    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    Scheduled Pinned Locked Moved Suunto Vertical
    760 Posts 137 Posters 348.2k Views 114 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • sebchastangS Offline
      sebchastang Silver Members @surfboomerang
      Thank you all for the feedbacks.
      I have the same experience and I also noticed the drain after my (long) hikes.
      There are a lot of possible configurations (battery mode, maps on/off, display timeout on/off, touchscreen on/off, gpx source, displayed fields on the activity screens, …, maybe it also depends on the selected watchface/complications) and it is not easy to reproduce but as I can see, we are a lot of users who will try to reproduce and want to help Suunto to find what causes the drain.
      Let’s keep posting on this thread to share our observations and I’m sure we will find the rootcause.
      Suunto Vertical Titanium Solar
      Suunto Traverse
      • surfboomerangS Offline
        surfboomerang
        @isazi
        I think I triggered it. 3% drop in 3 hours.
        Let me share some more information, hoping it can be reproduced with the debug firmware.
        === Configuration ===
        Custom hiking mode:
        1st screen:
        1 Ascent
        2 Descent
        3 Remaining distance to end of route
        4 End of route ETA
        5 Distance
        6 Average speed
        7 Duration
        2nd screen:
        Map
        Battery mode: custom: GPS: Good, Touch: Map Only, Display timeout: off
        Navigation: Route (a test route which I created in SA)
        Map: Outdoor
        Suunto+: None
        Intensity zones: HR zones
        Target: No target
        Backlight: Normal (off)
        GPS: On
        Wrist HR: On
        Sensors->HR Belt: Off
        Climb Guidance: Notification: On, Grade value: Percentage
        Theme: Light
        Autolap: Off
        Voice Feedback: Off
        Media Controls: Off
        Autopause: Off
        Feeling: Off
        === Actions ===
        • Rebooted the watch right before the start of the activity
        • Selected Hiking profile
        • Selected the created test route to follow
        • Started the activity
        • Had the maps screen on most of the times
        • Occasionally switched to the 1st screen and the climb screen (zooming in and out)
        • Used the map zoom and ruler a couple of times
        • Ended and saved the activity.
        Total activity duration: 38 minutes
        === Result ===
        The watch goes into watch mode like normal but battery drain is more than normal.
        OnePlus Nord 4
        surfboomerangS 1 Reply Last reply Reply Quote 3
        • D Offline
          duffman19
          I’ve been having the drain post activity as well. It really feels like the GPS chip just isn’t shutting off properly after ending an activity. I suppose it could also be an overactive bluetooth connection. Something isn’t shutting down properly. This would explain why the soft reset post-activity resolves the issue. Specific activity settings don’t seem to matter much.
          Vertical Ti / S9PP Ti / S9P Ti
          surfboomerangS 1 Reply Last reply Reply Quote 1
            surfboomerang @duffman19
            @duffman19 said in Battery drain:
            I tried to rule this out by enabeling airplane mode a while ago, but it didnt make any difference.
            OnePlus Nord 4
            D 1 Reply Last reply Reply Quote 0
            • D Offline
              duffman19 @surfboomerang
              @surfboomerang I did the same, but I thought it was determined that Airplane Mode wasn’t working correctly in the first place? Or was that a previous SW version and has been fixed since? And does Airplane Mode affect GPS, or is it just BT and WiFi?
              I’ve also tried activating Power Saving mode post activity and still get drain. That’s why I assumed there was a power hungry feature incorrectly running in the background, an antenna being the most obvious.
              sartoricS 1 Reply Last reply Reply Quote 0
              • sartoricS Offline
                sartoric Moderator @duffman19
                Watches’ GPS doesn’t “emit” anything, it just receive and elaborate data.
                So it doesn’t interfere with other radio systems
                SVTS - 2.50.28
                SSSWHR BARO Amber - 2.8.32
                Samsung A5 2016 - Android 7.0
                Suunto App Android 6.11.12 beta
                • K Offline
                  Kramble @Tieutieu
                  @Tieutieu said in Battery drain:
                  @Tami999 said in Battery drain:
                  @isazi many people report that they got drain after activity and soft reset often help them. Maybe its somethong with navigation that gps is still used after activity or something.
                  32% yesterday when I posted…11% this morning (I was not wearing my SV, I had switched to my SRs). Very strange battery drop…because the first 12h hours after my race, I lost only 1%…
                  Same for me, I triggered the drain for the first time after a battery charge at 70 % and I lost 35% in 3 days.
                  My watchface is the same since 2 months and I did not do any activities this days.
                  Only noticeable thing, during day 2 I was at a wedding so I went to bed at 4h in the morning (with sleep tracking and HR24).
                  Before that I just noticed a slight drain on every day usage with something like 3,5 % against 2% on preupdate.
                  Off course I did the soft reset and full battery cycle after the update.
                  Hope it could help, thank you @isazi as usual for keeping us informed !
