    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery drain
    Scheduled Pinned Locked Moved Suunto Vertical
    760 Posts 137 Posters 369.5k Views 114 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • gerasimosG Offline
      gerasimos Bronze Member @MeazzaS9
      @MeazzaS9 @Dimitrios-Kanellopoulos đź’Şmaybe have better feedback for this problem.
      Suunto Vertical Ti
      Suunto S9 gen1
      Suunto Ambit3 peak
      • Antoine LancrenonA Offline
        Antoine Lancrenon Bronze Member
        is it possible that the (in connectivity in the watch)
        wireless network and discovery options.could impact the battery drainage?
        Once i have downloaded my offline maps, i have set to off the wifi and turn off the discovery, as my watch is already paired with my phone.
        I will test and let you know. i am saying that, is that as soon I have reactivate the wifi from the app to the watch, i noticed the battery being drained again 4% a day or even more. I should be more around 1-2% a day.
        • thanasisT Offline
          thanasis Bronze Member @gerasimos
          @gerasimos said in Battery drain:
          Same problem after last big update!
          i just deactivated the hr measurements and things are great.
          gerasimosG 1 Reply Last reply Reply Quote 1
            gerasimos Bronze Member @thanasis
            @thanasis i never have HR on always off… sometimes and in activities
            Suunto Vertical Ti
            Suunto S9 gen1
            Suunto Ambit3 peak
            thanasisT 1 Reply Last reply Reply Quote 0
            • thanasisT Offline
              ok, then can you try to reset the watch and give it a try?
              • Emi OrtizE Offline
                Emi Ortiz
                Tengo el suunto vertical solar, los dias despues de la nueva actualizacion me gastaba 10% de bateria al dia, reinicie y cargue hasta el 96% y parece ser que problema solucionado, pero le dio el sol 30 minutos y cargo hasta el 100% cuando antes no hacia eso, alguien puede decirme si le ocurre lo mismo?
                  @thanasis next step hard reset
                  Suunto Vertical Ti
                  Suunto S9 gen1
                  Suunto Ambit3 peak
                  • matteo_000M Offline
                    matteo_000
                    Hi, from the last update I have seen the some problem.
                    Two day ago I have charged at 100% my SV and at the some time at the next day (24 h with night monitoring) my SV was at 90%: 10% off in one day without any sport activity 🙄 🙄 🙄
                    Yesterday I have made soft reset … I let you know about evolution.
                    SV2 All Black - Italy
                    gerasimosG 1 Reply Last reply Reply Quote 2
                      gerasimos Bronze Member @matteo_000
                      @matteo_000 maybe some experts here like @isazi @pavel-samokha💪🔺 have better feedback with that problem
                      I think after soft reset and a full charge cycle i have better results.
                      Let’s see
                      Check out an turn off backlight standby, wifi, Bluetooth in daily use
                      Suunto Vertical Ti
                      Suunto S9 gen1
                      Suunto Ambit3 peak
                      • HighlandsH Offline
                        Highlands
                        Following the topic. No problems on my SR after the update but a friend of mine with SV does have some battery drain after updating. What should I advise him? He already did the reboot by holding the upper button, switching off the pulseOX, brightness on low etc. Still draining more than he was used to see prior the update.
                        • G Offline
                          ggrego Bronze Member
                          Même problème chute de la batterie depuis la dernière mise à jour j’ai réinitialiser la montre depuis aucun problème
                          Michaël POINTEAUM 1 Reply Last reply Reply Quote -1
                          • MichaĂ«l POINTEAUM Offline
                            Michaël POINTEAU @ggrego
                            @ggrego same here. In 3hrs doing nothing drop from 20% to 16%…
                            Michaël POINTEAUM 1 Reply Last reply Reply Quote 1
                            • I Offline
                              Iggge
                              Have been seeing same here on my watch. For first time since I bought the watch did have to charge my watch two times in a week.
                              Monday I did charge it to 100%.
                              Today is was 42% with just one use during training(30 min running)
                              • M Offline
                                MeazzaS9
                                Recharged the watch on July 9th to 100% and after doing a soft reset (first time with the new software). Since that day he has consumed very little, 1% per day (I only wear it for training) and 1% for 1 hour of running training. Today I did 3 hours of Trail running with a map and itinerary not always selected and it left me ONLY 5% very happy. Once I get home I put it on airplane mode and after two hours I find it at 86%!!! Something wrong. I had already seen this anomalous consumption with version 2.33.14 Do you know if Suunto knows about the problem and is working on it? With vertical battery is a reason of choice for the user.
                                Suunto Race S Gravel Gray (2024)
                                Suunto Vertical Black Lime (2023)
                                Suunto 7 Graphite Copper (2021)
                                Suunto 9 Baro Black (2020) sold
                                  Dimitrios Kanellopoulos Community Manager
                                  Hi guys. Let it discharge and do a full circle charge.
                                  Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
                                  M matteo_000M gerasimosG AntoineA M 6 Replies Last reply Reply Quote 4
                                  • M Offline
                                    MeazzaS9 @Dimitrios Kanellopoulos
                                    @Dimitrios-Kanellopoulos is it the permanent solution?
                                    • Ars VitaeA Offline
                                      Ars Vitae Silver Members
                                      I can only confirm from my side that my Vertical after the new update consumes the battery literally three times faster than before. A short circuit exercise used to be only 1% of battery, now 3%, a 35 minute run used to be 3% now over 10%. I have the same GPS settings, all others as well. I’m not sure the new changes were necessary enough to undermine one of this watch’s most important features…
                                      • sartoricS Offline
                                        sartoric Moderator
                                        probably battery needs to recalibrate (as it almost happens after every fw update)
                                        I have no such problem. Slightly less than 40% (34) drain in 8 days with at least 1 activity every day and almost 4h of gps.
                                        After the Fw update I discharged it to 13% before recharge
                                        Anyway, this time, I’ll let it discharge to the “battery icon” just to be sure to recalibrate properly
                                        SVTS - 2.50.28
                                        SSSWHR BARO Amber - 2.8.32
                                        Samsung A5 2016 - Android 7.0
                                        Suunto App Android 6.11.12 beta
                                          Michaël POINTEAU @Michaël POINTEAU
                                          @Michaël-POINTEAU factory reset yesterday.
                                          Sadly one thing already confirmed fixed: media control.
                                          Sadly because that means watch full setup to be done again.
                                          Sadly because this is not something we shall have to do to get our features back. At least it shall be properly communicated upfront.
                                          Especially when in summer season’s when you expect to use your watch intensively and potentially leave to location where network might not be that great or even capability to plug the watch.
                                          Hopefully this will also resolve the battery drain.
                                          Nevertheless the watch connectivity with the app is awful right now.
                                          I will have to spend time.again fixing that too.
                                          Disappointed overall despite the new climb pro feature to be honest.
                                          I was promotion Sunnto for it’s reliability no later than this week.
                                            matteo_000 @Dimitrios Kanellopoulos
                                            @Dimitrios-Kanellopoulos discharge until 0%??? I habitually recharge the watch when the battery was about 20-15% anyway not under 10% for doesn’t stress the lithium battery. Is correct???
                                            sartoricS 1 Reply Last reply Reply Quote 2
                                            With your input, this post could be even better đź’—
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
