    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    Scheduled Pinned Locked Moved Suunto Vertical
    760 Posts 137 Posters 369.9k Views 114 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • sartoricS Offline
      sartoric Moderator @matteo_000
      @matteo_000
      Normally you should not and you shouldn’t need it.
      This is an exception, to recalibrate the battery.
      SVTS - 2.50.28
      SSSWHR BARO Amber - 2.8.32
      Samsung A5 2016 - Android 7.0
      Suunto App Android 6.11.12 beta
      1 Reply Last reply Reply Quote 3
      • wmichiW Offline
        wmichi
        I have also seen faster battery drain after the last update. Like others suggested, I drained the battery to a value below 20%, charged it to 100% and restarted the watch afterwards (15s upper right button). Now everything is back to normal. I did this process yesterday at 18:00. Went to sleep at 22:30, woke up at 7:00 with 99%, went on a short run for 1h 20min (performance mode) and now at 12:20 I am still at 99% 🙂
        That’s the first time I had to do this after a firmware update.
        Ars VitaeA ? 2 Replies Last reply Reply Quote 1
        • Ars VitaeA Offline
          Ars Vitae Silver Members @wmichi
          @wmichi Thanks for the advice. Do you usually have a bluetooth connection enabled or disabled?
          wmichiW 1 Reply Last reply Reply Quote 0
          • ? Offline
            A Former User @wmichi
            @wmichi same here, battery was draining at 7-8% daily after the update (have seen this on several updates on serval Suunto watches).
            I let it run down until the watch shut off and charging icon showed; charged to 100% and wore it for the last 10 hours with sleep tracking and woke up with the battery at 99%. Battery went through recalibration, and it is back to normal.
            • wmichiW Offline
              wmichi @Ars Vitae
              @Ars-Vitae I have it always enabled. I only have do not disturb enabled between 21:00 and 07:00 (but this doesn’t disable bluetooth connection). I have to add, that I have notifications disabled. This might also help with a longer battery life.
              Ars VitaeA 1 Reply Last reply Reply Quote 1
                @wmichi Ok, thanks.
                • Gilles D.G Offline
                  Gilles D. @altcmd
                  Hello @altcmd, same with my Vertical Solar Steel.
                  Battery loaded at 99%, then 36 hours later down to 86%, with only one hour of bike riding…
                  HR 24/24 : ON
                  Screen backlight : OFF
                  I don’t want neither to do a soft reset, because all downloaded maps will be erased, and will take ages to re-download.
                  Gilles
                  sartoricS 1 Reply Last reply Reply Quote 0
                  • ? Offline
                    A Former User @Ars Vitae
                    @Ars-Vitae
                    Waited 24 hours after the battery recalibration (full drain/ full charge). Watch is set up 24/7 HR/SPO, notifications on and a 30 minute row (5200m) with chest heart rate strap (to check).
                    It is back to where it was for me: 3% daily battery usage.
                    • Z Offline
                      zewen
                      here is my case:
                      i run a 100KM ultra trail running race at 7-12, when the race begin, the battery is 89%, after 25h25min, i finish the race, the battery is 50%, the race start at morning 8:00am, a cloudy day , almost rainning all day, next day is sunny day
                      and climb guidance notifications off, navigation with route on
                      all i want to say the solar it’s beyond my expect.
                      But,now the battery is 38% now,i only do 1 hour hike , sleep with sv
                      when the the lastest update, the battery is 40%, i update, after that, the battery drain fast , i drain the battery to there is a charge icon on the watch face( with several exercise), i charge it to full, and i do power off and power on.
                      seetings:
                      back light to off
                      standby off
                      alarm clock on
                      no notifications
                      h24 and sleep hr tracking on
                      blood oxygen off
                      best gps settings
                      no SuuntoPlus
                      Z 1 Reply Last reply Reply Quote 0
                      • Z Offline
                        zewen @zewen
                        @zewen
                        @zewen said in Battery drain:
                        full charge, last 21days during this time, i walking/running/ultra running for 39.6 hour, 1 hour weight exercise, only exercise and sleeping i wear my SV
                        seetings:
                        back light to off
                        standby off
                        alarm clock on
                        no notifications
                        blood oxygen off
                        best gps settings
                        no SuuntoPlus
                        winter, SV almost under my cloth, solar can ignore
                        • sartoricS Offline
                          sartoric Moderator @Gilles D.
