    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    Scheduled Pinned Locked Moved Suunto Vertical
    759 Posts 136 Posters 346.2k Views 113 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
      Dimitrios Kanellopoulos Community Manager
      Please keep in mind that battery needs a full circle 0-100 to calibrate. Thus you might see faster drops near 50-100 and slower at lower percentages.
      Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
      surfboomerangS 1 Reply Last reply Reply Quote 11
      • surfboomerangS Offline
        surfboomerang @Dimitrios Kanellopoulos
        @Dimitrios-Kanellopoulos That’s a problem with the SV. It takes ages before it’s totally empty 🤣
        I still haven’t used the charger since the watch is delivered. And it will take a couple of weeks I guess.
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        isaziI jjpazJ 2 Replies Last reply Reply Quote 5
        • isaziI Offline
          isazi Moderator @surfboomerang
          @surfboomerang I only used it because I needed more maps 🙂
          Blog: isazi's home
          • jjpazJ Offline
            jjpaz Bronze Member @surfboomerang
            @surfboomerang You can leave the watch with an activity started and wait 2 days to drain the battery! 😅
            Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
            • D Offline
              dombo Bronze Member
              during my last activities battery drain was ~5% in one hour. I lost 50% of battery in 10 hours bike ride - custom sport mode, weather + climb sport apps and navigation where I had more than half of the time only black tiles…
              TieutieuT isaziI 2 Replies Last reply Reply Quote 0
              • TieutieuT Offline
                Tieutieu Platinum Member @dombo
                @dombo said in Battery drain:
                Did you checked if backlight is off ??
                Suunto’s devices at home :
                Vertical titanium solar
                Suunto Race S
                S9pp titanium sand
                Suunto Wing & Spark
                S9B titanium Ambassador edition, A3P, X6
                D 1 Reply Last reply Reply Quote 0
                • D Offline
                  dombo Bronze Member @Tieutieu
                  @Tieutieu yes, it is off. in standby battery is OK
                  • ? Offline
                    A Former User
                    So this happened today…
                    Yesterday I went to bed and had still more than 30% of battery left.
                    I however woke up with 16% battery left, not sure what happened overnight, but I have also had only 51 minutes of sleep recorded. 16% is still enough, so I went out for a bike ride. When I started the activity, the battery prediction showed only 2 hours of activity left - that was strange. I changed the Battery mode from Performance to Endurance, which showed 3 hours - so I went for the bike ride. After 30 minutes the watch turned the power saving mode on, and shortly after that turned itself off.
                    So yesterday at 22:30 it was 30%+ and today around noon 0%. Standby is OFF. Brightness and Rise to wake on Low. Any idea?
                    • Brad_OlwinB Offline
                      Brad_Olwin Moderator @Guest
                      @tomasbartko First, did you check Standby backlight? Second, has the battery cycled from 100% to 0% to calibrate? The percent battery may not be correct, see posts on this.
                      Vector/T6c/Vertical 2 Ti
                      • ? Offline
                        A Former User @Brad_Olwin
                        @Brad_Olwin I have Standby turned off, but I didn’t go through the first cycle. I have read comments about the first cycle, but have never experienced this with previous watches (also from other brands). Is this “Vertical specific”?
                        • isaziI Offline
                          isazi Moderator @dombo
                          @dombo using two S+ apps results in twice the battery consumption
                          Blog: isazi's home
                          Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                          • Łukasz SzmigielŁ Online
                            Łukasz Szmigiel @isazi
                            @isazi even if an app just displays the notes or some very simple stuff?
                            S9PP 2.50.28
                            isaziI 1 Reply Last reply Reply Quote 0
                            • isaziI Offline
                              isazi Moderator @Łukasz Szmigiel
                              @Łukasz-Szmigiel seems so to me, I think it needs further optimization
                              Blog: isazi's home
                              • Jose LuisJ Offline
                                Jose Luis Silver Members
                                Hi, I want to cycle the battery from 100% to 0%.
                                Currently it is 20%, is it necessary to completely drain the battery or do I have to charge it before?
                                Thank you
                                Old: Suunto Spartan Sport Wrist
                                IPhone
                                SA: (beta)
                                TieutieuT 1 Reply Last reply Reply Quote 0
                                • TieutieuT Offline
                                  Tieutieu Platinum Member @Jose Luis
                                  @Jose-Luis said in Battery drain:
                                  Thank you
                                  Interested with the answer too ! Currently 4%…it’s hard to get it to 0% !!
                                  Suunto Race S
                                  S9pp titanium sand
                                  Suunto Wing & Spark
                                  freeheelerF J 2 Replies Last reply Reply Quote 0
                                  • freeheelerF Offline
                                    freeheeler @Tieutieu
                                    @Tieutieu
                                    I’ve done a dummy activity to drain completely to 0%.
                                    it’s not too hard when gnss is active, it actually goes very fast… at least in my case 😉
                                    living sideways
                                    • J Offline
                                      Jugger @Tieutieu
                                      @Tieutieu I did battery draining with max light (always on) and maps open inside my home.
                                      Suunto Vertical Titanium Forest
                                      Suunto Vertical 2 Titanium Sage
                                      • babychaiB Offline
                                        babychai Silver Members
                                        may i know under what condition need to do battery calibration? is it every new watch recommended to do battery calibration? 🤔
                                        Suunto Vertical Titanium Solar Black
                                        Suunto 9 Peak All Black
                                        Suunto Spartan Trainer Wrist HR (Black)
                                        sartoricS EgikaE 2 Replies Last reply Reply Quote 0
                                        • sartoricS Offline
                                          sartoric Moderator @babychai
                                          @babychai
                                          basically every electronic gadget need a battery calibration once 😀
                                          SVTS - 2.50.28
                                          SSSWHR BARO Amber - 2.8.32
                                          Samsung A5 2016 - Android 7.0
                                          Suunto App Android 6.11.8 beta
                                          babychaiB 1 Reply Last reply Reply Quote 0
                                          • babychaiB Offline
                                            babychai Silver Members @sartoric
                                            @sartoric haha alright, thanks. trying to drain the battery to 0% now. seem like the battery is very tough. using hiking mode with turn on the backlight and battery very stubborn to drop 😆
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
