    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 baro very low elevation gain vs other brands
    148 Posts 21 Posters 45.3k Views 20 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Fenr1rF Offline
      Fenr1r @stromdiddily
      @stromdiddily said in Suunto 9 baro very low elevation gain vs other brands:
      That’s how I normally wear it
      But you don’t normally get this distorted result in the same conditions?
      Unless you’ve changed jacket materials or the rain on that run was unusually chubby, my beautiful theory has probably been slain by ugly fact. I’d like to be at least plausible but some other variable(s) must be at work.
      stromdiddilyS 1 Reply Last reply Reply Quote 0
      • stromdiddilyS Offline
        stromdiddily Gold Members @Fenr1r
        @Fenr1r new shake dry jacket (is quite nice actually lol)
        Honestly it’s a one off, so not too concerned about it. I just thought it was interesting as I expected to see a super human type jump but instead saw fairly reasonable up/downs on the graph.
        Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
        User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
        Fenr1rF 1 Reply Last reply Reply Quote 0
        • Fenr1rF Offline
          @stromdiddily Hmm.
          Maybe less chubby rain, more beady jacket. Anyway, you’re right: add it to the PNW’s supply of post-X-Files/Twin Peaks Things Of Interest.
          • freeheelerF Offline
            freeheeler
            I don’t believe that S9B has very low elevation gain… I went from about 730m to about 1’250m and the total ascent is 721m. Ok there were small dips, very very small dips. But not to a sum of 200m.
            living sideways
            fazelF OktanO 2 Replies Last reply Reply Quote 0
            • fazelF Offline
              fazel Bronze Member @freeheeler
              @freeheeler what type of activity was this?
              • OktanO Offline
                Oktan @freeheeler
                @freeheeler not sure its a good example because you went up once and went down once. in hilly routes (many ups & downs like all my routes are) I see the differences. I guess each up I loose some elevation gain.
                Suunto 9 Baro Titanium & Ambit 3 Peak
                freeheelerF 1 Reply Last reply Reply Quote 1
                  freeheeler @Oktan
                  @Oktan
                  actually it is a bad example as there’s nothing easier than one consecutive ascent 😉
                  @fazel
                  it was ski touring
                  living sideways
                  fazelF 1 Reply Last reply Reply Quote 0
                  • fazelF Offline
                    @freeheeler thanks. I was wondering if the hand motions were different (I assume they are) and that might have caused some discrepancy? It sounds like the accelerometer data is considered along with the barometer measurements when calculating accent. Others will know more.
                    freeheelerF 2 Replies Last reply Reply Quote 1
                      freeheeler @fazel
                      @fazel
                      it could be possible that I’ve had a similar “setup” like @stromdiddily had recently during his run. Lot of wet stuff and the sensor holes just on top of the jackets cuff.
                      When zooming in the graph I can see tiny spikes… maybe I should entertain myself tonight and count all the irregular deltas 😉
                      The last couple of ski tours gave a more reasonable result. I’m not sure if it’s this. But what I actually wanted to point out is that I have the impression that S9B is not calculating way to low.
                      living sideways
                        freeheeler @fazel
                        @fazel
                        this graph is from a hike with poles. Hence similar movement like ski touring. When I zoom in the graph is impressively less noisy. It was a dry and sunny day. I assume that raindrops and hence molten snowflakes in combo with a garment can influence the recording.
                        I did not check the total ascent as this activity has more ups and downs plus a bike ride at the beginning and the end (and a pause for getting wet shirt changed). But just the fact that the graph has less noise is interesting, at least for me 🙂
                        living sideways
                        fazelF 1 Reply Last reply Reply Quote 1
                        • fazelF Offline
                          @freeheeler yes - your analysis seems good.
                          • isaziI Offline
                            isazi Moderator
                            Today I experienced something similar to @freeheeler. I went running outside and it was snowing (first snow in a long while in Amsterdam!), and got 47/49 (ascent/descent) on a route where I usually get ~10 meters. Corrected elevation seems something like 12/13 (I did play a little bit with Runalyze).
                            The common pattern seems to be rain/snow. First time this happen to me.
                            Also, when I got home the altitude on the watch kept changing rapidly (-3 when I stopped the exercise, 0 when I arrived home, then -2 a minute later, +2 next time I checked, and so on).
                            Currently the watch is taking a warm bath to calm down 🙂
                            Blog: isazi's home
                            freeheelerF 1 Reply Last reply Reply Quote 2
                              freeheeler @isazi
                              @isazi said in Suunto 9 baro very low elevation gain vs other brands:
                              you have to treat nicely what you love 😀
                              living sideways
                              1 Reply Last reply Reply Quote 4
                              • OktanO Offline
                                Oktan
                                Hi again,
                                Sorry, but I’m still annoyed by this issue.
                                Both S9B and A3P on handle bar, recorded exactly the same ride: S9B recorded 539m elevation gain and A3P recorded 641m.
                                How could it be?
                                • ? Offline
                                  A Former User @Oktan
                                  @oktan said in Suunto 9 baro very low elevation gain vs other brands:
                                  Hi again,
                                  How could it be?
                                  both calibrated at the begining of the activity?
                                  OktanO 1 Reply Last reply Reply Quote 0
                                  • OktanO Offline
                                    Oktan @Guest
                                    @andré-faria Yes.
                                    Dimitrios KanellopoulosD Mff73M 2 Replies Last reply Reply Quote 0
                                      Dimitrios Kanellopoulos Community Manager @Oktan
                                      @oktan link. Please so I can compare.
                                      Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                                      • Mff73M Offline
                                        Mff73 @Oktan
                                        @oktan
                                        I would bet on wind effect on S9B and lateral holes.
                                        If confirmed by Dimitrios, try protecting holes with something like this 😂
                                        SSU (retired), SV1, SV2
                                        Wife : S9PP
                                        SA: Always the latest beta :)
                                        Android + Galaxy S205G
                                        Dimitrios KanellopoulosD OktanO 2 Replies Last reply Reply Quote 0
                                          Dimitrios Kanellopoulos Community Manager @Mff73
                                          @mff73 nah then the s9 would have had more. I suspect the opposite
                                          Mff73M 1 Reply Last reply Reply Quote 1
                                          • Mff73M Offline
                                            Mff73 @Dimitrios Kanellopoulos
                                            @dimitrios-kanellopoulos
                                            Oh yes, I misread it.
                                            Wife : S9PP
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
