    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical is here
    Scheduled Pinned Locked Moved Suunto Vertical
    1.2k Posts 139 Posters 550.3k Views 122 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • surfboomerangS Offline
      surfboomerang @Dimitrios Kanellopoulos
      @Dimitrios-Kanellopoulos said in Suunto Vertical is here:
      There is a hotfix release being prepared so we wanna get your covered.
      I’m asking the forbidden question here. Any ETA on the hotfix release?
      Suunto Vertical Titanium Solar
      OnePlus Nord 4
      gone troppoG EgikaE 2 Replies Last reply Reply Quote 7
      • gone troppoG Offline
        gone troppo Bronze Member @surfboomerang
        The build quality and engineering on this watch is just incredible second to none. Suunto have outdone themselves. I hope this company continues to make watches in Finland to be this standard. Bravo suunto 🙌
        1 Reply Last reply Reply Quote 9
        • EgikaE Offline
          Egika Platinum Member @surfboomerang
          @surfboomerang no one here here can make promises or predictions, but putting your money on June would not be a too bad decision imo.
          It is currently being worked on.
          …still unforeseeable events can can always happen…
          • Mff73M Offline
            Mff73
            Sorry i question was already asked 😉
            To download a map in SV, watch need to be connected to Wifi, and maps selected in SA. All these task needs SA, thus the phone/tablet…
            Download will be triggered once SV will be on charger.
            But, should SA and the phone need to be near the watch for ALL the downloads to happen, or all informations for all map download are send to the watch once and then watch is autonomous to download everything as long as on charger ?
            Use case : you left home with your phone with you and SV is working alone for many Gb downloads 🙂
            SSU (retired), SV1, SV2
            Wife : S9PP
            SA: Always the latest beta :)
            Android + Galaxy S205G
            L EgikaE Brad_OlwinB 3 Replies Last reply Reply Quote 0
            • L Offline
              Likarnik Gold Members @Mff73
              @Mff73 omg, not acceptable to leave home without SV!
              Mff73M 1 Reply Last reply Reply Quote 1
              • Mff73M Offline
                Mff73 @Likarnik
                @Likarnik said in Suunto Vertical is here:
                as long as we accept to wait for map download 🙂 , sometime no choice 😉
                [edit] or put SV on powerbank and connect it to cell phone wifi hotspot
                Wife : S9PP
                • EgikaE Offline
                  Egika Platinum Member @Mff73
                  @Mff73 no need to keep phone connected to the watch while downloading.
                  You select the maps using the app.
                  Then connect watch to charger within range of Wifi and leave the house with your phone.
                  Maps will load.
                  You just get the convenience to check the download status on the phone while it is connected (and this might change in future as well)
                  • Mff73M Offline
                    Mff73 @Egika
                    @Egika
                    thanks 😉
                    I understand that wifi may consume lots of battery, thus having to put it on charge to ensure nothing will break due to battery.
                    But i can’t help thinking about “map updates” and not just initial download.
                    If battery life is so enormous, we may not put the watch on charger so often (for battery needs), but maps may not be updated until put on the charger ? 🤔🤔
                    OK, everything is still changing i guess.
                    other question (maybe no asnwer yet ) : map update = “just update” or “full redownload” ? Hoping it could be just updating “modified” map tiles 🤞
                    Wife : S9PP
                    isaziI 1 Reply Last reply Reply Quote 0
                    • isaziI Offline
                      isazi Moderator @Mff73
                      @Mff73 in a future update should be just the changed parts, but this is not implemented yet, so current solution is remove and download again.
                      Blog: isazi's home
                      • Mff73M Offline
                        Mff73 @isazi
                        @isazi said in Suunto Vertical is here:
                        understood and normal at this stage.
                        but, when should we know that an “update” is there ?
                        I mean, download is long enough (not critic) not to afford so often to delete maps to redownload them. Any kind of notification or hint that it is worth trying ?
                        Wife : S9PP
                        isaziI TieutieuT 2 Replies Last reply Reply Quote 0
                        • isaziI Offline
                          @Mff73 I don’t know, I think that if Suunto would do an overhaul of the maps will notify us some way. Transfers are also expensive for Suunto, so I believe they will work on smart updates soon enough.
                          Blog: isazi's home
                          • TieutieuT Online
                            Tieutieu Platinum Member @Mff73
                            @Mff73 said in Suunto Vertical is here:
                            IMHO even if a map gets update, zones are so large that it probably more unlikely that updates will really impact a lot.
                            So for me right now, getting updates is really not a big concern. Maps are already good enough😊
                            Suunto’s devices at home :
                            Vertical titanium solar
                            Suunto Race S
                            S9pp titanium sand
                            Suunto Wing & Spark
                            S9B titanium Ambassador edition, A3P, X6
                            • Mff73M Offline
                              Mff73 @Tieutieu
                              @Tieutieu
                              good enough isn’t good enough 🙂
                              Maps are collaborative : i just added three new official existing paths last week.
                              Wait and see how it will go 🙂 But, i know that my personnal changes will be reflected next month for OpenAndroMap versions, that is this kind of info which is interesting.
                              Wife : S9PP
                              TieutieuT Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 2
                              • TieutieuT Online
                                @Tieutieu
                                I should also add some existing paths I know but I also like that some of them remain “un-excessivly used” !! 😊
                                Suunto Race S
                                S9pp titanium sand
                                Suunto Wing & Spark
                                EzioAuditoreE 1 Reply Last reply Reply Quote 1
                                • EzioAuditoreE Online
                                  EzioAuditore Gold Members @Tieutieu
                                  There are a couple of bands available in the german’s suunto store. Got 2 more 🙂 When the green forest is available I’ll have them all 😄 It has been said a lot of times but here it goes again: man this is a lovely watch!
                                  Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
                                  Suunto Wing
                                  HighlandsH 1 Reply Last reply Reply Quote 3
                                  • HighlandsH Offline
                                    Highlands @EzioAuditore
                                    @Hristijan-Petreski I’d love to see a new strap with the colors of the Ukrainian 🇺🇦 flag.
                                    S9PP / SV1 / SV2
                                    EzioAuditoreE 1 Reply Last reply Reply Quote 0
                                      EzioAuditore Gold Members @Highlands
                                      @Highlands Than you need only light blue and can combine with the lime 🙂 Contact suunto support for light blue (the old vertical if I remember correctly had smt similar) and ask it 🙂
                                      Suunto Wing
                                      HighlandsH 1 Reply Last reply Reply Quote 0
                                        @Hristijan-Petreski Contacting support is something I did some days ago. Let’s see what they’ll say. I wonder if any of you guys would buy a strap like this? Thank you.
                                        S9PP / SV1 / SV2
                                        EzioAuditoreE DMytroD L 3 Replies Last reply Reply Quote 1
                                          @Highlands Well if you asked specifically for Ukranian flag than I am not sure how will the other side react since I never want to mix politics with my work, hobby and life generally. There are some really sensitive subjects that opiniate and alienate people which I generally try to avoid hence politics are out of my discussions. But if you asked for light blue (being creative 🙂 ) you might get better results. Again I am all for peace everywhere but knowing human history and politicians this is something I guess will never be true!
                                          Suunto Wing
                                          • DMytroD Offline
                                            DMytro @Highlands
                                            @Highlands especially if part of the costs would go to humanitarian aid, than surely.
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
