                        fazel Bronze Member @Brad_Olwin
                        @Brad_Olwin Thank you!
                          Sure, sometimes not all that much fun when I am hitting the lap button on 2 watches. Today I used S7 and S9B for hill repeats lap button on S7 and testing S9B SuuntoPlus Climb, which lags behind a bit unfortunately. Here is altitude, HR (both on OHR, S7 is better but not perfect) and Stryd watts. S7 OHR lagged on the first and 3rd intervals, S9 OHR too high at the beginning. Watts were good!
                          Workout after warm up: 1 mi uphill, 0.75 mi downhill, 2 min rest, 0.75 mi uphill, 0.5 mi downhill, 2 min rest, 0.5 mi uphill, 1 mi downhill, 2min rest and cool down.
                          fazelF 1 Reply Last reply Reply Quote 0
                          • fazelF Offline
                            @Brad_Olwin holy moly. I checked some runs on TP after I read your first reply of the day and noticed the corrections look staggered some. I’m wondering if you’ve ever seen that? I was thinking it might have something to do with using the Stryd for distance and the watch drawing the GPS track on top of it?
                            Like this…
                              @fazel FusedAlti will continuously correct so the staggered start is likely getting the altitude dialed in, I often see the same and you can see that in my post from TP here. I tend not to worry about it too much. My experience with Stryd for distance is not great, way short on trails. All of my posts here are trails, I do all my interval training on trails (sometimes wide and flat or wide and hilly like today) but hardly ever pavement. If your Stryd is accurate that may not be a bad idea. I have my Stryd paired as a powerpod only. If you pair as a footpod, the Stryd distance, pace and cadence will override the GPS data. Make sure you set auto calibration to off in the footpod menu or it will mess up the Stryd metrics for distance and pace.
                              Edited per your photo…I have never seen this! That does not look good. Do you have pause or auto pause on? I see breaks in the corrected.
                              • fazelF Offline
                                @Brad_Olwin so what is your advice for someone like me who needs it paired as a foot pod for the treadmill and runs gravel roads far more often then trails? The way I see it I could
                                • leave it paired as a foot pod but only use it for the treadmill
                                • leave it paired as foot pod, use it for the treadmill and roads but not trails
                                • pair it as a power pod for outdoor use, then disconnect and re-pair as foot pod for treadmill use
                                Correct?
                                  Correct?
                                  Test your distances with and without the Stryd on pavement and trail. Just run without and with, I would leave connected as footpod. If you find discrepancies then you can decide.
                                  • fazelF Offline
                                    @Fenr1r no detailed analysis yet, but I can tell you they were within 6%.
                                    • 9 Baro: 2549’ of ascent
                                    • Ambit3 Peak: 2726’ of ascent
                                    • Buddy’s Garmin 920XT: 2703’ of ascent
                                    • Buddy’s Garmin 235: 2558’ of ascent (no barometer)
                                    What is more interesting are the distances.
                                    • 9 Baro paired to Stryd: 22.74 miles
                                    • Ambit3 Peak via GPS: 21.58 miles
                                    • Buddy’s Garmin 920XT: 21.00 miles
                                    • Buddy’s Garmin 235: 20.83 miles
                                    Links to Activities
                                    Ambit
                                    9
                                    Wow - the Ambit draws pretty tracks…
                                    • OktanO Offline
                                      Oktan
                                      Is there an email / link to support contact form (I looked and didnt found one), where users can complain about the elevation issue?
                                      Suunto 9 Baro Titanium & Ambit 3 Peak
                                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                        Dimitrios Kanellopoulos Community Manager @Oktan
                                        @Oktan here 😎 is one place we are about 5 fieldtesters here for suunto here , and 3 debating.
                                          @fazel I spent some time again with your files and passed them through various services and still the ascent is reported lower from all dbs except Strava.
                                          Try loading your ambit file to runalyze
                                          So you can see above corrected and uncorrected.
                                          Now I loaded both files to qs.
                                          The altitudes are not so similar. One of the 2 had a fault probably due to some hand movement.
                                          Take a look
                                          You can clearly see that the ascent was missed by the s9 not due to some software but rather to different readings especially at the end that the diff is quite close to the ascent diff.
                                          Again the algo is the same for all watches , what you experience is more of pressure sensor changes.
                                          You ask 2 things:
                                          1. To lower the threshold. Due to filtering out outliers this doesn’t sound right and many testers and SUUNTO don’t support it. We play on the safe side. Climbing a mountain is ok. Climbing your porch bench 2000 times and hitting everest or running on the beach facing wind and getting 2000+ ascent (I have examples) I don’t endorse personally nor from what I understand suunto.
                                          2. To change the hw or position of the sensor ? (Not possible)
                                          3. To change the gps chip or ad an antenna? Not possible atm.
                                          Now, while this conversation might help someone , I will be leaving this thread for my sanity.
                                          It’s pretty much the Nth time we look into this and actually there is no issue. I would like to spend my time with improving qs.
                                          I cannot debate anymore on a saturated issue that has been iterated and tested from people (100+ fieldtesters) to machines that run the watches on rails. While we can argue that you want to register even 1 cm chnages as ascent Suunto and the RD team has chosen diffently and has chosen the filter and algos for each sensor that makes sense for the atheltes. Each watch from a3 to ssu to s9 has a different sensor and different sensor position with different pros and cons. For example a3 is prone to sweat while ssu is prone to wind and jackets. If you are not pleased guys and thus really bothers you to loose those 0.34 meters climbing everest or lifting your hand, I understand that but I personally don’t won’t to be bothered anymore. You can continue the debate here or anywhere else (contact support etc) but this is very very improbable to change any time soon. This might be improved at some point as a generic change for all watches and there are testers and a bigger team to validate that.
                                          Have a happy new year , and my advice is to try to be healthy and not dictated by a tenacity. It is what it is.
                                          Over and out from here.
                                          And hey!!! Important:
                                          You are doing great guys into looking into these stuff. I would do the same. I am not at all trying to stop you! Just want to be clear ☺️ . There is no problem adding any feedback here @fazel @Oktan etc. Please go on.
                                          EgikaE fazelF 2 Replies Last reply Reply Quote 7
                                          • EgikaE Offline
                                            Egika Platinum Member @Dimitrios Kanellopoulos
                                            @Dimitrios-Kanellopoulos and that post should be made a sticky one 👍👏
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
