    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 741.9k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J Offline
      jakubdr Bronze Member @SuperFlo75
      @SuperFlo75 I have installed nearly whole Europe and also no issues.
      SuperFlo75S 1 Reply Last reply Reply Quote 1
      • Dante MclallaD Offline
        Dante Mclalla Bronze Member @Guest
        @tomasbartko said in Suunto Vertical: Bug Collection:
        @Egika this is well possible and I am not arguing about that, just my experience so far.
        I do agree. We are here to list the issues we are facing and not to challenge Suunto as a company. So many issues however is annoying and make me thinking that the software at the time of the release is still immature and that’s a pity in light of the cost of this watch.
        • EgikaE Offline
          Egika Platinum Member @Mitch9
          @Mitch9 ok. Thank you. This is way too much battery consumption indeed.
          Independently of the solar charging, the problem is something else.
          There are open bug reports at Suunto right now regarding this issue.
          Cheers
          • SuperFlo75S Offline
            SuperFlo75 Silver Members Bronze Member @jakubdr
            @jakubdr That sounds good!
            Suunto Vertical 2 Titanium Sage
            Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
            Suunto Wing
            Suunto 9 Peak Pro Titanium (owns my wife now)
            Suunto Spartan Ultra
            SA iOS 3.12.0 (22937)
            Instagram @superflo75
            • surfboomerangS Offline
              surfboomerang @Mitch9
              @Mitch9 The solar widget doesn’t seem to work indeed. The graph on the watch face does.
              I also noticed touchscreen can stop reacting in the middle of the activity. Next time try to select “Map only”. In my case it started working again.
              @Mitch9 said in Suunto Vertical: Bug Collection:
              Before activity: ca. 85 % (5:00 am)
              After activity: ca. 60 % (4:00 pm)
              For reference, my watch uses 4% in 3 hours of windsurfing (a.k.a. solar heaven) with all options enabled except the display. Extending it to 11 hours you would end up with 14%-15% drain.
              Suunto Vertical Titanium Solar
              OnePlus Nord 4
              • Mitch9M Offline
                Mitch9 Silver Members @Mitch9
                Feedback after first mountaineering tour:
                • S+ app “safe” not working (black screen)
                • touchscreen stopped working not during activity (after soft reset everything was fine)
                • solar widget shows strange data for saturday (after more than 11 hous activity with sun burn despite three time sun protection with 50 SPF)
                Interesting: Now the widget updated the data (no idea why this happened!) and this is more realistic.
                Watch: Suunto Vertical Titanium Solar (Sand)
                SA: Android (beta)
                HRS: Polar H10
                • D Offline
                  dombo Bronze Member
                  I finally managed to discharge my Vertical completely (there was connect charger icon on the display) in order to calibrate the battery.
                  When I connect it to the charger, first I saw battery is charging, later watch boot up. I let it on the charger, but I noticed there was no charging screen and it stopped to charge with 5% showed on the watch face without increasing. I had to disconnect/connect charger in order to get charging screen and continue to charging.
                  I’m not sure if this is by design, as just connecting the watch to the charger does not ensure battery will be charged (even after few hours).
                  also my question is, if this will calibrate the battery as charging cycle was interrupted?
                  J EgikaE 2 Replies Last reply Reply Quote 0
                  • J Offline
                    Jugger @dombo
                    @dombo I had also same issue when loading my empty SV. I had maps on download and it started at the same time. Watch was beeping 🙄 for a minute before map download started and sounds where gone. After maps where succesfully downloaded I had 9% battery and it didn’t continue loading battery. After disconnect/connect it did load full. Calibration seems to be working dispite that. After 10 days still 48% with 24/7 HR and few hours of GPS.
                    • Stoke80S Offline
                      Stoke80
                      I think it was mentioned before, but couldn’t find it anymore:
                      Incoming messages are not always notified with vibration and highlighted on the screen on the SV.
                      If I check afterwards, they are shown in the message widget, but as said not highlighted on the main screen and notified with vibration.
