    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 baro very low elevation gain vs other brands
    148 Posts 21 Posters 46.2k Views 20 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • OktanO Offline
      Oktan
      Hi,
      Just want to say that Its a shame that I have a premium watch (Suunto 9 baro Titanium) and I still need to use the button in Strava to correct the elevation, vs my ride buddies which are using, Garmin, Wahoo etc.
      Shame! 😞
      Suunto 9 Baro Titanium & Ambit 3 Peak
      markytarkyM Brad_OlwinB M Antonino CoppolinoA 4 Replies Last reply Reply Quote 0
      • markytarkyM Offline
        markytarky Silver Members @Oktan
        @Oktan can you share more details? Some data?
        Instagram
        β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”β€”
        Watch: S9B customized, S9P all black
        Suunto App: iOS beta
        • surfboomerangS Offline
          surfboomerang
          Why do you need to correct it? Is this because of the 3m threshold?
          I find the altitude really accurate in the mountains.
          Suunto Vertical Titanium Solar
          OnePlus Nord 4
          • BulkanB Offline
            Bulkan Moderator
            I don’t get it, why do you think Strava is given you the right elevation?
            Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
            pilleusP 1 Reply Last reply Reply Quote 1
            • Dimitrios KanellopoulosD Online
              Dimitrios Kanellopoulos Community Manager
              I can help here but I need an activity to analyze this.
              Creator of quantified-self.io β€” a next gen training dashboard with MCP access, cross-service activity and route sync
              OktanO 1 Reply Last reply Reply Quote 0
              • Brad_OlwinB Offline
                Brad_Olwin Moderator @Oktan
                @Oktan Mine is dead on for elevation accuracy and gain/loss. You need to provide activities to support this. Corrections on Training Peaks for me are negligible, this is likely an issue with Strava.
                Vector/T6c/Vertical 2 Ti
                • pilleusP Offline
                  pilleus @Bulkan
                  @Bulkan said in Suunto 9 baro very low elevation gain vs other brands:
                  Yes. If I sync an activity from Suunto to Strava I can choose between recorded elevation gain from the watch and Strava elevation gain.
                  I never had a difference of more than 10 meters. My usual elevation gain with the bike is between 800 and 1000 m of climbing. πŸ‘
                  https://www.instagram.com/moves.are.life/
                  Suunto Vertical Black Lime
                  Suunto 9 Peak Pro Black
                  Suunto Spartan Ultra Stealth Titanium
                  • fazelF Offline
                    fazel Bronze Member
                    This is a pretty interesting topic.
                    I had posted a similar concern and @Dimitrios-Kanellopoulos demonstrated the raw data between my Garmin and Suunto was actually very similar in terms of gain / loss. This really comes down to the fact that Garmin is recording any changes of 1m or more, and Suunto only records changes of 3m or more. In my case, that resulted in a difference of around 300 meters over four hours of riding.
                    @Dimitrios-Kanellopoulos suggested this was β€œnoise” due to the Garmin counting differences less than 3m. Using PE = mgh I get around 225 KJ of work at my riding weight (including the bike) to climb 300 meters, so I’m not sure I completely agree.
                    I guess I wonder if this is really a philosophical decision (i.e., just β€œnoise”) or does this have anything due to battery consumption needs for recording changes of one meter or more.
                    isaziI OktanO 2 Replies Last reply Reply Quote 1
                    • isaziI Offline
                      isazi Moderator @fazel
                      @fazel said in Suunto 9 baro very low elevation gain vs other brands:
                      You are (or can be) right, but it all depends on the course. You can do a thought experiment of building a course in which those 300 meters are just bumps on the road after some longer descents, so you are using none of your energy reserves for those 300 meters πŸ™‚
                      I had amazing results with the S9 on really mountainous terrain, and I am perfectly okay with the results I have in the Netherlands. Obviously, if I was running on more hilly terrain I would have more to complain about.
