    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!
    330 Posts 46 Posters 87.2k Views 48 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • cosme.costaC Offline
      cosme.costa @Mi_chael
      @Mi_chael Yes, it could but I remember that was very difficult to find and if I recall well it was not in the manual, could be? I had to send my vertical back and I had to check everywhere how to turn it off.
      Anyway, Spartans and S can’t be turned off.
      1 Reply Last reply Reply Quote 3
      • Mff73M Offline
        Mff73
        There is a trick to turn off S watches, but it is to put the watch in “shipping” mode, then surely hard reset at the turning on.
        SSU (retired), SV1, SV2
        Wife : S9PP
        SA: Always the latest beta :)
        Android + Galaxy S205G
        M 1 Reply Last reply Reply Quote 1
        • M Offline
          Mi_chael Bronze Member @Mff73
          @Mff73
          Can you explain how?
          sartoricS 1 Reply Last reply Reply Quote 0
          • sartoricS Offline
            sartoric Moderator @Mi_chael
            @Mi_chael
            I’m sure it was explained in some thread. Search it 😁
            SVTS - 2.50.28
            SSSWHR BARO Amber - 2.8.32
            Samsung A5 2016 - Android 7.0
            Suunto App Android 6.11.8 beta
            • M Offline
              Mi_chael Bronze Member @sartoric
              @sartoric
              Read 8 threads but not found…
              • sartoricS Offline
                @Mi_chael
                But … did you search ? 😉
                https://forum.suunto.com/search?term=shipping mode&in=titlesposts
                SVTS - 2.50.28
                M 1 Reply Last reply Reply Quote 2
                • M Offline
                  @sartoric
                  When i used the research fonction, i’ve founded 8 topic.
                  But you’ve found 9. The answer is in the last topic.
                  Thanks man
                  • J Offline
                    Jonathan Schwarz Bronze Member
                    I think one of my biggest grievances with the S9B right now is how custom sport mode don’t save the last used configuration (ie the WHR, sensor syncing, SuuntoPlus option, etc).
                    I would really love to see that implemented as it would make starting an activity much smoother and faster (ie not having to go into the settings to adjust things before starting)
                    Suunto Race Steel All Black -
                    Suunto 9 Baro (retired)
                    Suunto Ambit 3 Vertical Lime (retired)
                    Suunto App - Always latest version
                    MiniForkliftM 1 Reply Last reply Reply Quote 4
                    • MiniForkliftM Offline
                      MiniForklift Platinum Member @Jonathan Schwarz
                      @Jonathan-Schwarz said in Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!:
                      I agree !! Would be nice to just hit Start without having to scroll down and adjust each time.
                      Or alternatively if you choose a setting say 3 times consecutively it would remember that and default to it. For example I always have to scroll down to turn the Wrist HR off as I don’t use it, would be nice if it ‘realised’ that and turned it off until I decide that I do want to use it. Sounds simple enough to implement
                      SV Titanium Solar Forest
                      freeheelerF 1 Reply Last reply Reply Quote 3
                      • freeheelerF Offline
                        freeheeler @MiniForklift
                        @MiniForklift
                        not sure if you’re using a chest belt instead? if so, WHR is switched off automatically.
                        I think too settings should be stored, unless the backlight. sometimes I run at day, sometimes at night…
                        living sideways
                        J MiniForkliftM 2 Replies Last reply Reply Quote 4
                        • J Offline
                          Jonathan Schwarz Bronze Member @freeheeler
                          @TELE-HO is that confirmed that the watch shuts off WHR if chest strap is paired? That was something I always wondered - say if the chest connection was lost for a period - would it switch to WHR instead. I always turn WHR offjust to be safe
                          isaziI 1 Reply Last reply Reply Quote 0
                          • isaziI Offline
                            isazi Moderator @Jonathan Schwarz
                            @Jonathan-Schwarz for what I know, the OHR is shut down if you have another heart rate monitor paired. And I don’t think it does turn on again if you lose the connection.
