    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    Scheduled Pinned Locked Moved Suunto Vertical
    755 Posts 136 Posters 337.3k Views 113 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Umer JavedU Offline
      Umer Javed @SuperFlo75
      @SuperFlo75 I completely agree with you. I’ve never “had” to recalibrate the battery, or get such battery drain behavior on any of my tech after an update. This was suggested to me in the 9PP thread and appears to have solved the same issue I was having.
      SuperFlo75S 1 Reply Last reply Reply Quote 0
      • SuperFlo75S Offline
        SuperFlo75 Silver Members Bronze Member @Umer Javed
        @Umer-Javed this solution was suggested here several times, too. But I think if it is important it should be suggested in the User manual of the watch, too? And btw it is not easy to go to zero with a SV… I was at 19% after more than 5 weeks of using… and I charged because I wanted to load new maps…
        Suunto Vertical 2 Titanium Sage
        Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
        Suunto Wing
        Suunto 9 Peak Pro Titanium (owns my wife now)
        Suunto Spartan Ultra
        SA iOS 3.12.0 (22937)
        Instagram @superflo75
        Umer JavedU 1 Reply Last reply Reply Quote 0
          @SuperFlo75 said in Battery drain:
          I trust the suggestion because it comes from people in contact with Suunto, beyond that I agree it’s very atypical. I can’t comment on this further than that.
          My trick to drain the 9PP was to
          1. start a GPS activity indoors
          2. with an S+ app that does a lot of calculations (e.g. fat burner)
          3. display turned to light mode
          4. brightness full
          5. backlight on
          6. stay on compass screen
          7. autolap every few seconds, so the vibration and sound would keep repeating
          You SV owners are suffering from success in the battery recalibration 😅
            Dimitrios Kanellopoulos Community Manager
            Let me explain a few things about battery calibration.
            First of all this happens after some health markers on the system are reset. Usually after an update. It happens to Macs phones etc.
            The effect is that usually you see the higher battery percentages dropping faster than expected and the lower ones (ie around 30-20%) dropping very slow. For example you might see 100-90% drop in 1 day (not expected) and stuck at 30% for a whole day.
            This gets fixed automatically as the battery watchdog calibrates it self during the normal usage.
            Draining the battery by various ways ain’t good. And most probably it’s not needed as the watch will last / should last as expected.
            My suggestion is.
            • in case you have a high drop in battery just do a reboot of the device to rule out any other issue.
            • once in 3 months let’s the watch charge on a full circle (0-100) if possible
            Enjoy your watch and life.
            Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
            Thomas HertzT Umer JavedU SuperFlo75S 3 Replies Last reply Reply Quote 20
            • Thomas HertzT Offline
              Thomas Hertz Bronze Member @Dimitrios Kanellopoulos
              thanks @Dimitrios-Kanellopoulos for this clarification. makes sense!
                Umer Javed @Dimitrios Kanellopoulos
                Thanks, @Dimitrios-Kanellopoulos
                So, the previous instructions were not needed?
                ? Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                • ? Offline
                  A Former User @Umer Javed
                  Thx @Dimitrios-Kanellopoulos
                    SuperFlo75 Silver Members Bronze Member @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos Thanks for explaining
                    Suunto Wing
                      Dimitrios Kanellopoulos Community Manager @Umer Javed
                      @Umer-Javed well needed no , but if you want to get rid of your head playing games to you yes.
                      I personally never bother about battery calibration and allow the usage of the watch, phone etc to happen naturaly
                      • ? Offline
                        A Former User
                        So, I haven’t worn my Vertical for a day and a night and apparently it lost 40% of battery. I made sure to deactivate HR, sleep and alarms. What the heck. 😂
                        My S99P survives being outside my phone’s range just fine, so… 🤷
                        • valdis830V Offline
                          valdis830
                          Something similar what happened these days. Timeline for experts
                          Watch charged on the 17th (eventual daily use, almost always in drawer with HR sensor up to avoid false reading)
                          • training day 18/06- 2:30
                          • long break>>>
                          • training day 3/07- 1:25 (I start with 63% battery and end with 60 which seems great to me. Only 3%)
                            Watch 2 days in the drawer.
                          • training day 5/07- 2:25 (I start with 33% battery which means a sudden drain of 27% in 48 hours without hardly using the watch) Training comes with another surprise of 10% in 2 hours and a half. I end up with 23%.
                          • in the last 24 hours it has drained another 12% without any use and now at 11%
                          I don’t want to get mad about an issue, but this was testing my trust in Suunto.
                          I await clues and clarifications dear friends.
                          freeheelerF 1 Reply Last reply Reply Quote 0
                          • freeheelerF Offline
                            freeheeler @valdis830
                            @valdis830
                            I would restart the watch, charge it completely and observe the behavior.
                            if it happens again: magic logs would help 👍
                            living sideways
                            valdis830V 1 Reply Last reply Reply Quote 1
                              valdis830 @freeheeler
                              @freeheeler
                              Thanks, that’s the first thing I’m going to do.
                              • E Offline
                                e6321 Bronze Member
                                Adding my experience with Vertical solar as sounds similar.
                                Charged to 100% 4-5 days ago, didn’t wear until today but it was fully discharged.
                                Sound like a theme with being off wrist. Have noticed OHR seems to be on a lot when not on wrist.
                                plopes73P isaziI 3 Replies Last reply Reply Quote 0
                                • plopes73P Offline
                                  plopes73 @e6321
                                  @em632 I’ve noticed the OHR is always measuring even off wrist, execpt if the strap is folded and in contact with the sensor.
                                  Otherwise if the sensor is in contact with a table it stays measuring.
                                  Cheers
                                  S9 Peak 2.18.18
                                  Vertical
                                  Android 10
                                  Suunto App 4.45.5
                                  • plopes73P Offline
                                    plopes73 @e6321
                                    @em632 forgot to mention, I have a black silicon strap.
                                    S9 Peak 2.18.18
                                    Vertical
                                    Android 10
                                    Suunto App 4.45.5
                                    • isaziI Online
                                      isazi Moderator @e6321
                                      @e6321 doubt the two things are related. Even if OHR is always on, your watch should last weeks in a drawer, not 4-5 days. So, something else kept burning battery. Now it could be that after it completely discharged it’ll work fine, but if it does not, send logs and PM me.
                                      Blog: isazi's home
                                      E 1 Reply Last reply Reply Quote 0
                                      • E Offline
                                        e6321 Bronze Member @isazi
                                        @isazi sorry Im sure this has been asked a million times but I cant see anything searching the forum - how do I send logs?
                                        Yeah agree about the OHR have noticed the blood oxygen LED is on sometimes off wrist as well, that is a bigger power draw I think?
                                        My battery jumped from 96% to 100% today, wasn’t even that sunny… Theres a few odd things about this watch.
                                        ? isaziI 2 Replies Last reply Reply Quote 0
                                        • ? Offline
                                          A Former User @e6321
                                          @e6321 just go to your profile and scroll to the bottom:
                                          • isaziI Online
                                            @e6321 said in Battery drain:
                                            This has been solved, will be available with next firmware update.
                                            Blog: isazi's home
                                            ? 1 Reply Last reply Reply Quote 5
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
