    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 baro very low elevation gain vs other brands
    148 Posts 21 Posters 45.3k Views 20 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • OktanO Offline
      Oktan
      It was great if the user could set a flag in the settings, if he prefers the watch to take each 1 meter change into calculation or not.
      BTW, @Dimitrios-Kanellopoulos I posted the activity a few messages up.
      Suunto 9 Baro Titanium & Ambit 3 Peak
      • OktanO Offline
        Oktan @andrewglipman
        @andrewglipman said in Suunto 9 baro very low elevation gain vs other brands:
        not enough to trigger adding it to the ascent.
        This is exacly the problem. Why not take all changes and be accurate…I cant understand that and this make me feel dissapointed.
        Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
        • isaziI Offline
          isazi Moderator @sky-runner
          @sky-runner said in Suunto 9 baro very low elevation gain vs other brands:
          One easy way to verify that is just to look at elevation profile and manually add up all climbs and compare to the total ascent reported by the watch.
          Also using Runalyze you can play with different thresholds and check.
          Blog: isazi's home
            Dimitrios Kanellopoulos Community Manager @Oktan
            @Oktan load your activity on runalyze. Do you know the service ? There you can see all the elevation reported by services and different methods of calculating ascent.
            @fazel also linked you the post with the details.
            It’s a common thing for people to ask this question and it does take a lot of debate each time iterating over the same points.
            In a kind way this is how ascent is calculated. The 1meter threshold will register ascent just by your arm swing. The 2 meter threshold will do the same on each little bump or wind or rain etc.
            While I do understand the debate this number of 3 meters is selected not in random but by continus data parsing and validations. We want to have the most consistent real ascent and that’s the decision made. We cannot sacrifice puting 1m ascent and getting people complaining of getting 200+ meters ascents in amsterdam.
            There is nothing bad with your watch or Strava or the data. It’s all there ok.
            To be honest here as as an ex mountain goat. If you think you can say you did 200m ascent each run on flatish, and thus about 2k per month, you are just not saying the truth to you. As an athlete you are mischievous to you. And that is important. That’s a personal opinion when my Garmin friends from Amsterdam would come with 2k ascent per month to visit, and stop at the first 100m trail going up splitting their lungs out. Opinion , no, 10x1m in 10k up is not 100m ascent to your legs.
            Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
            sartoricS fazelF sky-runnerS OktanO 4 Replies Last reply Reply Quote 6
            • sartoricS Offline
              sartoric Moderator @Dimitrios Kanellopoulos
              @Dimitrios-Kanellopoulos said in Suunto 9 baro very low elevation gain vs other brands:
              Oh Damn you Force of Gravity and Steep Slopes !!!
              SVTS - 2.50.28
              SSSWHR BARO Amber - 2.8.32
              Samsung A5 2016 - Android 7.0
              Suunto App Android 6.11.12 beta
              1 Reply Last reply Reply Quote 3
              • fazelF Offline
                fazel Bronze Member @Dimitrios Kanellopoulos
                @Dimitrios-Kanellopoulos - interesting point about the arm swing. This is helpful as it helps me understand the decision process.
                @Oktan here’s the link: https://forum.suunto.com/topic/5169/s9-barometer-problems/66?_=1608338498813
                • sky-runnerS Offline
                  sky-runner Platinum Member @markytarky
                  @markytarky said in Suunto 9 baro very low elevation gain vs other brands:
                  Guys, another problem is if you have a free account Strava makes adjustments, the paid account seems to just take the data.
                  That is completely untrue. Whether Strava makes adjustments or not depends only on two factors:
                  • Format of uploaded data. If the data is in FIT format the data comes from the header - basically what has been reported by the watch. If the data was in GPX format there is no header, and Strava gets all the data by analyzing the track.
                  • If the data comes from a device with barometric altimeter, Strava trusts altitude and total ascent / descent. Otherwise it ignores the elevation data and applies elevation correction algorithm that gets the data from its own database.
                  Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
                  Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
                    sky-runner Platinum Member @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos I watched my Garmin many times in real time trying to understand how it calculates total ascent. It looks like Garmin also uses 3 meter threshold, similar to Suunto. However Garmin still counts total ascent more accurately. The difference is that it uses the 3 meter threshold only initially when there is a change in vertical direction. After that the threshold seems to be smaller because I see the ascent changing in 3-5 ft increments (1-1.5 meter). Also Garmin always captures the last bit of ascent when running over top of the hill. It seems it analyzes the trend and understands that I started running downhill because it often adds the last few feet of ascent after I have already started running down.