                  Ambit 3 peak saphir
                  Spartan Ultra (sold)
                  S7 graphite copper
                  S9 peak all black
                  Vertical titanium green forest
                  Wings
                    surfboomerang @surfboomerang
                    @surfboomerang said in Battery drain:
                    I’m sure I did trigger it: 8% in 12 hrs
                    OnePlus Nord 4
                    • jjpazJ Online
                      jjpaz Bronze Member
                      My tests during the last two weeks, only wearing (24h) and syncing SV (SR S Offline and not synced with phone):
                      • August 14th: SV full charged; soft reset; synced.
                      • August 27th: level battery is 34%.
                      66% battery consumption in 13 days (~5% by day with ~1h activity by day)
                      Several activities (~10h with GPS and ~2h30’ indoor training, only HR)
                      Differences: I haven’t followed routes nor Climb Guidance, only “simple” training activities and battery consumption seems normal. And I haven’t used nor synced Suunto Race S.
                      Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
                      SuperFlo75S 1 Reply Last reply Reply Quote 1
                      • SuperFlo75S Offline
                        SuperFlo75 Silver Members Bronze Member @jjpaz
                        @jjpaz This is nearly normal, isn‘t it? With about 10h of activity. Or do you think consomption is still too high?
                        Suunto Vertical 2 Titanium Sage
                        Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                        Suunto Wing
                        Suunto 9 Peak Pro Titanium (owns my wife now)
                        Suunto Spartan Ultra
                        SA iOS 3.12.0 (22937)
                        Instagram @superflo75
                        jjpazJ 1 Reply Last reply Reply Quote 0
                        • isaziI Offline
                          isazi Moderator
                          My personal workaround while we wait for a fix is: if you use navigation just reboot your watch at the end, after syncing the activity with your phone.
                          This is my personal view, nothing from Suunto
                          I managed to send logs to Suunto and hope a fix for this will be included in the next firmware. I also believe it is not the GPS but the storage that is kept active, GPS would give an even larger battery consumption. No confirmation from Suunto yet. I try to keep the forum informed as much as I can 🙂
                          Blog: isazi's home
                          surfboomerangS gerasimosG AntoineA 6 Replies Last reply Reply Quote 12
                            surfboomerang @isazi
                            @isazi Did you manage to reproduce the behaviour yesterday with the debug firmware watch?
                            OnePlus Nord 4
                            isaziI 1 Reply Last reply Reply Quote 0
                            • isaziI Offline
                              isazi Moderator @surfboomerang
                              @surfboomerang yes, I went out for a lunch walk to collect vegetables in our garden, and it was enough to trigger the issue.
                              Blog: isazi's home
                                @isazi Great news!
                                OnePlus Nord 4
                                • gerasimosG Offline
                                  gerasimos Bronze Member @isazi
                                  @isazi thanks for help 🙏
                                  Suunto Vertical Ti
                                  Suunto S9 gen1
                                  Suunto Ambit3 peak
                                  • jjpazJ Online
                                    jjpaz Bronze Member @SuperFlo75
                                    @SuperFlo75 Yes, it seems normal to me or a little bit higher. Before the update I was charching the battery every 17-18 days when battery reached ~15-20%, so around 4-4.5% consumption every day. Now it seems nearer 5% but could be for many reasons.
                                    • AntoineA Offline
                                      Antoine Bronze Member
                                      Do this solution solve the issue ?
                                      https://www.facebook.com/share/p/KsPKhbk48Wxu2hzM/
                                      Suunto vertical solar
                                      Coros arm HRM / Suunto wing 2
                                      Android A55 Samsung
                                      Suunto App latest official update
                                      thanasisT isaziI 2 Replies Last reply Reply Quote 0
                                      • thanasisT Offline
                                        thanasis Bronze Member @Antoine
                                        @Antoine said in Battery drain:
                                        copying it here for those who cannot read it:
                                        I have had a problem with fast battery drain in watch mode. I contacted the Suunto support chat and they gave me this solution that seems to work. Battery drain is back to 3%/24h. It was up to 7-8%.
                                        1. Place the watch on the charger and press and hold the upper button for 60sec to reboot the watch (I did not know this reboot option existed).
                                        2. After reboot do an ordinary soft reset by pressning the upper button for 12sec (watch not on the charger).
                                        No data or settings will be lost.
                                        • isaziI Offline
                                          isazi Moderator @Antoine
                                          @Antoine rebooting always solves the issue, until it is triggered again 🙂
                                          Blog: isazi's home
                                          F K 2 Replies Last reply Reply Quote 1
                                          • F Offline
                                            Frederic Bronze Member @isazi
                                            I am having the same issue and it is pretty annoying. I believe it appeared after the July 3rd update (v2.35.34)
                                            Suunto Vertical
                                            My Suunto Workflow
                                            MyTourbook - First Steps
                                            Questions or bugs ?
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
