    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    First questions about the Race 2
    Scheduled Pinned Locked Moved Suunto Race 2
    47 Posts 16 Posters 11.1k Views 18 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • JoaquinJ Offline
      Joaquin Moderator @SergioB
      @SergioB other option, if you carry your phone with you, is to simply edit the route in the app and invert its direction. In just a few seconds the route will automatically update on your watch without the need to stop the activity.
      Technical & Product Specialist – Suunto Iberia
      S 1 Reply Last reply Reply Quote 3
      • JoaquinJ Offline
        Joaquin Moderator @dreamer_
        @dreamer_ My colleague @pavel.samokha can explain about turns in GPX files, he is an expert, but basically if the turns are in GPX they will be in the Suunto app.
        We’ve discussed this internally many times. Some brands like Amazfit or Polar create turns based purely on the curve angle, which often results in unnecessary or misleading instructions. Coros doesn’t even display most turns correctly when exporting a GPX, showing the limitations of that approach.
        Creating turns only by curve degree can be risky and is not the solution we want. The only brand doing it really well is Garmin, which we understand is using map data rather than curve angles.
        dreamer_D 1 Reply Last reply Reply Quote 4
        • dreamer_D Offline
          dreamer_ @Joaquin
          @Joaquin btw. Thanks a lot for the very nice answers.
          One thing only. Amazfit had fixed al the TBTs in the last updates (at least for trail running, I don’t need the faster scenarios but I understand what you are talking about. The thing is they do work, or it seems. I don’t know if their approach is good or bad, speaking technically). They do work even in imported GPX are working by default. I tested this throughly and they were working incredible nice (at least in the last update, I don’t have their devices anymore due to some bugs and missing things I didn’t like). Garmin goes a lot further though. But then, Garmin maps are somehow slow (I read something about the CPU they are using as the cause, but I don’t have the reference)
          But the thing is, Suunto has done a fantastic job. But there are some details to have to look at yet
          Suunto Vertical 2 Titanium Sage, Suunto Run
          JoaquinJ 1 Reply Last reply Reply Quote 0
          • JoaquinJ Offline
            @dreamer_!
            We continue working on it!!
            THANKS A LOT FOR YOUR FEEBACK ❤️
            • S Offline
              SergioB Bronze Member @Joaquin
              Thanks @Joaquin , I was aware of the options of reversing the route with the phone. Overall I’m very satisfied with my SR, and the “issue” of reversing the route is not bothering that much (i’m not turning back that often, and when happens I can use the phone “procedure”). So no problem at all for me, I was just trying to underline what could be fixed/improved in the future!
              Suunto Race 1 and SuuntoApp on Android 13.
              JoaquinJ 1 Reply Last reply Reply Quote 1
              • JoaquinJ Offline
                @SergioB full agree, we continue improving Climb Guidance 😉 stay tuned
                  Dimitrios Kanellopoulos Community Manager @duffman19
                  @duffman19 Suunto has this as well. It’s on navigation
                  Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                  D 1 Reply Last reply Reply Quote 1
                  • D Offline
                    duffman19 @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos I wasn’t referring to creating your own POIs. I know those exist and use them frequently. We were referring to POIs and landmarks that are native to the on-watch maps. Things like road names, peaks, towns, etc. that are visible without having to create your own POIs in the app. This is one step below routable maps and what other companies have started to add to their mapping experience.
                    Vertical Ti / S9PP Ti / S9P Ti
                    Tomas5T 1 Reply Last reply Reply Quote 2
                    • Tomas5T Offline
                      Tomas5 Gold Members @duffman19
                      @duffman19 this would be awesome feature, because if you have offline map downloaded, and it is just “blind” map without any labels, it is hard to use it for any navigation when you are lost.
                      Suunto Ambit 2 > Suunto 5 > Suunto Race 2
                      dreamer_D 1 Reply Last reply Reply Quote 1
                      • dreamer_D Offline
                        dreamer_ @Tomas5
                        @Tomas5 is not only about labels.
                        Actually all brands are putting some POIs by default. I.e: when you are in the maps, you can not only see street names, but water fountains, bus/train stations, pharmacies,…there are some interesting use cases. The most interesting one for me is just the water fountains while trail running. I like a lot to train in the mountains and see there’s a fountain near. The rest is not that important for me but I understand that It could be for hikers and people that does a lot of mountainering.
                        At the end, Suunto has the mountains in the heart, and the Race and Vertical watches cost between 500 and 800 euro…If there are cheaper watches that can fix all the navigation things we were talking about, Suunto should (of course) 😉
                        And now even more, when Suunto’s watches are better than ever. Perhaps we see a fix soon and the Vertical 2 , has everything in by default. I have a very big interest in that watch
                        • S Offline
                          szleslie Bronze Member
                          Maybe I am not educated enough but please enlighten me how you use these small screens for navigation where labels are useful and important?
                          I use only the loaded track and follow it. If there is a complicated junction the map helps me to decide which way to go. Zoom level is 25-100m. I use it this way. No more no less. This simple.