                      Blog: isazi's home
                      fazelF 1 Reply Last reply Reply Quote 2
                      • fazelF Offline
                        fazel Bronze Member @isazi
                        @isazi Yes - I agree it surely depends on the terrain. On consistent grades there is probably very little separating the philosophies. Undulating probably more so. Your point regarding momentum has merit, but I was only trying to illustrate a point. Certainly some of that work I must do, even if it is accelerating on the back side of the small rise.
                        • OktanO Offline
                          Oktan @Dimitrios Kanellopoulos
                          @Dimitrios-Kanellopoulos Here is the activity: https://www.strava.com/activities/4486972002
                          Before the correction it was 1243 m. After the correction - 1542 m
                          • OktanO Offline
                            Oktan
                            and here is my wahoo elemnt recording:
                            • OktanO Offline
                              Oktan @fazel
                              @fazel similar to my case: 300 m on 5:22 hours riding
                              • sky-runnerS Offline
                                sky-runner Platinum Member
                                I complained about the same for as long as I used Suunto 9 Baro. Just to make it clear, absolute altitude measurement is reasonable accurate on S9B, but adding up all elevation changes, i.e. total ascent and total descent, is not. That is not visible on activities where you have just one or two big climbs and descents, but is quite visible during long ultras with multiple climbs or on even on shorter runs on rolling terrain. My estimate is that the watch loses 10-20 ft (3-7 meters) per climb, so if a run or ride has a lot of smaller climbs that adds up. That is based on my experience with S9B prior to February 2020.
                                One easy way to verify that is just to look at elevation profile and manually add up all climbs and compare to the total ascent reported by the watch.
                                Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
                                Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
                                markytarkyM isaziI 2 Replies Last reply Reply Quote 2
                                  markytarky Silver Members @sky-runner
                                  @sky-runner I don’t think this is a general issue. I use S9 baro for very long time for many different long and short runs with many long and short and small and big climbs. Never saw a problem. Not even comparing to the map.
                                  Instagram
                                  • fazelF Offline
                                    fazel Bronze Member
                                    I went back and looked at some recent workouts where I wore thee 9 and actually found tight agreement for most.
                                      Guys, another problem is if you have a free account Strava makes adjustments, the paid account seems to just take the data.
                                      Instagram
                                      sky-runnerS 1 Reply Last reply Reply Quote 0
                                      • A Offline
                                        andrewglipman
                                        I know that I am looking at the S9, not the Baro, but for me this is the way that the S9 calculates the ascent.
                                        Today I created a route in Suunto App with 778 ft elevation,Screenshot_20201219-131133_Suunto.jpg .
                                        Watch confirms this route profile: 20201219_123158.jpg
                                        Strava shows the same, but I will use corrected data Screenshot_20201219-123104_Strava.jpg
                                        So its missed off 300 ft of climb.
                                        In Strava I always have to hit the Use Corrected Data. linky
                                        My old 310XT never gave me the option to corrected data as it seemed to give the right amount. I manually added the main climbs and I get to at least 600+, not counting the undulations.
                                        Another run linky watch shows 1017 ft, but Suunto App shows 1788ft, Strava corrected shows 1866 ft.
                                        As I say, its those undulations that seem to be missing.
                                        I am confident that the watch knows the correct height as I have been on top of a local hill that is 780 ft, and the watch tells me the elevation is 770 ft or so, so I am happy with that part.
                                        BTW Liverpool are now 4-0 up…
                                        Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                          Dimitrios Kanellopoulos Community Manager @andrewglipman
                                          @andrewglipman suunto app counts 1m of ascent. Actually even less. This is not aligned with how the watch does it. And the same applies to all other route planners. It’s just how messy this situation is.
                                          So again there is a minimum of 3m climb needed to register ascent. That’s how it is and that’s how it reports accurate ascent for baro models.
                                          • A Offline
                                            andrewglipman
                                            The route had quite a lot of undulations that are certainly not enough to trigger adding it to the ascent.
                                            I will continue using the corrected data.
                                            Had the S9 for just over 1 year and still love it.
                                            With your input, this post could be even better πŸ’—
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
