    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical is here
    Scheduled Pinned Locked Moved Suunto Vertical
    1.2k Posts 139 Posters 645.5k Views 122 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • zhang965Z Offline
      zhang965 @v.sacre
      @v-sacre said in Suunto Vertical is here:
      @Frederick-Rochette VO2max appears only after a few sessions
      I got my vo2max after my first run.
      Winners Wear Winners
      • wmichiW Offline
        wmichi
        I went on a E-MTB ride today with my Vertical Solar. I had the watch on my arm (not mounted on the bike), weather was partly sunny (mostly cloudy), a lot of tree cover (shadows). I followed a 70km route and had the map displayed most of the time.The watch was in performance mode (multi band) and connected to Verity Sense.
        Before the workout I had 68%. 3h 45min later:
        64%, so about 4% to 5% lost in 3.75 hours. As you can see on the image, the watch didn’t see enough sun to take full advantage of solar charging. This is impressive!
        surfboomerangS 1 Reply Last reply Reply Quote 7
        • surfboomerangS Offline
          surfboomerang @wmichi
          @wmichi Same experience here. 3hr windsurf session here in relative sunny conditions. 4% battery used with all options enabled except the display.
          Suunto Vertical Titanium Solar
          OnePlus Nord 4
          1 Reply Last reply Reply Quote 3
          • Stefan KerstingS Offline
            Stefan Kersting Platinum Member
            My first run with the Vertical 😄
            Suunto nailed it! The GPS presisjon es from another world 😋
            When backcountry skiing I did som lapsing today and was going up in the same tracks and you have to zoom pretty hard to see that there are three tracks in the zickzack pattern. At its best the there GPS tracks are within 0,5 meters. Amazing! Even when running down you can see a curved line, on the S9B this was just a straight line down the slope.
            ![IMG_5636.PNG]
            (/assets/uploads/files/1684597791866-img_5636.png)
            Instagram: https://www.instagram.com/helgelandsbukken/
            https://www.instagram.com/suunto_adventures/
            IG: Helgelandsbukken, suunto_adventures
            Vimeo: vimeo.com/helgelandsbukken
            Blogg: https://turblogg.midnattsola.com
            1 Reply Last reply Reply Quote 9
            • TieutieuT Offline
              Tieutieu Platinum Member
              12h of exercices since initial full charging on thuesday, mostly with Maps activated (used a lot) and gps on performance mode, touchscreen activated during exercice.
              Backlight to low, turn to raise on minimum.
              No notifications, but sleep and hr tracking h24 activated.
              Still 72% battery.
              Sync with app used a lot, watch menus and widget used a lot.
              Impossible to say how much solar helped, but i guess it has a Little.
              The Vertical is a quite impressive tool !!
              Suunto’s devices at home :
              Vertical titanium solar
              Suunto Race S
              S9pp titanium sand
              Suunto Wing & Spark
              S9B titanium Ambassador edition, A3P, X6
              1 Reply Last reply Reply Quote 5
              • Kamil KamilK Offline
                Kamil Kamil
                Vertical vs 7? What is your opinion?
                A 1 Reply Last reply Reply Quote 0
                • A Offline
                  altcmd Silver Members @Kamil Kamil
                  @Kamil-Kamil There is a separate thread on this topic. Please check the forum.
                  • TieutieuT Offline
                    Hi ! Does someone experimented some kind of « auto-lock » during an exercice ?
                    Two times this morning the watch locked on while running, without using buttons to do it. And I’m 100% sur I didn’t pushed accidentally the buttons.
                    Couldn’t tell how long I had not touch the screen when it happened.
                    Not a big deal, almost a « good thing »
                    Suunto Race S
                    S9pp titanium sand
                    Suunto Wing & Spark
                    sartoricS 1 Reply Last reply Reply Quote 0
                    • sartoricS Offline
                      sartoric Moderator @Tieutieu
                      @Tieutieu
                      what do you mean for “lock” ?
                      does screen turn off or are just the buttons locked?