                            Blog: isazi's home
                            Saketo NemoS 1 Reply Last reply Reply Quote 2
                            • Brad_OlwinB Offline
                              Brad_Olwin Moderator
                              @Jonathan-Schwarz @MiniForklift @TELE-HO I too think the start menu is way overly complicated and I have been telling Suunto this every possibility I have. So have other testers. We are there with you. Hopefully Suunto will do something to change that, I just don’t know how difficult those changes are to implement. I suspect they are not trivial.
                              Vector/T6c/Vertical 2 Ti
                                MiniForklift Platinum Member @freeheeler
                                @TELE-HO No chest strap, I don’t use any HR. Notice that it’s always searching for it when I’m waiting to start an exercise - maybe there’s somewhere in the watch settings where I can completely turn of HR during exercise?
                                freeheelerF 1 Reply Last reply Reply Quote 0
                                  @MiniForklift
                                  no there is no default setting afaik… it would oversteer the startmenu setting or at least have a conflict.
                                  @Brad_Olwin
                                  …my bet: about one year from now 😉
                                  and it would be trivial, but let’s pretend it is not 😉
                                  living sideways
                                  • Saketo NemoS Offline
                                    Saketo Nemo Moderator @isazi
                                    @isazi
                                    Sure? it seems to me that since the last update we can, but I have to try. Not surprisingly, if I’m not mistaken, from the settings you can choose both to use the belt and to activate the whr.
                                    obviously in default it goes on belt, but if it loses the connection now, by activating the appropriate flag, it changes to whr.
                                    It seems to me that it was a function present in a Coros watch and required in this forum.
                                    But again, I could be wrong. My memory is not so strong
                                    MarynM isaziI 2 Replies Last reply Reply Quote 0
                                    • MarynM Offline
                                      Maryn Silver Members @Saketo Nemo
                                      @Saketo-Nemo this would be nice for longer runs for some user which are using for example polar oh1
                                      Suunto Vertical, Suunto Race, Edge 530, Vantage V, Suunto Wings, Polar H10&Verity Sense
                                      • isaziI Offline
                                        isazi Moderator @Saketo Nemo
                                        @Saketo-Nemo would be terrible for a OHR sensor, especially one on the wrist, try to get a lock on heart rate mid activity. It could take pretty long, and most probably lock on cadence if you are moving. And it sounds like a nightmare of edge cases, with decisions to take on what to do when the belt is connected again, if it is. The simpler solution, and the one that most companies use as far I can see, is to have memory on the chest sensor itself to compensate for disconnects, so that data can be transferred back to the watch post activity. Of course if the battery dies this does not work, but coin cell operated straps lasts for much longer than a watch.
                                        Anyway, easy to test. Start activity with paired chest strap, remove it, and go away until it disconnects, then check if the leds on the watch are blinking 🙂
                                        Blog: isazi's home
                                        • florin2528F Offline
                                          florin2528 Bronze Member
                                          from my side after more than 1.4k km with S9 Baro.
                                          cons:
                                          • sleep tracking, was not working properly. Taking movie watching and reading as sleeping. Garmin fenix5 didn’t do that. I’m not using it at all
                                          • display: light during evening/night
                                          • daily stress(WHR), battery was going low too often
                                            - GPS - less accurate than Ambit2 or phone, this is the most important one for me.
                                          • missing shortcut for airplane mode
                                          • you can’t see the time(hour) during an activity
                                          • WHR not working properly, I would prefer not to show the numbers instead of wrong readings
                                          pros:
                                          • well made, robust
                                          • good battery life compared with other
                                          • navigation - helped me a lot, by loading routes from colleagues, or defining new routes when running in new places.
                                          • good information on screen depending on the type of activity
                                          • I wouldn’t change it for Garmin, I tried fenix5 and was very bad on battery
                                          • nice straps
                                          Suunto issues:
                                          • difficult to order accessories in Romania
                                          • I like the Suunto app, I would like to have it on the web also
                                          Cheers,
                                          Florin
                                          MarynM Brad_OlwinB zvonejanZ florin2528F 4 Replies Last reply Reply Quote 2
                                          • MarynM Offline
                                            Maryn Silver Members @florin2528
                                            @florin2528 said in Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!:
                                            yes you can.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
