    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Export POIs from Suunto 9
    90 Posts 18 Posters 21.7k Views 17 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • isaziI Offline
      isazi Moderator @Dimitrios Kanellopoulos
      @Dimitrios-Kanellopoulos I have the feeling @djibarian means POIs recorded with the watch, and not route waypoints.
      Blog: isazi's home
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
        Dimitrios Kanellopoulos Community Manager @isazi
        @isazi then POIS are inside the app.
        Since the watch doens’t relate recorded POIS during or out of excersise as they are decoupled.
        Those pois do sync but then you need to create a route with those pois as waypoints.
        So here is the difference or the confusion.
        POI is not waypoint. It can be recorded outside an activity.
        Waypoints are waypoints on a route.
        When creating a route you can add waypoints. Those are exported in a GPX
        When you are doing an activity you can create pois. When also outside of the activity you can also create pois for example a nice spot while walking in the town. Those will sync with the app and be shown in the map.
        You can later on after your run/hike sync. That will get the pois and the route you did.
        You convert that workout to a route and then you create the waypoints of that route from the pois that are overlayed on the map. You export that route to GPX and apparently you have what you need.
        Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
        • D Offline
          djibarian Bronze Member
          @isazi Exactly, I mean POIs recorded with the watch, not as part of the route.
          Dimitrios, you say "You can later on after your run/hike sync. That will get the pois and the route you did. You convert that workout to a route and then you create the waypoints of that route from the pois that are overlayed on the map. You export that route to GPX and apparently you have what you need.”
          …You can later on after your run/hike sync. That will get the pois and the route you did.
          OK
          …You convert that workout to a route and then you create the waypoints of that route from the pois that are overlayed on the map.
          How to create the waypoints from the POIs, manually? 1) converting track to route throws away time info. 2) waypoints also have the time which were recorded, which is also lost.
          …You export that route to GPX and apparently you have what you need.
          That GPX doesn’t have time info and the coordinates and elevation are clamped.
          EASY SOLUTION:
          In the POIs tab, add an option to export all of them as GPX (or ideally, the selected ones). That would allow you to export the track as FIT (and then convert it to GPX without losing any data) and add to that GPX the POIs exported as GPX too, using a text editor and copy/pasting inside the XML. Not ideal, but at least you could extract ALL your data.
          Dimitrios KanellopoulosD sartoricS 2 Replies Last reply Reply Quote 0
            Dimitrios Kanellopoulos Community Manager @djibarian
            @djibarian well the information on the poi does contain the time created afaik.
            So this gets more complicated. You want:
            Activity export as GPX with the POIS that have a timestamp that belongs inside the activity timeframe.
            Unfortunately and coming back to some previous comment afaik this was never possible with movescount etc.
            Not very sure why this is a problem , in the perspective of something that was not there before. Sure if can be a feature request but we cannot say it’s just export pois.
            I suppose you want a GPX file with POIS that you load to another service right?
            M 1 Reply Last reply Reply Quote 0
            • D Offline
              Saving a route as GPX including the waypoints created to that route is OK, as the lack of precision is not a problem because you usually use that route to follow the path.
              But by the way, one problem with those waypoints is that the Suunto app doesn’t let you create a waypoint at any place, it has to be INSIDE the path. That’s a problem if you want to mark a summit but there is no path to reach it, and you now you can reach it across the field from the path, but need the waypoint to locate the summit.
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
              • sartoricS Offline
                sartoric Moderator @djibarian
                @djibarian
                I guess you’re not talking about POI nor WP
                you are talking about Track Points.
                Points added while recording the track (based on gpsmap 62 mentioned before).
                Like these , isn’t it ?
                SVTS - 2.50.28
                SSSWHR BARO Amber - 2.8.32
                Samsung A5 2016 - Android 7.0
                Suunto App Android 6.11.8 beta
                  @djibarian you can do a free drawing in the route planner for that specific case
                  • D Offline
                    Nope, you cannot create a POI outside the route. Try it.
                      @djibarian waypoint you mean? I just told you how. Do a free drawing to that peak and then long hold to add a waypoint.
                      If you don’t want to pass from the peak as of routing then no need todo it at the route planner. Add a poi at that peak. When in the activity, you can navigate to that poi via the navigation menu
                      • D Offline
                        oh, free drawing, I got it. Thanks!
                        • D Offline
                          and how do you add a poi to the peak outside the route planner?
                            @djibarian go to the map. Tap on the peak -> create POI -> name etc -> press add to watch.
                            Make sure you are on version 4.33.x (x is any number)
                            (do the above outside the route creation)
                            • D Offline
                              @sartoric I’m talking about both trackpoints and waypoints (or POIs)
                              • D Offline
                                djibarian Bronze Member @Dimitrios Kanellopoulos
                                @Dimitrios-Kanellopoulos said in Export POIs from Suunto 9:
                                cool, I see is a new feature in the android beta
                                  @djibarian at the same map you should be able to see also the pois you created with the watch.
                                  The same applies when you are using the route planner. So the pois are marked and you can create a waypoint at a route
                                  • D Offline
                                    I see you see the POIs in the route planner, but still you have to create the waypoints manually.
                                    Anyway that’s not a problem. The only problem I see now is to be able to export the POIs, whether all of them together, or being able to select some of them in the POIs tab, and export them as GPX.
                                    Do you think is feasible to expect that option to be in a next release?
                                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
                                    • M Offline
                                      margusl @Dimitrios Kanellopoulos
                                      I guess it’s technically correct. Just that bluntly copy-pasting data of few hundred POIs from Movescount.com in batches of 10, formatting as CSV and converting that list into GPX of POIs for using with other devices and mapping tools takes more determination than skill and something like 5 to 15 minutes from average user. That part of Movescount is also quite scraper-friendly.
                                      Fenr1rF 1 Reply Last reply Reply Quote 0
                                      • Fenr1rF Offline
                                        Fenr1r @margusl
                                        @margusl On the third hand, bulk export can be built-in. The ViewRanger app will export all visible (or total saved) tracks, routes (with named WPs) and POIs from the planning/review screen to a single GPX file.
                                        (Of course, VR doesn’t do much with health metrics. Or talk directly to anything other than its companion WearOS app.)
                                        Still a worthwhile standard to target, though. Unless Suunto wants to get away from GPX entirely ASAP. Which might be tricky as FITs don’t appear to be anything like as common as a route import format.
                                        • pavel.samokhaP Offline
                                          pavel.samokha
                                          Can’t promise on the behalf of the company, but we’ll probably add POIs import/export in the future
                                          Opinions expressed are solely my own and do not express the views or opinions of my employer
                                          1 Reply Last reply Reply Quote 4
                                          • isaziI Offline
                                            isazi Moderator
                                            Is there already a feature request? If not, let’s create one and vote. I honestly don’t use POIs, but also until 12 months ago was not using routes on the watch either. I am still a paper map fan! Anyway, I would vote for the possibility to export/import POIs from/to the app.
                                            Blog: isazi's home
                                            Fenr1rF 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
