    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical: Bug Collection
    Scheduled Pinned Locked Moved Suunto Vertical
    1.1k Posts 183 Posters 715.9k Views 155 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • mikekoski490M Offline
      mikekoski490 Bronze Member @gone troppo
      @gone-troppo Ditto so far.
      Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
      Current: Suunto Race Ti
      Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
      Suunto App running on Google Pixel 8/Android 14
      • cs2ndC Offline
        cs2nd @gone troppo
        @gone-troppo Thank you for your note. This is reassuring.
        Suunto Race Ti
        Suunto 9 Peak Ti
        • AlexndreA Offline
          Alexndre
          When I do indoor rowing why does my watch indicate the cadence and distance when it can’t calculate them ?!
          Suunto Vertical
          • jjpazJ Offline
            jjpaz Bronze Member @gone troppo
            @gone-troppo There are several “minor” bugs that need to be corrected.
            In my case:
            • Initial setup required 2 soft reset to be able to configure intensity zones.
            • Several S+ Apps doesn’t work as expected and doesn’t offer reliable data (and data offered is very different as data in the Apps and watch)
            • Recovery and resources doesn’t work, is reported to Suunto also.
            • Random reboots during activity: it happened to me one time this weekend, testing maps. When moving map in the screen watch during a “walking” activity suddenly rebooted. And it was only “10 days old”, not an old and overloaded watch.
            • Random reboots when switching widgets: some people have suffered this, is not my case.
            So, many of the problems are “minor” or not very important but the problem with the random reboots is very very important because if that issue becomes recurrent the watch becomes unstable and unreliable and it seems that are not isolated cases.
            I hope that this initial software is an “advanced Beta version” and a more pulished software is coming and the unreliability problems will be solved.
            Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
            Brad_OlwinB 1 Reply Last reply Reply Quote 4
            • aroo7A Offline
              aroo7 Bronze Member
              It should definitely look better. These unexpected reboots are incredibly annoying. Recovery time is also to be improved - on Sunday I had 120h, this morning it was 8h… The S9PP may have been a bit run-of-the-mill but it looked more stable. I hope we won’t have to wait long for an update
              • wmichiW Offline
                wmichi
                Resources are still a joke. For example, I do a very easy bike ride for 1.5h. HR in zone 1 all the time -> resources drop sometimes after syncing the activity from 80% to 25%. I do a short stretching routine, resources drop sometimes from whatever value to 0%. The only Suunto watch where the resources seemed to work as intended, was the Suunto 7. I thought with real 24/7 HR it would also work correctly on the Vertical. It doesn’t. Get rid of this Firstbeat crap.
                • K Offline
                  Kramble @runomatic
                  @runomatic said in Suunto Vertical: Bug Collection:
                  Turn by turn navigation with imported GPX Tracks (via STRAVA) doesn’t work. Anybody else with this problem?
                  Yes it’s the same on my S9 peak.
                  Ambit 3 peak saphir
                  Spartan Ultra (sold)
                  S7 graphite copper
                  S9 peak all black
                  Vertical titanium green forest
                  Wings
                  TieutieuT 1 Reply Last reply Reply Quote 0
                  • TieutieuT Offline
                    Tieutieu Platinum Member @Kramble
                    @Kramble said in Suunto Vertical: Bug Collection:
                    Turn by turn only works with routes made with SA or komoot
                    Suunto’s devices at home :
                    Vertical titanium solar
                    Suunto Race S
                    S9pp titanium sand
                    Suunto Wing & Spark
                    S9B titanium Ambassador edition, A3P, X6
                    • Jacob FisherJ Offline
                      Jacob Fisher
                      Adding another bug related to my previous bug of the watch crashing causing a soft reset of the watch. While starting a standard run, the vertical got stuck on the loading screen and was unable to start the run without soft resetting the watch again. I checked and the watch is up to date
                      • Brad_OlwinB Offline
                        Brad_Olwin Moderator @jjpaz
                        @jjpaz said in Suunto Vertical: Bug Collection:
                        In my case:
                        These "bugs are not happening to all and that makes them a bit more complicated.
                        1. I have not had the HR zone issue with the production firmware at all on 2 different Vertical watches set up from factory settings.
                        2. All the S+ apps I have tested worked under the conditions I tested them, which are not working for you?
                        3. Recovery and resources are working well for me and match other Suunto watches and generally match other brands as well. These are quite dependent on how the user sets them up.
                          1. I have not had a random reboot during activity or moving/deleting/adding Widgets.
                        So, I am not saying you are not having these issues but wanted to make you aware that during testing these either did not occur or are rare even among the testers. So, it may take some time to get to the root of the issue. It is likely partly due to how you have the watch set up and how you are using it. I am sorry this is happening to you as it should not be but hopefully will be corrected quickly.