                    In contrast, Suunto 9 seems to be doing some sort of averaging of altitude over 5-10 seconds in addition to the threshold, which results in additional smoothing of extremes (the lowest and the highest points). With Suunto, I noticed that I had to stop and wait at a highest point for a bit for the last 10-15 feet (3-5 meters) to be captured, and if I ran without stopping it would often miss that last bit of ascent even if I was above the threshold.
                    I agree that for most people it isn’t a big deal, and the whole issue is much less noticeable when moving slower, for example hiking. But I noticed it regularly enough to be bothered by it.
                    Dimitrios KanellopoulosD cosme.costaC 2 Replies Last reply Reply Quote 1
                    • freeheelerF Offline
                      freeheeler
                      silentvoyager was heavily involved in this type of discussions and we already have plenty of these in this forum.
                      When I roughly compare my Fenix3 activities with my S9B activities I get the impression that Garmin exaggerates the total ascent.
                      I trust my S9B more than any other watch I’ve previously owned.
                      living sideways
                      sky-runnerS 1 Reply Last reply Reply Quote 1
                        sky-runner Platinum Member @freeheeler
                        @TELE-HO I am silentvoyager. At least I was before I deleted my previous account. Anyway, I better stop here.
                        freeheelerF Brad_OlwinB BulkanB 3 Replies Last reply Reply Quote 4
                          freeheeler @sky-runner
                          @sky-runner
                          😀 welcome back, bro!
                          living sideways
                          • OktanO Offline
                            Oktan @Dimitrios Kanellopoulos
                            1. No, I dont know the service, but I will try to look into it.
                            2. The watch is on the bike handlebar and not on my hand.
                              Dimitrios Kanellopoulos Community Manager @sky-runner
                              @sky-runner I understand that but there is no averaging. It’s just a time window of 3 seconds to filter out noise. Also if you use the climb suunto plus this is bypassed so it counts your rolling hills workout.
                              fazelF 1 Reply Last reply Reply Quote 1
                              • Brad_OlwinB Online
                                Brad_Olwin Moderator @sky-runner
                                I think you can keep pushing on this and I agree that perhaps a better method to filter noise could work. Even though this rarely affects me because my climbs are larger it would bug me a lot. I have been asking if we could get improvements in the altitude profile graph for routes. Perhaps improvements in altitude filtering could come too. So, please don’t give up and don’t silence yourself. No watch is perfect!
                                Vector/T6c/Vertical 2 Ti
                                1 Reply Last reply Reply Quote 5
                                • BulkanB Offline
                                  Bulkan Moderator @sky-runner
                                  Welcome back!!! About the ascend debate, as @Brad_Olwin says there is always room for improvement.
                                  Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                                  1 Reply Last reply Reply Quote 4
                                  • cosme.costaC Offline
                                    cosme.costa @sky-runner
                                    Suunto is not adding altitude in increments of 3 m. I do not know the algorithm but not all ascents are multiple of 3 m, as an example: today ascent 73 m (not multiple of 3), yesterdays ascent 738 m (multiple of 3), another day 395 m (not multiple of 3). So I think that the 3 m threshold triggers the ascent counting but then the increments are calculated in another way.
                                    Dimitrios KanellopoulosD sky-runnerS 2 Replies Last reply Reply Quote 4
                                      Dimitrios Kanellopoulos Community Manager @cosme.costa
                                      @cosmecosta that is correct. We dont do 3m segments.
                                      You can climb 4m go down and that is 4m added to your ascent. You just have to “eventually” climb 3 meters in I think 3 minutes (or more) to be counted.
                                      • fazelF Offline
                                        @Dimitrios-Kanellopoulos does this algorithm account for horizontal velocity? I have the same sense as @sky-runner - I’m more likely to see differences when cycling then when running. Thanks!
                                          Dimitrios Kanellopoulos Community Manager @fazel
                                          @fazel yes. It does.
                                          • fazelF Offline
                                            @Dimitrios-Kanellopoulos Thank you!
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