                          Do you check the street or track labels while walking/running/cycling? If I zoom out to get a broader view the labels are disappear on my Garmin. They are not useful any more. I always have a phone on me where I can check the map with every feature’s name. I used twice on device route planning but it was pain in the but. It was a Garmin Edge 830 and a Fenix 7X. Phone is more useful. Usually I plan my tracks at home. If on site route planning is needed I always used my phone to do that not my Garmin.
                          Now I have Race 2. My only pain is it is not possible to send new track to the watch without internet connection on iOS. I asked support about it. They sent me a long answer. On iOS there is some file handling limitation. Android is ok in this regard. If it will be solved it would become a more outdoor watch.
                          Tomas5T dreamer_D 2 Replies Last reply Reply Quote 5
                          • Tomas5T Offline
                            Tomas5 Gold Members @szleslie
                            @szleslie this is valid point, i see it only like last case scenario. I can imagine that you are in mountains, not sure how to continue with hike. No internet connection and you have offline maps in watch. So you can look around for some known point, maybe some peak, lake, or something that will help you to get better orientation. And than another scenario, you have created path in phone and on the route there may be some interest point like waterfalls, lakes etc but you didn’t create POIs for each. So it can just help you estimate how far it is to this points. Currently i don’t have watch with offline maps but i can imagine this scenarios to be usefull. Phone is best in backpack, watch is on wrist available all the time to check.
                            S M 2 Replies Last reply Reply Quote 0
                            • dreamer_D Offline
                              dreamer_ @szleslie
                              @szleslie POIs are not labels, POIs are icons. Then, there are the labels of the streets.
                              I.e. a water fountains is just a raindrop
                              S D 2 Replies Last reply Reply Quote 0
                              • S Offline
                                szleslie Bronze Member @Tomas5
                                @Tomas5 You are right. I was thinking where can I use it this way. I came up with same. There are conditions where paper maps and phones are not easily usable if at all. Last chance back up solution can be a watch with full maps with labels and everything and on device routing. It is better than nothing.
                                • S Offline
                                  szleslie Bronze Member @dreamer_
                                  @dreamer_ I agree. It is useful for some. I think it is not important for me at the moment. Maybe in the future. Who knows. I am a cyclist first than a hiker (more of a short walk than a hike). A simple map is enough for me. Repeat, for me:). I tried local tourist map with colour coded tracks and it was useful on my Garmin. Unfortunately it was painfully slow, the map rendering. Suunto is much better in this regard. Every watch needs some compromises.
                                  If Suunto will add more map features in the future, please make them optional. Switchable labels, POIs etc.
                                  • dreamer_D Offline
                                    dreamer_ @szleslie
                                    @szleslie I agree. My Epix Pro gen2 is not good for hiking because the mapping is incredibly slow.
                                    • D Offline
                                      duffman19 @dreamer_
                                      You guys make great points. I don’t think anyone is really using a watch to make high-level navigation decisions (at least I hope not). Suunto’s barebones maps are really great for giving just a bit of context when you are following a pre-planned route.
                                      But having just a few simple POIs baked-in would be really great for the examples you gave above. Things like shelters, water, trailheads, parking lots, cliffs, peaks, and the like (“mountain” focused POIs) would be awesome for quick diversions or emergency situations. And making them an optional layer (good point @szleslie!) would be great so you can still enjoy a simple, uncluttered map experience when you don’t need them.
                                      Having a POI icon layer (no labels, just icons) would be a great way for Suunto to differentiate themselves from the competition while keeping things clean and simple.
                                      • sky-runnerS Offline
                                        sky-runner Platinum Member @Joaquin
                                        @Joaquin in my experience auto-reverse function often activates when it really shouldn’t. It should, as you say, activate only if you already go in the opposite direction for 200 meters, but in my experience just momentarily losing the route if enough to flip it even if the watch never tells you that you are off route.
                                        Here is a fresh example from yesterday. I was doing a trail run that consisted of two different 10 miler loops with a resupply at my parked car in the middle. I never was further than 15 meters from the route and never changed my direction, but after the resupply stop it decided to reverse the entire route. And then it took a very long time to actually convince the watch to use the original route the way I planned. The problem is that I didn’t remember how I planned it. On the watch map screen there were 4 paths leading to the car or leaving the car, and I had no idea which one to take to stick to my plan. I ended up opening the route on my phone to figure out where I was supposed to go next. This shouldn’t happen.
                                        There are may more examples like that. Once because I parked slightly off the route and was off route for the first couple of thunder meters, once I reached the route, the watch flipped it. That was extremely annoying because for the remaining part of the day the elevation profile was moving right to left. Basically the watch decided to do the entire route in reverse, even though there was absolutely no reason for that.
                                        Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
                                        Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
                                        S 1 Reply Last reply Reply Quote 2
                                        • Jakub BrzóskaJ Offline
                                          Jakub Brzóska
                                          @Joaquin are there plans to refine pool swim? i mean manual intervals with lap buttons for example?
                                          • wzxecrW Offline
                                            wzxecr @Steven Hambleton
                                            @Steven-Hambleton Thanks. I support this too. I have the Race S (and just ordered the Race 2). I love ti but I really miss the possibility to set a specific alarm clock on a specific day
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