                      At the moment I would guess, it’s about 50% of the notifications which are not highlighted
                      Suunto Quest / Suunto Ambit 3 Peak / Sununto Spartan Sport Wrist HR / Suunto 9 Baro / Suunto 9 Peak Pro / Suunto Vertical / Suunto Race S / Suunto Race 2
                      • Frederick RochetteF Offline
                        Frederick Rochette Bronze Member
                        This morning I did a 3h45 trail ride using the map plus navigation.
                        When I started I was at 100% battery and by the end I was down to 86%.
                        I should point out that the GPS is in ‘best’ mode and that I was often in direct sunlight.
                        isaziI 1 Reply Last reply Reply Quote 0
                        • EgikaE Offline
                          Egika Platinum Member @dombo
                          @dombo no problem. The calibration points for the battery management are the shut-down voltage at the low end and the full-charge voltage at the high end. Whatever mAh goes into or out of the battery if added up - continuously or interrupted makes no difference.
                          1 Reply Last reply Reply Quote 3
                          • isaziI Offline
                            isazi Moderator @Frederick Rochette
                            @Frederick-Rochette how many S+ apps? Or none at all?
                            Blog: isazi's home
                            Frederick RochetteF 1 Reply Last reply Reply Quote 0
                              Frederick Rochette Bronze Member @isazi
                              @isazi only one : weather
                              Ivan De RasisI isaziI 2 Replies Last reply Reply Quote 0
                              • Ivan De RasisI Offline
                                Ivan De Rasis @Frederick Rochette
                                @Frederick-Rochette said in Suunto Vertical: Bug Collection:
                                Stranamente non riesco più a trovare nel menu di SV la funzione feedback dalle impostazioni
                                Suunto 9 Baro
                                Suunto Vertical
                                • isaziI Offline
                                  @Frederick-Rochette that’s too much indeed. Let’s wait a couple of weeks for the hotfix and then we’ll see if logs are necessary.
                                  Blog: isazi's home
                                  Frederick RochetteF 1 Reply Last reply Reply Quote 4
                                    Dimitrios Kanellopoulos Community Manager
                                    Weather app destroys the battery , known
                                    Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard or use mcp.
                                    surfboomerangS D 2 Replies Last reply Reply Quote 6
                                      surfboomerang @Dimitrios Kanellopoulos
                                      @Dimitrios-Kanellopoulos Also other known issues with S+ apps?
                                      OnePlus Nord 4
                                      E 1 Reply Last reply Reply Quote 0
                                      • D Offline
                                        dombo Bronze Member @Dimitrios Kanellopoulos
                                        @Dimitrios-Kanellopoulos it was discussed on the forum already… but… we all bought the product for a full price (Vertical), which has lot of bugs. we are testing, continue reporting, loosing our data,… I would expect from Suunto at least list of acknowledged bugs, advises for workarounds and more open communication.
                                        because waiting undefined couple of weeks for hotfix firmware update is not pleasant at all.
                                        isaziI Dimitrios KanellopoulosD Brad_OlwinB S 4 Replies Last reply Reply Quote 4
                                        • babychaiB Offline
                                          babychai Silver Members
                                          Hi,
                                          2 days ago i hike for 9 hours 17 mins. i wear SV (stainless steel) and S9P at the same time to track my hike.
                                          SV i use performance mode and i only turn on Weather S+ app. battery from 85% drop to 45%
                                          S9P i use performance mode without turn on any S+ apps. battery from 95% drop to 55%
                                          SV i did click more button for navigation but didn’t expect the amount of percentage dropped is same with S9P
                                          as i read from forum here turn on 2 S+ apps will drain more battery. so is it turn on any 1 S+ app will also drain more battery?
                                          Suunto Vertical Titanium Solar Black
                                          Suunto 9 Peak All Black
                                          Suunto Spartan Trainer Wrist HR (Black)
                                          • isaziI Offline
                                            isazi Moderator @babychai
                                            @babychai some apps drain too much battery, this will be fixed.
                                            Blog: isazi's home
                                            babychaiB 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
