    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!
    330 Posts 46 Posters 87.2k Views 48 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • freeheelerF Offline
      freeheeler @isazi
      @isazi
      my assumption is that the sensor measures pressure change and FusedAlti says: no not possible and tries to correct it… but I’m not sure if FusedAlti is reacting that quick?
      I’m 100% with @surfboomerang the watch must be more customizable… also a gym workout with ascent is not really what I want to see… yes I do jump lunges… but not that high…
      living sideways
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @freeheeler
        @TELE-HO for the gym workout, just make your own activity and remove all the fields related to speed and movement. It’ll work.
        Blog: isazi's home
        freeheelerF 1 Reply Last reply Reply Quote 0
          freeheeler @isazi
          @isazi
          you mean custom activity?
          I don’t record gym workouts frequently… on Sunday I did… but more because of testing the OHR once again.
          Let’s hope Suunto gives us more customization on the sport modes. I don’t go paddling in the lake so often… and for surfing (let’s call it surfing when I try to catch some green and immediately end up in the washingmachine 😉 ) I never use my watch. It is a minor issue for me… but I don’t know how swimmers handle this? Do they get the result:
          1’000m distance swim while 500m swim-ascent?
          living sideways
          • isaziI Offline
            @TELE-HO yeah meant custom activity. Would be really nice being able to customize also default activities, but custom activities are already a very good workaround (they’re more than a workaround, but a workaround for this specific issue).
            Blog: isazi's home
              freeheeler @isazi
              @isazi
              this means for synced 3rd parties that I need to change the activity there manually?
              I think I’ll give this a try, thank you 👍
              living sideways
              • isaziI Offline
                @TELE-HO customisation begins with a base activity, and the type is derived from that. I made only one customised activity for indoor climbing and Strava and QS both see it as climbing.
                Blog: isazi's home
                freeheelerF 1 Reply Last reply Reply Quote 1
                  freeheeler @isazi
                  @isazi
                  just looked into it and of course I have all my sport modes customized. Or did I get it wrong now?
                  I have selected the screens I want and the datafields as I want… that’s what you mean by custom activity?
                  Because the only fields I have for e.g. SUP are: distance, duration, avg speed, speed, max speed… but after the activity it shows ascent in meters and the comment HR reading was not optimal (I’ve put the watch over my wetsuit…)
                  And for gym workouts I use the customized activity cross fit with PTE, duration, avg HR, HR and % of max HR
                  …I think I miss something here… thanks for your help!
                  living sideways
                  • isaziI Offline
                    @TELE-HO using MC or SA? I’m not sure if there’s a difference. I just used this trick for indoor climbing and other people found it was working for them too. There are one or two other threads about it.
                    Blog: isazi's home
                      freeheeler @isazi
                      @isazi
                      yes, I know, I saw them recently.
                      strange…
                      I’m using only SA (in combo with QS)
                      living sideways
                      • isaziI Offline
                        @TELE-HO now that I think about it, I also use the standard “strength” and “yoga” activities and they also don’t register any distance nor ascent/descent.
                        Blog: isazi's home
                        freeheelerF 2 Replies Last reply Reply Quote 0
                          freeheeler @isazi
                          @isazi
                          then it seems there’s room for improvement… not all outdoor activities require GPS and/or altitude
                          living sideways
                            freeheeler @isazi
                            @isazi
                            I just noticed that Suunto has no problems with this as SA does not show an ascent value for e.g. SUP…
                            and SA has no annual total ascent or something like that… since I mainly check my activities in QS, this issue comes to the surface. I have now manually corrected it in QS… so to say reasonable cheating for good.
                            living sideways
                            • isaziI Offline
                              @TELE-HO went to QS to check. I have no distance and no ascent/descent for yoga and strength activities, and the same for my indoor climbing custom activity. Also no ascent/descent for openwater swimming (but of course distance).
                              Blog: isazi's home
                              • Maxime RaemyM Offline
                                Maxime Raemy
                                add the possibility of creating specific training(intervalls running mode)
                                i.e. 2x (200-300-400-500)…. 2x(3x300-2x400)
                                sorry if this topic has already been asked
                                freeheelerF Václav KrálV 2 Replies Last reply Reply Quote 0
                                  freeheeler @Maxime Raemy
                                  @Maxime-Raemy
                                  search the forum for “structured intervalls” and do not get scared…
                                  hope never dies ✊
                                  living sideways
                                  Maxime RaemyM Michał RudzkiM 2 Replies Last reply Reply Quote 0
                                    Maxime Raemy @freeheeler
                                    @TELE-HO sad that this option was not renewed… 😢
                                    • T Offline
                                      tomahawk5000
                                      Hi guys, do you think that Suunto will release any other significant update for our S9B?
                                      Kind regards,
                                      Tomek
                                      Suunto 9 baro -> Vertical 2
                                      zhang965Z zvonejanZ Luís PintoL Brad_OlwinB N 5 Replies Last reply Reply Quote 0
                                      • zhang965Z Offline
                                        zhang965 @tomahawk5000
                                        @tomahawk5000 said in Pros/Cons of Suunto 9 BARO * ONLY * be fair and polite!:
                                        No
                                        Winners Wear Winners
                                        • zvonejanZ Offline
                                          zvonejan Bronze Member @tomahawk5000
                                          No
                                          • Michał RudzkiM Offline
                                            Michał Rudzki @freeheeler
                                            @TELE-HO no it’s wrong. “Hope dies at the end” 🐷
                                            Fenr1rF 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