                          @Gilles-D said in Battery drain:
                          Soft reset (12sec long press ) doesn’t erase maps
                          SVTS - 2.50.28
                          • Marton AttilaM Offline
                            Marton Attila
                            It seems the problem persist. I completely drained the battery and charged from 0% to 100% It worked until it reached 70%-65% battery, from there it’s downhill pretty fast. I think the battery indicator is wrong somehow. For 2 days I had from 100% to 98% almost. Now from 65% I lose about 4% per night.
                            LisztoL Emi OrtizE Patrick RxP 3 Replies Last reply Reply Quote 0
                            • Antoine LancrenonA Offline
                              Antoine Lancrenon Bronze Member
                              Only 28% left since the 11th of July… Yes I used ~2h tracked activity per day. Still I think it drains too much. I am loosig 3% during the night,.24hrs HR tracking. a part of that, everything is off or low. I am still pretty disappointed by the battery of the vertical solar. I have never went beyond 12 days without recharging. Far from the spec.
                              I 1 Reply Last reply Reply Quote 0
                              • LisztoL Offline
                                Liszto @Marton Attila
                                As @sartoric closed my previous post to avoid duplicate (thanks to redirecting me here)
                                I’ll post my experience here :
                                I acquired recently a Suunto Vertical solar (following the refurbish system) in May
                                Everything was good in term of battery drain (something similar to what suunto announce on their website).
                                But following the last system update I noticed a HUGE battery drain (roughly 10% / day) which is definietly not normal.
                                Consumption during workout seems “normal” but it’s hard to judge.
                                So I tried at least one thing (I didn’t have soft / hard reset for now) :
                                I just shutdown the watch and switch it on again.
                                I charge the battery till 100%
                                Following the “reboot”, the watch started to act “normal” and consume 1-2% during the following day.
                                Right after this day without any workout, I made a workout for a duration of 6h30 (GPS double precision, heartrate etc…) and the watch lost around 10-11% (seems accurate & normal to me).
                                BUT following this activity, the watch starts again its bad behavior and since it losts again 10% / day.
                                Have you any idea ? I supposed it’s nor normal because everything was ok the month before the update.
                                I can try a soft reset but I would avoid the hard one 😕
                                Thanks again for people who can help me and if you need more informations, feel free to ask 🙂
                                • I Offline
                                  Iggge @Antoine Lancrenon
                                  @Antoine-Lancrenon I will let my watch get to zero and after that charge it to 100%. Hope that will solve the problem for me as it has for others.
                                  My watch has since the new release used about 10% (12% today) each day. Before the update it was about 3-5%.
                                  thanasisT 1 Reply Last reply Reply Quote 1
                                  • freeheelerF Offline
                                    freeheeler
                                    I saw mine eating battery like potato chips over the past few days. will observe and report
                                    living sideways
                                    • thanasisT Offline
                                      thanasis Bronze Member @Iggge
                                      If anyone wants to make the battery drain real fast, put the ohr on a glass surface when not wearing . It makes it discharge much faster. I am taking this approach to get to the 0% in the next couple of days so that to make it for the weekend
                                      • sartoricS Offline
                                        sartoric Moderator
                                        Mine seems ok.
                                        I’m at 49% after 10 days, with activities and 24/7.
                                        Maybe some of the other options is draining more than expected (eg. I don’t have phone BT always on)
                                        SVTS - 2.50.28
                                        • SuperFlo75S Offline
                                          SuperFlo75 Silver Members Bronze Member
                                          My SV seems ok, too. I updated at 03.07.24 with 38% battery, and I charged from 6% to 100% battery at 15.07.24… this consumption was as I would expect it. And now, I will see.
                                          Suunto Vertical 2 Titanium Sage
                                          Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                                          Suunto Wing
                                          Suunto 9 Peak Pro Titanium (owns my wife now)
                                          Suunto Spartan Ultra
                                          SA iOS 3.13.1 (23404)
                                          Instagram @superflo75
                                          • Zdeněk HruškaZ Offline
                                            Zdeněk Hruška Bronze Member
                                            Hi guys just to share my experience with the battery drain. It was terrible after the update eating around 10% of the battery a day. But after maybe two cycles when I charged the watch from around 30% to the max it seems to be stable again and back to the previous consumption. I believe in many cases it will end up the same and there isn’t probably any issue that should be fixed (I can’t be sure of course). For now it seems to be ok so I am happy with that:)
                                            1 Reply Last reply Reply Quote 4
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