                        Vector/T6c/Vertical 2 Ti
                        jjpazJ 1 Reply Last reply Reply Quote 5
                        • jjpazJ Offline
                          jjpaz Bronze Member @Brad_Olwin
                          @Brad_Olwin Yes, clearly issues are not happening to all, I’m only talking about my experience.
                          The problem when setting intensity zones: just out of the box and after upgrading was impossible to set up rythm and power zones3. No problem with HR zones.
                          S+ not working for me: TP Heart Rate (TSS) and Strava Relative Effort. Data that SuuntoApp show are very very different to data calculated by watch, SuuntoApp, TrainingPeaks and Strava. So those SuuntoApps are using different source data to calculate and are not useful, no reliable data.
                          Recovery: after a workout the watch calculates a recovery time, OK. If you check periodically the Recovery time widget you can verify that it’s frozen and doesn’t change although my recovery and resources are going up. In previous watches that time is going down to reach 0 after severas hours. And if you save another workout with recovery time “active” the new recovery time erases the old and the loop start again. Or, in my case, you save a light session, like yoga or pilates, directly puts 0 en recovery time. A bit random.
                          gone troppoG 1 Reply Last reply Reply Quote 0
                          • gone troppoG Offline
                            gone troppo Bronze Member @jjpaz
                            Question please if someone could help I don’t know if it’s a bug or glitch but. I have created several custom sport modes. When I select a sports mode it takes me to the screen where I can change battery settings etc. anyway when I go into battery it defaults to “custom” which is dual band. I want to change it to endurance so I click that and click select but when I go to the sport it hasn’t changed and is still on custom dual band?? The only work around I found was to actually start the activity immediately pause It and then change it to endurance there that seems to work? Is this a known issue?
                            Side note I managed to get he 0% resources error others have mentioned here. I woke up with 72% did an easy zone 1 excercise and after uploading activity it now shows resources 0%
                              gone troppo Bronze Member @gone troppo
                              Never mind the above I worked out the problem after selecting the different battery mode I was pressing the middle button which was going back and then I was re selecting the activity and this would then default back to custom battery. Once you choose the battery mode you want you press upper right button to select and then you press it again until you get to start and then it will use the battery mode you chose. Sorry this might have been stupid to most but I couldn’t work it out so someone else may have the same problem and read this. User error
                              The resource going to 0% is still a legit issue though that happened today though.
                              • Mitch9M Offline
                                Mitch9 Silver Members
                                I got my first annoying bug:
                                While hiking with a route activated, I got a notification with vibration that I’m not on track. So far so good, but the vibration didn’t stop for a long time. I tried different things (pause, resume, deactivate route…) but the vibration continues except for some little breaks.
                                Maybe a unknown massage feature? 😁
                                Couldn’t sent logs but next time (Hopefully this will never happen again!).
                                Watch: Suunto Vertical Titanium Solar (Sand)
                                SA: Android (beta)
                                HRS: Polar H10
                                • Mitch9M Offline
                                  The illustration of the region Lower Franconia is not correct.
                                  SA: Android (beta)
                                  HRS: Polar H10
                                  • SuperFlo75S Offline
                                    SuperFlo75 Silver Members Bronze Member
                                    Crazy, on my phone it is correct… 🙈
                                    Suunto Vertical 2 Titanium Sage
                                    Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                                    Suunto Wing
                                    Suunto 9 Peak Pro Titanium (owns my wife now)
                                    Suunto Spartan Ultra
                                    SA iOS 3.12.0 (22937)
                                    Instagram @superflo75
                                    • helgonet12H Offline
                                      helgonet12
                                      Hi! I turned off my Blood Oxygen under sleep. But it shows up in Suunto App? I double checked that it really was turned off and it was. Is there any other place I need to turn it off or is this a bug?
                                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                                        Dimitrios Kanellopoulos Community Manager @helgonet12
                                        @helgonet12 said in Suunto Vertical: Bug Collection:
                                        reported this
                                        Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                                        • jjpazJ Offline
                                          jjpaz Bronze Member
                                          About recovery widget:
                                          Yesterday I finished my training at 19:00, watch showed 17h in recovery time. So recovery time should be decreasing gradually until 12:00 on next day.
                                          Just before going to bed (22:30) I watched the widget and it showed the same 17h for recovery time.
                                          This morning (7:00) watch showed 11h in recovery time (-6h).
                                          Now (12:35) the watch is still showing the same 11h in recovery time.
                                          This is not the behavior in previous watches (S9B and S9P that I have) and I can assume that it’s going to show 11h until this afternoon when I’ll save another training and replace the recovery time.
                                          jjpazJ D 2 Replies Last reply Reply Quote 0
                                          • jjpazJ Offline
                                            jjpaz Bronze Member @jjpaz
                                            @jjpaz auto update:
                                            13:30 --> Recovery time 11h.
                                            14:00 --> Recovery time is now 0h. So, has decreased from 11h to 0h instantly.
                                            isaziI 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
