    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!
    330 Posts 46 Posters 87.2k Views 48 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • freeheelerF Away
      freeheeler @Maryn
      @Maryn
      maybe he did not do the firmware update?
      living sideways
      MarynM 1 Reply Last reply Reply Quote 1
      • MarynM Offline
        Maryn Silver Members @freeheeler
        @TELE-HO maybe yes.
        In latest sw version time is shown if you set more than 3 fields on the screen.
        Of course, you can also put time(hour) as a seperate data field.
        Suunto Vertical, Suunto Race, Edge 530, Vantage V, Suunto Wings, Polar H10&Verity Sense
        • MarynM Offline
          @florin2528 said in Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!:
          • less accurate than Ambit2
          By the way, if you say that Ambit 2 has better gps then is highly likely that you are running an old software 🙂
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @florin2528
            from my side after more than 1.4k km with S9 Baro.
            cons:
            • sleep tracking, was not working properly. Taking movie watching and reading as sleeping. Garmin fenix5 didn’t do that. I’m not using it at all
              Florin
            This does not happen for me. If you have your normal sleep hours set and autoDnD set I never get sleep counted when reading or watching a movie. If you do not have sleep hours set it might be possible.
            Vector/T6c/Vertical 2 Ti
            • zvonejanZ Offline
              zvonejan Bronze Member @florin2528
              • you can’t see the time(hour) during an activity
              double tap or bottom button (2 sec)
              florin2528F 1 Reply Last reply Reply Quote 0
              • isaziI Offline
                isazi Moderator
                Doing an alpine climbing tour this week. The altimeter of the S9b is amazing, I have been sitting on a couple of summits with the watch agreeing with the map, same for huts. On the same group a Fenix 5s (or maybe 6s, but looks more a 5s to me) user got readings far by even 100 meters. And being this the first alpine tour I did with the S9, I’m very very happy.
                Blog: isazi's home
                Bogdan1921B MarynM 2 Replies Last reply Reply Quote 12
                • Bogdan1921B Offline
                  Bogdan1921 Silver Members Bronze Member @isazi
                  @isazi
                  I can confirm this. Also, last week I was one day for 9 hours on a hiking tour. When I’ve arrived at the peak of the mountain, the wrote altitude of the peak was exactly the same with the altitude from the watch and I was really impressed👍
                  Suunto Race
                  Polar H10
                  Iphone 14 Pro
                  Suunto 9 Baro [sold]
                  1 Reply Last reply Reply Quote 7
                  • MarynM Offline
                    Maryn Silver Members @isazi
                    @isazi what gps system did you use ? Beidou?
                    isaziI 1 Reply Last reply Reply Quote 0
                    • isaziI Offline
                      isazi Moderator @Maryn
                      @Maryn since it became available, I’m always using GPS+Beidou. Maybe GPS alone would be enough, but I’ve had good results with this setup so far and I’m not changing it for now.
                      Blog: isazi's home
                      lexterm77L 1 Reply Last reply Reply Quote 1
                      • lexterm77L Offline
                        lexterm77 Bronze Member @isazi
                        @isazi said in Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!:
                        I used gps+beidou and tracks were wobbly like a drunk going home on St. Patrick’s day. I turned off and use gpu only and tracks became clear.
                        • ? Offline
                          A Former User @lexterm77
                          @lexterm77 my experience is following: the best results I get, when I am waiting a few minutes when I got GPS conformation… I have always something to do… shoes etc. I think more satellites will connect then. I also try to connect in free areas and not in the woods. I think these start conditions are leading to best gps, even if you are afterwards in the woods… only connecting fast in not so free areas is not so good… Think this is also not Suunto specific…
                          Especially do this, if I am following in mountains or in the woods. Not if so much when I am running in flat free areas…
                          @Brad_Olwin @Dimitrios-Kanellopoulos right?
                          lexterm77L 1 Reply Last reply Reply Quote 0
                            lexterm77 Bronze Member @Guest
                            @mountainChris
                            My experience with trail running or hiking along a side of a river dam in heavily wooded area is best with gps only, any other combination reveals worse results as eastern sky is obscured. I always wait for gps lock, and I always start my hike on same stone and finish it to have a reference. I don’t know why is wobbly when it connects to more satellites. My ascent descent don’t match either if i use combination of gps-s, where gps only matches within 1m.
                            • ? Offline
                              @lexterm77 Do you have a statistic behind it? Could be also random…
                              I think there is a difference waiting for gps lock and waiting after gps lock further a few minutes if you plan running in woods. And also connecting first in free areas… I think I read this somewhere. Also just my feeling with runs…
                                @mountainChris
                                I’ve figured it out, its nothing to do with a watch.
                                • florin2528F Offline
                                  florin2528 Bronze Member @zvonejan
                                  @zvonejan nice, thank you. I will try it.
                                    florin2528 Bronze Member @florin2528
                                    Anyone knows how to get altitude during Trail Running?
                                    sartoricS cosme.costaC 2 Replies Last reply Reply Quote 0
                                    • sartoricS Offline
                                      sartoric Moderator @florin2528
                                      @florin2528
                                      What do you mean for “get altitude” ?
                                      In the results ? Watch ?
                                      SVTS - 2.50.28
                                      SSSWHR BARO Amber - 2.8.32
                                      Samsung A5 2016 - Android 7.0
                                      Suunto App Android 6.11.8 beta
                                      • cosme.costaC Offline
                                        cosme.costa @florin2528
                                        If you mean know the altitude during the run, I do not know with the standard sportmode but I use a custom sportmode where one of my fields is the altitude.
                                        florin2528F 1 Reply Last reply Reply Quote 1
                                          florin2528 Bronze Member @cosme.costa
                                          @cosmecosta
                                          I was with standard trail running mode, which fits my 95% of the needs. 🙂
                                          thanks,
                                          Florin
                                            florin2528 Bronze Member @sartoric
                                            @sartoric during trail running to show on the watch the altitude at which you are.
                                            I had a run into the mountains, and after 2300 m i started to feel a little dizzy and I wanted to see what’s the altitude. my colleague with ambit 2, told me in seconds, but could not find it on my S9B.
                                            Mff73M 1 Reply Last reply Reply Quote 0
                                            With your input, this post could be even better đź’—
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
