Push Notification
@Akos-Hajas I will report this as well, I tested this and I AM getting notifications from SportsTracker but not from SA, I may need to delete SportsTracker to check this thoroughly.
@Brad_Olwin thank you
@Akos-Hajas @Dimitrios-Kanellopoulos I am not getting iOS notifications from SA. I am getting them from SportsTracker, however. I will delete SportsTracker and test this but there may be some issue. The two apps are not acting independently on my iPhone. When I turn off notifications for SportsTracker they are turned off in SA and vice versa. When both are on I only get notifications from SportsTracker.
I’m getting all the push notifications I have enabled on my phone from SA, and I have the Sports Tracker app installed too, with those notifications showing up as well. Granted, I don’t have everything enabled (comments, new followers, new workout successfully uploaded), but they’ve been working without fail on my Android 9 phone.
@ianshowalter On iOS this may be an issue, not working appropriately for me. iOS handles notifications much differently than Android.
@Brad_Olwin yes it’s on iOS…
Don’t forget android user please
@Gabriel-S This thread is for iOS, I do not have an Android, you might want to start another thread for that.
@Brad_Olwin I had already start a thread on 16 feb 2019!! here => https://forum.suunto.com/topic/2009/notification-of-the-sa in the android section, it was forgotten.
The actual thread isn’t categorized as an ios one. -
Any updates on a solution to this issue? Seems like a fairly critical one to me, as notifications form part of the basic functionality of the app.
@Alistair_d +1 I can just confirm that notifications still doesn’t work for me too.
@Alistair_d
I can confirm too that notifications still doesn’t work for me…
@Dimitrios-Kanellopoulos after the iOS update from today : I can confirm that notifications still doesn’t work …please fix it guys
@Dimitrios-Kanellopoulos I can confirm I am not getting push notifications either. Sport Tracker does provide notifications but not SA. Sorry. Let me know if you want me to file a bug.
@Akos-Hajas said in Push Notification:
My S7 is not receiving notifications either, so it is a problem with the app. A quick workaround is to install Sport Tracker, they use the same database and you will get notifications.
@Brad_Olwin good tip. Currently using
portsTracker in conjunction with the Suunto App with notifications working perfectly in ST (
). Just realised this topic has been open since Sept (
), but I’m sure the :
will squash this
and we’ll see a resolution soon (
any update about this? I’m still not getting push notifications…
@dombo Sorry, this is filed as a bug and clearly not fixed yet, for me either. I put a comment in about it. I do not know when it will be fixed.
@Brad_Olwin thank you for taking care about this. hopefully it will work soon
Register Login