                      SVTS - 2.50.28
                      SSSWHR BARO Amber - 2.8.32
                      Samsung A5 2016 - Android 7.0
                      Suunto App Android 6.11.12 beta
                      TieutieuT 1 Reply Last reply Reply Quote 0
                      • TieutieuT Offline
                        Tieutieu Platinum Member @sartoric
                        @sartoric said in Suunto Vertical is here:
                        @Tieutieu
                        does screen turn off or are buttons locked?
                        Buttons get locked. Just as if I was doing a long press on the bottom one and then middle one to lock
                        Suunto Race S
                        S9pp titanium sand
                        Suunto Wing & Spark
                        freeheelerF 1 Reply Last reply Reply Quote 0
                        • lexterm77L Offline
                          lexterm77 Bronze Member
                          I can’t believe tracks on this thing?!
                          • freeheelerF Offline
                            freeheeler @Tieutieu
                            @Tieutieu
                            when you very quickly double tap the data screen you can lock the screen with a third tap on exactly the dedicated field in the “pop-up” lock screen
                            living sideways
                            • TieutieuT Offline
                              Tieutieu Platinum Member @freeheeler
                              @freeheeler said in Suunto Vertical is here:
                              @Tieutieu
                              Oh ! Didn’t know that and very possible that it is what happened so ! Thanks !
                              Suunto Race S
                              S9pp titanium sand
                              Suunto Wing & Spark
                              • MiniForkliftM Offline
                                MiniForklift Platinum Member
                                Love the watch, got the maps sorted (which was user error rather than anything on Suunto’s side) 😳
                                The only negative I can find is the charger, the magnets just seem to be very weak and with any slight knock or movement the watch just falls off it. Completely the opposite compared to the S9B where you almost have to physically pull the watch off!
                                SV Titanium Solar Forest
                                Brad_OlwinB 1 Reply Last reply Reply Quote 1
                                • Brad_OlwinB Offline
                                  Brad_Olwin Moderator @MiniForklift
                                  @MiniForklift my understanding is there are sensitive components inside that would be affected with a strong magnet. Hence, the change in charger starting with S9PP.
                                  Vector/T6c/Vertical 2 Ti
                                  MiniForkliftM SuperFlo75S 2 Replies Last reply Reply Quote 2
                                    MiniForklift Platinum Member @Brad_Olwin
                                    @Brad_Olwin said in Suunto Vertical is here:
                                    Thanks for the explanation, that makes sense. It’s only a pain if it’s not charging whilst stationary, for example I’ll quite often charge it while I’m driving. But not too much of a big deal I guess as you hardly have to charge the thing 😂
                                    • SuperFlo75S Offline
                                      SuperFlo75 Silver Members Bronze Member @Brad_Olwin
                                      @Brad_Olwin I‘m a bit confused about the charger… I got one with my S9PP and now one with the SV… they both look like they are the same, and they are both with a very weak magnetic force. I remember I read or hear somewhere in a SV review, perhaps DC Rainmaker?, that the Charger of SV is better than the charger of S9PP… 🤔 but you said there was a change with S9PP… 🤔
                                      Suunto Vertical 2 Titanium Sage
                                      Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                                      Suunto Wing
                                      Suunto 9 Peak Pro Titanium (owns my wife now)
                                      Suunto Spartan Ultra
                                      SA iOS 3.12.0 (22937)
                                      Instagram @superflo75
                                        freeheeler @SuperFlo75
                                        @SuperFlo75
                                        the change happened from S9P to S9PP. S9PP and SV chargers are compatible.
                                        you can see the difference also in the contact pattern. newer chargers have these button type connectors only
                                        living sideways
                                        SuperFlo75S 1 Reply Last reply Reply Quote 0
                                          SuperFlo75 Silver Members Bronze Member @freeheeler
                                          @freeheeler Ok, thank you for the information. But in the Suunto webstore, I could buy a charging cable compatible with S9P and S9PP… I can use the newer cable for the older device, but not the older cable for the newer device?
                                          Suunto Wing
                                          freeheelerF 1 Reply Last reply Reply Quote 1
                                            @SuperFlo75
                                            yes exactly, that’s what I did, too
                                            living sideways
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
