@sartoric said in Export POIs from Suunto 9:
Waiponts are now in beta
I opened this post in August 2019 and they should come in the next updates… possibly maybe…, specially taking into account the frequency of Suunto apps updates to date. That’s fine.
@djibarian I’m using waypoints in beta.
@djibarian said in Export POIs from Suunto 9:
and they are … but …out of curiosity, I really cant understand if you’ve ever tried to use MC APP or not
Yes I tried but I found lost of problems before, like not being able to use one app if using the other. Maybe you’re looking this from a different point of view because you are an old user. But I started using the Suunto watch right away with the Suunto app, so for new users the path to going back is way more difficult, if possible.
@isazi is the beta public so I could use it?
@djibarian yes it is. It’s a beta, so there may be bugs and its purpose is to find bugs before hitting the public, but you can just join the beta in Google Play or the iOS equivalent.
Dear Sirs
Probably you can remember that but let me ask you one more time, when we can expect export new POI’s to the SUUNTO APP? -
@AdamMada now that waypoints are supported and work, hopefully it’s not too difficult to add pois.
@AdamMada said in Export POIs from Suunto 9:
Dear Sirs
Probably you can remember that but let me ask you one more time, when we can expect export new POI’s to the SUUNTO APP?It may come, but when ?
some readings
https://forum.suunto.com/post/49063
https://forum.suunto.com/post/2014
https://forum.suunto.com/post/46479 -
Still waiting for my POIs to be able to be extracted from my watch… totally ridiculous. If you are curious, I’m selling the watch.
So far the only way of extracting the POIs I found was via Movescount, doing some annoying trickery with the Bluetooth and then having to export all my data, where the POIs were, then selecting the one or two I was interested and deleting all the other stuff, downloaded after waiting for an email to arrive from Suunto saying that the export was ready. Totally stupid waste of time.
@djibarian Suunto app supports POIs in beta.
@isazi said in Export POIs from Suunto 9:
I guess that is clear, but does the beta Suunto app support extracting POIs?
@André-Faria Extracting as in syncing from watch to app? Yes it does.
Extracting (as getting a massive list of POIs to use in some other tool or device without a lot of rewriting or tedious copy-pasting ) is possible if one uses beta on rooted Android and can extract those pois from app db ( https://forum.suunto.com/topic/5543/android-4-33-generic-comments/64 )
OP is (or at least was) on ios.
Can we have a badge “Hacker” for this guy @margusl ?
Can we extract the POIs from inside the watch simply with a hammer?
@isazi I think you said the same 2 years ago, that the functionality was in the beta.
He , as we, probably said that the feature was coming (so probably was alpha test) but now you can see your POIs in SA beta
@margusl Yes I am on iOS but I wouldn’t mind connect the watch to an Android device if that would do the trick. But do you need also root the device?
@djibarian 2 years ago the feature was created . @isazi is here about 1 year like you.
The feature is recently on beta and actually now it’s rolling out on production of the Android app
Register Login
