Sync issue - error loading data - sync not fully completed
@Dimitrios-Kanellopoulos said in Sync issue - error loading data - sync not fully completed:
Are you using some suunto plus ?
I always use a HR zones duration and sometimes weather
what is the FIT file and where can I find it? and where should I upload it?
The training was also not visible in the web version of Sports Tracker.
Yesterday’s training session was unloaded, the previous 3 were not… -
@isazi what is the FIT file and where can I find it? and where should I upload it?
@isazi In the Suunto App, the previous 3 workouts, when you click on the card, writes a data error…
In my case it seems to be linked to the use of a Suunto app, but only with the basic running mode
I have the same problem , cannot sync my workout from my watch (9PP) with SA.
Suunto 9PP - Latest firmware, Android 15, App ver 5.3.7 - the same problem as a topic starter. Error loading data. Seems like it got corrupted when it uploaded from the watches to the Application on the smartphone, then the application trying to upload it on the server without any success.
Can you please do something? -
@Atilla-Altymyshev
Good evening,I’m using a 9 Peak Pro (s.n. 224810000471), and after the software update to version 2.43.12, my watch isn’t fully syncing. I’m running iOS 18.5 and the app software is 2.46.3.
I’ve tried re-pairing via Bluetooth, restarting both the watch and my smartphone, and even reinstalling the app, but nothing has helped.
Hello
I encounter the same issue with 9PP and iOS.
Since the last watch update / app some days ago, synchronization is not working properly (running activities).I have done many operations and test (unpairing, reset, uninstall) but nothing worked until I removed on my watch and activity setting the Suunto app called « HR zone duration » which I was using during training running activities.
I have no other clue but it seems that this SuuntoPlus App makes my trouble since the last update.
I saw previous posts confirming that this could be one major root cause.And Suunto, please make some validation test on your side and bring us solutions to fix it as it seems to be linked with at least one SuuntoApp.
Thanks a lot!
Biking the last couple of days just synced fine. No suunto plus feature there.
This is different with my running mode, here some suunto features I´d installed.
With some poorly synced running moves I saw missing HR-data. I sense a solution for my issues. Or our issues.
Will turn off all suunto plus with my running mode and check again. Keep you posted.Lorenz
@Pierre-0 said in Sync issue - error loading data - sync not fully completed:
Good morning,
I deleted the Suunto app called “HR zone duration,” which I also used, but the synchronization still isn’t working.
Perhaps my 9PP is too old to be compatible with the new updates?
I use my watch daily to record my sports activities, and it hasn’t been working since last Saturday. Do I need to buy a new watch?
@marcomonari No worries - Suunto 9 Peak Pro is fully supported.
I guess those sync hiccups will be sorted quickly. -
@marcomonari
Did you remove HR zone duration in SuuntoPlus option in the watch before launching the activity ?
This seems to solve synch issue on my side (iOS and watch firmware 2.43.12).
But the older activities done with HR zone SuuntoPlus selected are still blocked (I deleted them to clean Sync Problem pop up in the IPhone App) -
But the older activities done with HR zone SuuntoPlus selected are still blocked (I deleted them to clean Sync Problem pop up in the IPhone App)I’ll try tomorrow.
But I won’t delete the activities for now; I’m still hoping for a problem-solving upgrade. I’d hate to lose a week’s worth of activity recordings.
So, just came back from running with “heart rate zones” off and syncing just worked fine.
At least what my issue is concerned, I found a solution for that.
Let’s hope for a watch update on that.Run on! Lorenz
@Pierre-0 But I won’t delete the activities for now; I’m still hoping for a problem-solving upgrade. I’d hate to lose a week’s worth of activity recordings.
Good afternoon!
After having turned off heart-rate-zone-Suuntoplus syncing just worked out fine.
So, at least what my issue is concerned, I found a solution.
Thx!
Lorenz -
@Pierre-0 I removed wrist HR from the sports activity and it worked, thank you very much for the advice, the 9PP has synced! But when can I re-enable it?
Regarding past activities from the last few days, however, it’s giving a synchronization error. What do you recommend? -
My 9PP(2.43.12) is having issues syncing to the app(2.47.1) as well. I have tried unpairing and repairing the device to the app, uninstalling the app, deleting HR Zone duration from the watch/app via SuuntoPlus. Every time I try and sync, it goes through a few of the things(optimizing gps, sleep, etc) before failing the rest of the sync. I’d really like to get this issue resolved to upload my recent activities.
Register Login
